Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
Pump leaking how do i remove the impeller from the motor shaft
  • 106 Answers
Some impellers have a screw in the middle which screws into the centershaft with reverse threads. If it has one, unscrew that first. Next, there is either a flat on the shaft near the opposite end or there is a slot in the end of the shaft for a screwdriver. Hold the shaft securely, and unscrew impeller. Sometimes a big pair of pliers is needed, but be careful not to damage impeller.
Posted on Jul 23, 2010
Pentair 011523 pump shaft seal is leaking. How do you remove the impeller and motor?
Separate the plumbing portion of the pump from the seal plate which is attached to the motor. The bolts will be a 9/16 inch hex head, that are visible facing the motor. Remove those bolts. That will then allow you to pull the motor and the seal plate away from the plumbing portion of the pump. Remove the diffuser which is covering the impeller, and then the impeller will need to be unthreaded off of the motors shaft. The motors shaft, will need to be locked. You can do this by removing the Cap on the backside of the motor and you can use whatever tool required to keep the shaft from spinning. Once you are able to lock the shaft, you can read the impeller... Note* some styles will have a screw in the middle of the impeller securing it to the motors shaft? This screw is Backwards thread, not normal thread. If your pump has this screw, need to remove it first, then you will be able to unthread the impeller off of the motors shaft.
once the impeller is removed, you can then remove the two halves of the shaft seal. Very carefully reinsert the new shaft seal into the proper places, just the way they were prior to you removing them.
Reassemble in backwards order as you disassembled everything.
good luck
Sep 04, 2013 | Pentair 011523 WhisperFlo High Performance...
Remove impeller from Waterway 502n22c
To remove the impeller you first take the front face plate off to expose the impeller. Then isolate the shaft from the motor with a pair of needle nose vise grips and using a pair of channel lock pliers grip the end of the impeller and rotate counter clockwise to un thread it from the shaft. If the shaft seal has been leaking there may be to much corrosion to turn the impeller in which case it needs to be broken off.
May 13, 2013 | Waterway 5HP Executive 56 Frame Spa Pump...
Hi, I have a waterway executive 48 spa pump and need to replace the seal on the pump shaft. How do I get the impeller off the shaft to access the seal.
Thank you for posting your question here on Fixya.com.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. You will also need to check for an impeller screw in the center of the impeller inlet. If a screw is present they are usually left hand thread. Back out the screw first, then proceed to remove the impeller.
To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jun 13, 2011 | Pool & Spa
How do I removie the impeller to renew the seals the pump ie leaking and I have new carbon seals nad I have removed left hand ihread nut at the front of the impeller but it will not come off
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
John
Feb 01, 2011 | Sta Rite Max E Pro 2 Hp Up Rate Energy...
Winding noise with some water leaking from the motor seal. Water still flowing but sounds laborous.
The shaft seal more likely than not needs to be replaced. If your shaft seal has been leaking for any length of time, the bearings could be damaged and this should be replaced. The whisperflow uses a PS1000 shaft seal and is fairly easy to replace (most seals available online or at most swimming pool retail stores). It is best advised not to run the pump until you have had this inspected by a licensed pool technician or have changed out the seal.
1) Make sure breaker/power to pump is off. 2) Remove the six bolts holding the wet end to the seal plate. 3) Remove the diffuser to expose the impeller. 4) Remove the screw in the middle of the impeller by turning clockwise (left hand threads). 5) Remove the dust cap at the rear of the motor and use a wrench to hold the shaft while you remove the impeller by turning counterclockwise. 6) Once the impeller is off, remove the four bolts holding the seal plate to the motor. 7) Press the old seal out of the seal plate and clean it thoroughly. Remove the ceramic part of the seal from the impeller and clean it thoroughly as well. 8) Apply a thin coat of lube (I prefer Magic Lube or Lube Tube) to the seal plate and impeller where the new seal will go. 9) Remove the new PS1000 shaft seal from the box (being careful *NOT* to touch the ceramic or carbon face with your fingers), press the metal part into the seal plate carefully, try not to bend the metal and make sure its completely seated against the seal plate. 10) You can now install the seal plate back onto the motor and secure with four bolts. Press the ceramic part into the impeller, use cardboard or paper between your fingers and the ceramic face. 11) Once you have seated the seal into the impeller, hold the motor shaft and thread the impeller on until snug, then reinstall the stainless screw, remember it is left hand thread so you'll have to turn it counterclockwise. 12) Reinstall the diffuser over the impeller and then install the wet end onto the seal plate using the six bolts, don't overtighten them.
Check the pump for operation and you should be good to go!
Dec 07, 2010 | Pentair 011515 WhisperFlo FullRated Energy...
Water coming out down by motor , pump is pumping but leaking. how do you get impeller off
sounds like a shaft seal leak..... cut power to pump ... unbolt the motor at the seal plate and pull motor from pump... take electrical cover off back of pump and hold the shaft at the middle (may have to do some digging to find it) of the back of the pump... now youll be able to remove the impeller by spinning it counter clockwise...
make sure you dont go cheap on the seals... and make certain to replace all seals on pump
(diffuser oring, housing gasket, shaft seals, and lid gasket
May 23, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
My Hayward just hums when I turn it on and after a few seconds the breaker pops.
You will need to disassemble the pump and check the impeller. remove any debris and try turning the impeller by hand. If it does not move or is dragging, you will need to overhaul the pump. Possibly a shaft seal leak has damaged the motor bearing(s). Replace the shaft seal and motor bearings. If the motor is badly deteriorated, you might need to replace the motor. Note... the impeller turns counterclockwise to loosen. you may need special tools to grip and hold the motor shaft and the impeller to prevent damage to the impeller. If the impeller is seized on the shaft from rust, you may have to break it to get it off. reassemble with teflon lubricant on the shaft threads when reinstalling the impeller. This will prevent seizure later.
Apr 10, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
REMOVE IMPELLER FROM SHAFT A O SMITH PUMP MOTOR HIFLO
The impeller is threaded onto the motor shaft, take the back cover off and use a wrench to hold the motor shaft, then turn the impeller counter clockwise to remove.
Mar 15, 2010 | Plumbing
Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Jun 03, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pump disassembly
I removed the impeller on my DW761UQB. The instructions were molded into the plastic pump housing. This is how I DID MINE: Remove motor mount screws. Remove the chopper screw (screw only goes into impeller, not motor shaft). Remove chopper and rotate/remove strainer. Place socket or wrench on impeller tip and place another wrench on rear of motor's plastic fan. Unscrew fan from impeller shaft ( threads are LEFT handed, turn CW). Once fan is 'backed off' of the impeller, CAREFULLY pry the motor/fan from pump housing (impeller is attached to motor shaft via splines). Don't crack the delicate plastic pump housing. Mine was stuck, but separated with moderate force. Now remove the impeller/seals from the pump housing. This worked for MY above mentioned model, I don't know what other models it applies to. I am not a pro.
Sep 25, 2008 | Dishwashers
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
122 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
