Question about MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard (7592-030R)
Hi: from: tedlessley@earthlink.net please help. my new msi g41tm-e43 board with windows 7 was operating well for several weeks. suddenly, the power on button would not cause the system to power up -- no boot at all. i replaced the 500 watt cooler master power supply with a new one -- pretested successfully -- did not solve the problem. tried pushing the power on button multiple times -- no good. tried shorting pins 6-8 on the front panel connect socket repeatedly -- nothing happened -- except a momentary 1 second response from the cooling fans.
  • tedlessley Jul 22, 2010
    hi:
    i trust that you will have the previous correspondence on my failure to power up from the front panel button.
    if not, my discussion was with "hbristol173" of your group.
    i do not have another cpu to substitute as suggested finally by hbristol173 to determine whether the problem is with the cpu or the motherboard.
    i'm still wondering about a bios problem.
    is this situation fixable by clearing the cmos?
    ted
    1600: 22 july 2010
    President:
  • 2,030 Answers
The board is bad...especially if you shorted pins 6-8 and got no power up.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Jul 22, 2010
    President:
  • 567 Answers
Hello thanks for asking,there are several reasons that can cause this problem,you should try plug your computer into a different wall outlet the present one may have a fault,{2) you can try using a different power cable the one use can be faulty,(3) you can check the connections to the motherboard tho make sure they are correct , the power connector and the 4 pin connector which power the CPU. Try these solutions and let me know if any work
  • 2 more comments
    hi hbristol173:
    thanks for your response.
    1 & 2. i tried two different ac power cables.
    i plugged the new one and a good old one into different ports of my power strip and also separately plugged them straight into the ac wall socket. no change except a momentary bump in the fans again.
    3. i disconnected the 20 pin and its 4 pin and then reinserted both of them solidly into the motherboard socket. correct wire colors were verified.
    also disconnected the cpu 12v 4pin and substituted the associated second 12v 4pin in its cable pack into its place.
    to go further, i disconnected all the front panel wires from the motherboard and inserted only the power on connector. no result at all.
    please continue.
    ted
    1500: 22 july 2010
    hbristol173:
    another step.
    again, i tried shorting pins 6-8, the power on button pins on the motherboard connector , but this did not produce any result.
    maybe this a problem with my new msi g41tm-e43 motherboard.
    maybe, a bios code problem?
    with no power up, i can't get to the bios.
    ted
    1510: 22 july 2010
  • Hilton Bristol Jul 22, 2010
    Thanks for the reply the problem is with the motherboard or the CPU if you have another CPU you can put it on the motherboard to see if it will work, if it does that mean its the PRESENT CPU if it don't work this mean its the motherboard. But you don't have another CPU you can take the motherboard and let someone test it for you.
    This problem has nothing to do with th BIOS its a power problem which can be cause by a dead motherboard or dead CPU you already try the other solutions and the problem still exist, the and the only way to determine the problem another CPU or another motherboard is needed. Otherwise your power button on the case is dead or you did not make the right connection on the motherboard, thats my solutions other than these i am out of ideas.
    Thank you
Audio bus driver
Go to the intel site. They have these audio drivers for all intel motherboards.
Mar 03, 2014 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
880GM-E43. Worked without a problem for around 2 weeks. All of a sudden it will not power on, no indicator light on the motherboard. Replaced the PSU thinking that it was the problem, didn't...
I'd have to agree; bad power regulator on the motherboard.
The board is getting some power (3-5v) since the CPU fans move, but it's not getting the 12v it needs to power the processor, RAM, etc. (No onboard power LED). Sorry for the bad news!
Jun 29, 2011 | MSI 880GME43 Motherboard
My installation CD of the motherboard was lost, unable to install the motherboard drivers with the internet but could not install the drivers for audio and video. I'm no sound and the videos do not...
look in msi site http://www.msi.com/product/mb/G41TM-E43.html for the drivers. or ypu just download the newer version of the motherboard in msi for the compatability of the devices
Mar 22, 2011 | EliteGroup G41TM (V10) (G41TM(10))...
No DVI signal on G41TM-E43
Download the driver from here:
http://www.msi.com/product/mb/G41TM-E43.html#/?div=Driver&os=Win7%2064
Please select your windows system 32 or 64 bit.
Download the vga driver and unzip the file.
Uninstall the old one before you install the new.
Check also your bios for the graphic settings.
My advice is to buy a better graphic card to insert in the pci-e socket instead of using the onboard graphic for better performance.
Good luck
Feb 04, 2011 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
'where can i find webcam software for msi cr400'' so i can take pictures and record without logging onto the net?
I think you mean you need the drivers for your MSI CR400 Webcam. You can find them here:
http://downloadnew.org/software/driver-webcam-msi-cr400-windows-7/
Please write back to me if this isn't what you want but I hope this was helpful
Nov 02, 2010 | Computers & Internet
G41tm-e43 + windows 7:
just install ur orignal window 7 driver for ur motherboard
http://www.msi.com/index.php?func=proddesc&prod_no=1791
follow this link
Mar 06, 2010 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
I have had a motherboard failure the MS-7357 (V1.X) Mainboard... needing upgrade thinking of the MSI G41TM-E43 LGA 775 Intel G41 will i have to mess arround with the power switches with the case as this...
Boards don't come with switches. The problem with company made computers is that they get a manufacturer to make a board especially for the case they make. They do this to specifically stop you doing what you are trying to do, upgrade a machine with a proprietary board in THEIR case. You will find trouble at the rear of the machine getting to sockets and plugs.
It is far better to buy a good case, and then you can swap out components with ease. The case that held my Asus boarded P4 with the first SATA drives now has an Asus Quad Core in it with SATA 2.
MSI G41TM E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard Newegg ca
I would contact MSI direct
G41TM E43 MSI Global
Some of this might be useful
G33M - MSI
https://www.msi.com/Motherboard/G33M.html
... the app from the MSI website. Features - Automatically Detect the BIOS/Driver/VGA/Utility Update - Support Microsoft Windows XP/Vista/7 32/64bit. featurePic ...
::UPGRADE:: G33M (MS-7357) - new processor and RAM - MSI Forum
https://forum-en.msi.com/index.php?topic=125215.0 Mar 11, 2009 - 6 posts - ‎2 authors
The motherboard is a G33M (MS-7357) and has a piddly 1.6ghz processor and 1gb of generic RAM. I'm running Windows XP Home.
CPU-Upgrade: MSI G33M (MS-7357) processor support and ...
www.cpu-upgrade.com > MSI Nov 28, 2010 - MSI G33M (MS-7357) motherboard specifications ... FSB 200 MHz, L2 512 KB, TDP 35 Watt, Conroe-L, Rev A1, SSpec SL9XP, 7357v10.zip.
UserBenchmark: MSI G33M (MS-7357) Compatible Builds
www.userbenchmark.com/System/MSI-G33M-MS-7357/450 Compatible Components (from 7 PCs). Popular components in PC builds with the MSI G33M (MS-7357) Motherboard. CPU. Core2 Quad Q6600Intel $190Bench ...
Oct 21, 2017 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
New build turned on power no beeps no video nothing but fans
make sure that your little speaker is plugged in to the correct pins. This gets many people every time. If the speaker isn't plugged into the correct slot you're definitely not going to get anything to work...yeah i know...a silly speaker...you can have quite a few things plugged incorrectly and things will still work but if you have the speaker plugged into the wrong one...then ur dead in the water...find the little cylindrical speaker and try plugging it into a different slot...really look on that board for it. Should be labeled JFP2..connect the speaker to the 4 pin side of that 7 pin connection.
Dec 21, 2009 | MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro...
MSI G41TM-E43 LGA 775 Intel G41 HDMI Micro ATX Intel Motherboard (7592-030R) Logo
47 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
