Home | Sony | SNC-RZ30N Network Camera | Unable to detect the cam...
Sony SNC-RZ30N Network Camera
Problem for Sony SNC-RZ30N Network Camera
Unable to detect the camera
By sval on Apr 22, 2008
I am not able to detect the camera (when connected in my LAN using a regular Ethernet cable) using IP setup program. I tried also to connect it with a cross cable directly to my computer and I used ARP commands. Nothing.
Could be the camera network interface not working? Whenever I plug the camera in my network, the Network LED on front of the camera doesn't turn on although at the other end (router, switch) the port LED turned on. The camera power LED is OK (is on).
Thanks
Clarification Request
Posted by dmckinley on Nov 14, 2008
Reset to Factory
From Sony Support
Unplug power
Hold in reset button (beside power input)
Plug the Camera back in
**Count to 5**
Let out reset button.
Note:
Did not work for me.
Posted by csnowak on Sep 16, 2008
The web server from the camera is not functioning anymore as well. My browser says the page cannot be found. No network lights on the camera or the switch.
Please advise
Same Problem
Nov 14, 2008
-   Exact same issue as first post. ANY FIX OUT THERE?
-   dmckinley
Sep 16, 2008
-   The cameras seem to have disappeared from my network. The network light does not light anymore and I cannot see or control the camera. Resetting my Ethernet switch and the camera does not solve the issue. The cameras have worked for quite a while and then they were gone.
Maybe there is a firmware upgrade needed?
Please advise-   csnowak
May 17, 2008
-   having the same problem it worked for a while now power light is on but no network light. Network switch shows activity on that port.-   cj81bu
Solution #1
posted on May 27, 2008
Somewhat Helpful)
bitdegenerat
Rank: Apprentice
Rating: 75%, 1 votes
try to reset the camera at the factory default and then use ip setup program
Was this helpful?
Yes
No
Solution #2
posted on Oct 09, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I recently set up my camera with a Kyocera KR2 router with a static IP air card. I can pull the camera using the two laptops I used to set up the system but not on any other computer. I cleared all cookies, history etc. to make sure it wasn't something simple like that. Any ideas what would be causing this?
Popular Solutions for Sony SNC-RZ30N Network Camera
Questions and Unsolved Problems for Sony SNC-RZ30N Network Camera
Do you recommend Sony SNC-RZ30N Network Camera?
Answer
Answer
Camera is connected to internet and to video mixer - camera control via browser works fine - but I... (More)
Answer
can't see camera with internet explorer verion 7 or higher
Answer
can not send mail through isp for sncrz30 There is no option to add user and pass that the isp... (More)
Answer
no power light, power supply ok
Answer
Actually it's a Sony SNC-RZ25P. Anyway it does not seem to be able to send e-mails through the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony SNC-RZ30N Network Camera:
Top Web Camera Experts
Rank: Guru Guru
Solutions: 14051
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Web Camera Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
