Question about Mitsubishi VS-60803 60" Rear Projection Television
Mitsubishi vs-60803 turns relay on board then goes
Mitsubishi vs-60803 Power relay on board engages when power button is pushed, then goes off right a way. Please feel free to get technical!
  • Mitsubishi Master
  • 1,906 Answers
Replace the power relay the contacts are burned and, will not latch.
Posted on Jul 22, 2010
Mitsubishi VS-70707 rear projection TV
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Jan 31, 2008 | Mitsubishi WS-55807 TV
The 4 wheel drive doesn't work in my 89 Ford Bronco
The sound is not coming from the glove compartment, it is coming from the panel behind the drivers seat, that's where the relays and computer are located.
The relays click and apply power to a transfer case motor.
The motor attempts to turn a shaft that engages the front drive shaft.
When the computer thinks the shaft has NOT turned it tries again.
It will try three times then quit, figuring the shaft has not turned.
Get someone to crawl under the vehicle and engage the 4WD (just turn on the ignition- do not start the engine) See if they can hear the motor attempt to turn the shaft, it will make a clicking sound.
If not the connections or the motor may be bad.
I have found the most probable cause is the relays on the control board.
If you are technically adept --
you can remove the small side panel from behind the drivers seat and remove the control board. (remove the power plugs first)
Clean the relay contacts and bend them a little to give them more 'wipe' to keep them clean longer.
Put it back in and turn on the ignition.
Then push the RESET button on the side of the board.
Try the in / out 4WD a couple of times. If it doesn't work turn off the ignition, turn it back on and push the reset button again.
Oct 16, 2008 | 1989 Ford Bronco II
Is there a reset? VS-60803
menu -1-3-7-0
then inital
then enter
DO NOT DO THE E2 RESET!!!!
Let me know if you need more help
Tim nolan
Sep 17, 2008 | Mitsubishi VS-60803 60" Rear Projection...
Mitsubishi WT-42311
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
and or the
convergence IC's (STK392-110) had failed and caused a diode (D522) to short
out.
If Q5A00 check bad there are other parts that have to be checked or
replaced.
Dec 02, 2007 | Mitsubishi WT-42311 42" Rear Projection...
WS-55807 doesn't power on
1) Check all fuse devices in power supply
2)Pc board with transformer possibly defective.............T.
Nov 07, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi vs-60803
greetings from belize take your set to a tech and have him look at it.good luck.
Mar 23, 2007 | Mitsubishi VS-60803 60" Rear Projection...
Push Power button, green light goes on for a few seconds then nothing....
I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
