Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Not operating my machine starts up as usual then stops and flashes A03 with the add salt symbol. There is more than enough salt in the machine, what do I do???
  • Sarahjewell May 13, 2008
    Flashes add salt - although salt is full up
  • Anonymous Jul 18, 2008
    my machine has an aoi symbol and will not start as normal , what do I do ?
Yes
Posted on May 04, 2008
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 | Dishwashers
Silvercrest bread maker
It's best to follow your manual as there are specific steps to be followed at specific times. First you add liquids (water, oil, etc.), then sugar and salt, then flour and finally yeast as the last ingredient. (Don't let the yeast come in contact with the liquids or salt).
When my wife & I make bread, we usually mix in a little additional bread yeast just to make certain everything g goes well. Make certain your water is at room temperature, not too hot, nor too cold.
Next place the baking pan into the machine, locking it in place.
Plug the bread maker in and you get a signal beep and program 1 appears in the display. You can set the browning level at this time. You can also set a delay for up to 15 hours before starting if you wish.
Press start and the machine starts to mix and then kneed the mix. It will start, stop, start again, etc. Just let it do it's thing until it beeps 10 times and the display reads 0:00.
Take it out, be careful, it will be hot.
I don't know which Silvercrest you have, but if you don't have a manual, here's one you can download. Should be near enough to yours to get you through your first loaf.
data manualslib com
Mar 10, 2014 | Kitchen Appliances - Others
How to stop it frfom beeping/flashing 91 low salt.
1st... Check electrolytic cell and clean with vinegar...If white scalley stuff inside, cap one end and soak for 6 to 12 hrs and rinse until clean
2nd...check salt level, see manual for PPM, if low, add salt.. If you have a big pool 12000 to 15000 gallons, you will have to add up to 100 lbs of salt..
3rd... Run only pump for 24 hrs to dissolve salt..
4th... Set you cycle and should be fine
Hope this helps and rate if it does
Jul 16, 2011 | Intex Automatic Salt Water System for ...
I just bought a saltwater system for my 12x39 pool a month ago did start up like book said and pool was fine for a month then the low salt light came on so i put 15 lbs of salt in per instructions kids...
you really should get test strips for salt. Get the kind that reads #'s
Get your pool to as close to 3000ppm as you can. any lower than 27000 and you do not generate enough chlorine any higher than 3600 will taste bad and could trigger high salt alarm 3000 is best
run filter only for a few hours before running generator the salt needs enough time to fully distribute through the pool
Jun 30, 2010 | Intex Automatic Salt Water System for ...
Lost manual
I am assuming you have poured in the correct amount of salt. If not post the size of the pool and I can list the correct amount. Now, you will need to set the hours of operation according to the size of the pool which I need to know in order to help more. I will go through the procedure of startup. When you turn the pump on after dissolving the salt in the pool, it will show a code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep. The LED will flash 00. Your keypad is now unlocked. Push the up button to set the number of daily hours of operation according to the size of your pool. Up to add hours, down to remove an hour. If you do not have an owner's manual tell me the size and where you live and I can tell you how much salt to add and hours each day to run.
May 30, 2010 | Intex Automatic Salt Water System for ...
I need an instruction manual for my Deni 5000 ice cream maker
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Oct 14, 2009 | Deni 5000 Scoop Factory 1.5 Quart Ice...
My pool was clear and just great. all of a sudden the low salt light came on and stopped producing clor.so put a bag of salt in started it up and same thing says low salt , so i bought another bag put it...
Salt sensor is dirty;
Use diluted solution of muriatic acid. Contact spa store for comments/suggestions.
Brush with a mildly abrasive green fiber household cleaning pad. Contacts should be clean and bright.
WARNING Inhalation of muriatic acid vapor or contact with skin or eyes can cause serious injury or death. Wear goggles and rubber gloves, and perform cleaning in a well-ventilated area. Add acid to the water; do not add water to the acid as splashing could result.
Thoroughly rinse the Flow/Temp/Salinity Sensor with clean tap water. Replace and resume normal operation.
Sep 03, 2009 | Pool & Spa
I have a ectrolux ewf 1074 with the padlock symbol
you need to turn machine on and hold the option and extra rinse buttons simultaneously for 6 seconds, the symbol will go and you'll be able to use your machine again as usual
Aug 02, 2009 | Electrolux EW1000i Front Load Washer
Control panel
Try turning off the breaker to it for a few min… and then turn it back on that might reset it.
Nov 07, 2007 | Smeg DWI614 Built-in Dishwasher
Salt Indicator Light Flashes Permanently On Indesit IDE 750 dishwasher
I think I have the answer.
On Yahoo Answers Blue Rizla Girl put up the idea that the sensor is some form of hydrometer. (i.e. floats in salty water sinks if not salty enough)
Based on this thought I postulated that the sensor is some form of hydrometer float in a tube with perhaps an optical sensor.
If this is correct why is it not working?
Is it because the float is stuck at the bottom of the tube, perhaps by some food debris? If so how can we fix it?
This is what I did on my Hotpoint FWD60:-
I took the salt filler cap off. There was no salt in the reservoir as it has been a problem for months, and I was only refilling it when dishes were not coming clean.
I poured 2 litres of hot water into the salt reservoir.
I then put the empty machine on the intensive 65 degree wash, half load and with the reservoir cap still OFF.
When finished I filled up with salt and HEY PRESTO the salt light is OFF!!!!
Just hope it stays that way until the reservoir really needs refilling.
While I was down on my hands and knees I took the opportunity to clean the filters in the sump. They do get full of bits!
I also flushed the sump by dashing a couple of cups of hot water into it and then bailing it out with a small yoghurt pot. I repeated this until the water in the yoghurt pot and the sump no longer had any signs of bits in them. (Dashing = vigorously pour)
I was amazed at how many bits I got out, especially considering I had given the machine a good clean in the past 6 weeks.
I even got part of a paper label!
So there we have it, try it out and report back.
Sep 14, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
257 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
