Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
16hp B&S ohv runs for 30min under load then stops 5min cool off starts runs 30 min new coil plug gas is venting adj valves
  • 112 Answers
Could be fuel vaporising.... re rout the fuel line away from heat sources this may help or the fuel is not getting to the carby fast enough....check fuel filter and lines for cleanness .
Posted on Jul 24, 2010
Will not start. but if I pour gas in carburetor it will. stop after the gas is burn of carburetor
Could be that the needle is stuck in carb, or else the fuel pump diaphragm is bad. Check the pump, thats what I would check first.
Jan 24, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
22 hp ohv misses under load comp.ok valve adj.ok spark,fuel,air,ok w.t.h.
really sounds like a carb problem if it only starts acting up under load
Aug 30, 2012 | Briggs & Stratton Briggs Stratton Intek V...
B&S Model: 303447-1078-31 16hp stops running after warm-up
bad coil it will seem like a fuel issue and the spark will look fine threw the spark plug but with a real spark tester you will see it is a yellow spark instead of blue replace coil and thank me
Jul 04, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I read the guys problem with his Cub Cadet running and then stalling out. Here is my problem with my lawn tractor; I have an older model 125, runs great but stops running after about 30 min. when it...
My name is Dane and I am going to help you solve your problem.
Run your mower again and when it starts to run rough, loosen your gas cap. If it runs right again, you have a stopped up gas tank vent. clean it or replace the cap. Could be a bad coil too. I hope I've helped! Thank you! Dane
Dec 28, 2010 | Garden
02 FLHRCI 95 kit, andrews cams, adj. pushrods, new lifters, drag pipes. Bike runs good when cold but after approx. 30 min. it starts missing on occasion. As long as I am asking for more fuel, it seems to...
Hi Okie41, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the negative cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below.
Good luck and have nice day.
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Aug 19, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
16hp b&s runs for 30 min or so and stops like it is out of gas. Yes the gas cap is lose and vent is not cloged
Its probably the fuel solenoid on the bottom of the float bowl. Remove it and replace with a float bowl bowl plug. You can leave the connector unpluged.
Jul 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine starts and runs,mows for 30 min then chokes
i had the same problem i talked to a repair shop and they said the coil was going bad and when it heats up there is a short in it (follow the spark plug wire back to the motor and the coil is there ) i replaced the coil pack and problem solved, hope this helps.
May 14, 2010 | Garden
Stihl 55 blower runs 5min. and quits /cool 5 min. and runs aga
running the right fuel mixture for the unit if not it could have to much oil & fouling out the plug or not enough oil & getting to hot & melting the piston ring & piston the only other thing is the carb adustments
Nov 10, 2009 | Garden
17hp b/s intek OHV after 30 min mowing starts running rough
if gas is in the oil the needle and seat in the carb are bad or some thing in it. the gas will go in to the crank case and load the cylinder with gas. you can take the carb apart to see if something is in the seat. or replace the carb
Jul 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
361 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
