Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
I recently attempted to fix Panasonic PT-53wx53g projection HDTV. It began with a blue "bowing" at the base of the picture, so i changed convergence chips that i bought at a local electronic supply and surrounding resistors. I powered it on and the resistors began glowing, smoking, then the tv powered itselft off. I was advised to buy a kit from the internet which consisted of two new chips and only half the resistors that surround the chips, the instructions said these were the only ones feeding the chips. I have installed all the items from the kit, and now the tv powers on, makes a high pitch squeal, then powers off and blinks 3 times. No smoke though. no glowing either. Need some advice please.
  • CaseyCCT Jul 22, 2010
    Im sorry typo, its a PT-53tw53g model
Slinteriors
  • 8617 Answers
SOURCE: PT-53WX53G Serial # LX32310034. Aug 2003
replace the covergence ICs STK392-110
Posted on Mar 08, 2008
welcomejee
  • 10594 Answers
SOURCE: panasonic pt-53wx53g vertical output ic
IC451 (Vertical Output) LA78045 part number is C1AA00000521
Available in Part Store.
Above info are taken from related service manual and an image of s.manual is given below...
Posted on Jun 19, 2009
dave1645
  • 834 Answers
SOURCE: I have a Panasoic PT 53WX53G rear projection TV, I
yea any 2.2 ohm at at least 2 watt any tv shop should have them good luck
Posted on Nov 23, 2009
Testimonial: "Thank you This is a great service!"
Slinteriors
  • 8617 Answers
SOURCE: MY PT-53WX53G turns off when powered on. The
Thats the error for convergence failure. Heres a link to the repair kit for your model which contains the parts and the CD with detailed instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Posted on Jul 07, 2010
  • 8457 Answers
SOURCE: I have a Panasonic Projection HDTV that i recently
The 2 STK convergence ICS are dead,all the resistors too,if it is smoking and glowing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it again.Find the correct tv make and model.The convergence kit buy from one of these website's will have all the parts to repair it right this time.
Posted on Jul 16, 2010
I have a 7 year old Panasonic HDTV. Picture quality has been great until today. As an example, the banner at the bottom of the picture is visible but it is also displaying in an arch mode above the...
Tv any colors mis alignment.The tv convergence board parts are dead.The convergence board require changing the 2 STK convergence ICS and some or all it resistors,this parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Jul 06, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Blue/yellow shadows
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Ghosting in Red, Green and blue
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 24, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Convergence IC's
Buy the STK392-120 they are a better chip. Some people say go up to the STK392-150 but i had an issue trying that with a panasonic it keep burning resistors as fast as I could change went back down to a STK392-120 and worked great.
Jun 03, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Phillips 60 inch HD rear projection? Convergence!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 26, 2007 | Panasonic PT-53WX53 53" Rear Projection...
PT-47WX53 blue convergence
you will need to change or have the convergence IC's replaced I'm afraid. Good Luck
Aug 15, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Power comes on then goes back off.
More than likely, the two convergence IC's have to be replaced.
Jan 28, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
