Question about Canon LaserCLASS 3170 All-In-One Printer
Supply Rec. Paper message keeps flashing even though paper trays are full
  • dgarcia45 Jul 23, 2010
    Supply Rec. Paper message keeps flashing even though trays are full
    I Appreciate the help, Thanks
    Guru:
  • 722 Answers
Hello there,
Unplug the printer, and wait about 1-2 minutes. Plug the printer back in. Wait until it is finished resetting itself. If the paper light is still flashing, the sensor inside may need to be adjusted, as it may not be detecting the paper.
Also, make sure there is no paper jammed up in the rollers inside. Even the smallest piece may cause this light to stay on.
Also, make sure there is not too much paper that it would no be able to feed the paper through in an attempt to print a document or photo etc.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
Posted on Jul 23, 2010
  • Brandon Bruce
    Brandon Bruce Jul 25, 2010
    More simply, it could be dusty inside as well - try blowing it out with a hair dryer (cold air) or with an aircan. Just trying to think of what else would cause this if the tray's are full.
    carsandcomps,
  • Canon Master
  • 6,826 Answers
I couldn't download a manual for your 3170 laserclass all in one printer but the brochure is available.
Also, troubleshooting didn't have your specific problem.
I think that if you look inside where the paper tray goes, there is either a lever that senses when there is paper, or a photo eye that senses when there is paper in the tray.
I would try asking tech support at Canon what they think is causing this paper empty error.
http://www.usa.canon.com/cusa/office?pageKeyCode=contactUsLanding
Posted on Jul 22, 2010
I am getting flashing error messages 'Supply REC. Paper Tray: LTR' and 'Received in Memory'. There is no paper jam and there is paper loaded in the tray. I have also tried to manually feed paper. I have...
Hi there:
I had the same problem and it made me crazy. All you have to do is pull out the paper tray, pinch the very back wall of it (I think it has a blue button to pinch) and slide the very back of it forward so the paper is snug in the tray. Put the tray back in and it should go away. :)
Hope I helped........
Mar 09, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
Error message saying "supply rec. paper"
There is a small side tray on the right side of the machine,check if there are paper loaded in.
Jun 30, 2009 | Canon LaserClass 9000L Plain Paper Fax
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Message keeps paper tray is full and it is full.
pull cassette out and look inside the cassette bay on the left side. there is a white gear that lifts up your paper. that might have come unseated. make sure its seated in right by pushing it back in. last but not least, make sure you don't have your rear paper stopper in cassette pushing paper too hard against the front of cassette preventing paper from raising up.
Mar 09, 2009 | Brother MFC-8460N All-In-One Printer
Message keeps saying out of paper and paper tray is full.
ok heres what u can do go to ur printer options and check if the paper is set to "letter" or "a4"
Supply Rec. Paper tray will not clear even with a whole ****
Ok try this - switch the machine off at the mains, empty the paper tray. Push the paper tray back in and switch on the machine with no paper in it. When it's finished warming up it should tell you the tray is empty. Then put paper in. This will usually clear it.
Jan 24, 2009 | Canon imageCLASS MF5550 All-In-One Laser...
Printer will not print: Canon imageCLASS D320
The paper size selected in the menu system must match the paper size in the rec. (recording) paper tray. If you have 'letter' size paper in the tray and the menu system is set for 'A4' paper you will get this message. Either put A4 size paper in the tray, or change the paper size in the menu system to 'letter'.
Oct 15, 2008 | Canon imageCLASS D320 All-In-One Laser...
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Supply rec. paper Tray:LTR
Sorry i said he reset it, he actually cleaned the feed rollers and run a bypass to allign the feed drive unit, I am getting him back in so i will keep you all posted on the outcome
Feb 21, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Check paper tray - reload paper
Your paper sensor actuator arm is most likely broken or out of position, or you may have a dirty sensor if you are in a dusty environment. If you look in the machine with the tray out, you should see a small (usually black) piece of plastic hanging down. You can also take the toner and drum cartridge out and turn it on its back to get a better look. If it's not there, it's probably broken off.
Feb 07, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
69 people viewed this question
old marine
old marine
