Question about Whirlpool Washing Machines
My washer has water in the bottom under the inner tub even when the machine is not in use. When I jigggle the inner tub I can hear it slosh around. Is this normal.
  • Whirlpool Master
  • 8,220 Answers
What you hear is liquid in the balance ring. Normal.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 22, 2010
How to drain the inner tub of washing machine
we dont have much call for top loaders in the uk, but if they are like front loaders, there should be a filter at the bottom either on the left or right. if so, pull the machine forward and then tilt it back against the wall. not too far in case it slips forward and lands on its back.
remove the filter cover and then using a bowl and plenty of towels, tilt it forward and let the water run out.
hope this helps
May 12, 2014 | Washing Machines
Unbalance when spinning
Unauthorized water gets into the tub ring. Sloshes about and cause unbalanced load even if nothing is in the washer. Rich mans solution: replace inner tub. poor mans solution: drill holes, drain water.
Dec 18, 2010 | Maytag Bravos MTW6600T Top Load Washer
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Mildew smell
water may not be draining completely out cause something is stuck in drainage area.
Other posts tell how to remove the top of washer to look between white outer tub and inner wash tub for sock or something else that is lodged.
Look at my post on "eco smart won't drain, smells hot" for instructions on removing the black motor/white plastic housing from bottom of washer. I had a sock stuck in the very lowest part of the drainage system, water wouldn't drain out and couldn't see the sock until I removed the motor. I was able to pull the sock through the quarter-sized hole in bottom of tub and drain the remaining very stinky water. I used a dog dish (need a low edge bowl to fit under washer), tipped washer forward, then back and just kept emptying the dish.
Saw another post said don't tip washer back. There is something on backside of washer that you could break if you tip backwards. So, if you tip forward i guess you won't break anything--i haven't...yet.
Noticed a musty smell lately, and also had gray streaks on my clothes. Think the standing water that wouldnt' drain out has been my issue for some time now and when the motor burned out, I finally had to research the other issues.
Sep 20, 2008 | Fisher Paykel EcoSmart GWL15
Water stuck...
There is an internal overflow hose to prevent water from getting onto the motor and other electrical components. It sounds like the overflow system did its job.
The water you hear is likely one of two things: a small amount of water that is still in the tub, under the basket, which is nothing to worry about. Or, you are hearing the fluid (that is supposed to be there) in the balancer.
Feb 21, 2008 | GE WBXR2090B Top Load Washer
Water in Outer Tub
My washer does this too and I called Maytag and was told it was normal. I don't like that answer, though.
Mar 06, 2007 | Maytag Neptune MAH5500B Front Load Washer
Water left in barrel (not the tumbler)
If you can't see any water and just hear it, this is completely normal. This is a front load washer and has a special cover of the inner tub basket. This cover contains some water that has been sealed in at the factory to keep the load balanced while it is spinning.
Nov 25, 2006 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
304 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
