Question about Brother IntelliFAX 4100 Laser Fax
Brother intellifax 4100 clicks during receive
Fax machine just started making a loud clicking noise when it receives. tried a new toner cartdrige and cleaning but still have clicking sound. What is the next step?
  • chuck1262 May 01, 2008
    Swapped the toner / drum unit with a like model still makes same noise... Is the fuser unit a separate component?
  • cwrd May 02, 2009
    We have gone through 3 IntelliFAX 4100 machines in less than 18 months (small office - real estate) - they are good until they start clicking! Our make a loud clicking noise and the output is full of lines across the page. I have heard that recond cartridges may be the problem - however - even after replacing both the fuser / drum and the cartridge - it still has the same problems. I'm ready to change brands unless someione has an answer. - at $299 - they should last a LOT longer...
Our tech told us that any cartridge from Office Depot will make it click and have problems. We changed back to a Brother cartridge and it works fine!!
Posted on May 29, 2008
Did changing the fuser unit help?
Posted on May 19, 2008
Change out the fuser unit!
Posted on May 01, 2008
When I go to print or copy the machine makes a loud clicking noise and then says paper jam. Brother MFC - 8460 N
The loud clicking noise is either the toner cartridge or the paper feed. If the jam occurs in the drum and toner cartridge then I recommend changing the toner.
If the paper is not being fed at all then you need to have the paper feed kit replaced.
Thanks,
Pat
May 11, 2010 | Brother IntelliFax-2820 Laser Fax
I have a brother intelliFax 4100. I cannot receive fax.
While it is ringing press the START button. You are set to MANUAL RECEIVE
Feb 08, 2010 | Office Equipment & Supplies
Loud clicking noise when faxes arrive
The noise may be caused by the toner cartridge binding up. This can happen with remanufactured cartridges more so than OEM. Try swapping out the cartridge.
Apr 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Have you tried a new toner cartridge?
Oct 27, 2008 | Brother IntelliFAX 4100 Laser Fax
Grunting noise?
If your machine is a Brother 4100 you can clear the drum message by pulling the drum out of the machine and then pressing the clear button. The display will ask if a new drum is the be installed. Press the number 1 to say yes. Reinstall drum. This resets the drum counter.
As far as the grunting sound, that may be caused by a tight or jammed toner cartridge. Try changing that out.
Hope this helps.
Aug 27, 2008 | Brother IntelliFAX 4100 Laser Fax
Intellifax 4100 grinding noice
Probably caused by the toner cart. Only use genuine new Brother brand supplies. Remans fail quite often with Brother machines.
Possibly bad gears on fuser drive. But with the poor print quality, I suspect it is the toner.
May 02, 2008 | Brother IntelliFAX 4100 Laser Fax
"Clacking sound when receiving faxes"
a clacking noise is not good, what's the make and model of your machine.
Thank You,
Mikey
Apr 04, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxes received are so light, the page looks blank
don't forget to try other fax-paper... your's might have already expired.... if this doesn't work... the printer's heater might need changing.
goodluck... hope this helps.
Feb 26, 2008 | Brother IntelliFAX 4100 Laser Fax
Gears grinding with Brother Intellifax 4100
Does it only make the noise when printing. Do you hear the noise when sending out faxes? I have heard grinding noises onlt when using poor quality toner refills, or the fuser gear and or drive gear asm is stripped. First try a known good OEM toner.
Mar 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
558 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
