Question about HP Compaq Business Desktop dx2200 - P4 524 3.06 GHz (S6104464)
My hp compaq dx 2200 microtorre don't start i press the power button and the front led come on but the back fan speed out and his dont't do nothing.
SOURCE: HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
5 blinks 1 second apart No memory
6 blinks 1 second apart No graphics
7 blinks 1 second apart System board failure (detected prior to video)
8 blinks 1 second apart Invalid ROM
Posted on Nov 19, 2007
SOURCE: HP Compaq D530 sff Will not power up
I have the same problem but it seems to be related to the NIC. When I start without the ethernet cable plugged in it's fine, plug in the ethernet cable and the machine stops dead. I can't even start the PC with the cable plugged in.
Posted on Mar 05, 2008
ndguy2481
  • 251 Answers
SOURCE: CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
there is no way it depends on ur processor if it is getting hot it might have to stay high to cool it
Posted on Dec 01, 2008
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Posted on Feb 10, 2009
My compaq presario 2200 wont boot up...when i press the on/off switch without the a/c charger (battery alone), the amber led flashes twice....if i plug the charger in with the battery, the led blinks once...
If the computer is not turning on, there is a big chance of hardware failure and normally there is no easy fix for this rather than a motherboard replacement.
May 03, 2011 | HP Compaq Presario 2200 Notebook
When I press the switch button the power led comes up but nothing shows on the screen, the cpu fan rolls for few few seconds and stops
try to do a power drain.... unplug the power chord... then remove the battery.... while the battery is out... press and hold the power button for 30 seconds.... then put the battery back in and then the power chord.... then try booting it up.... if it works well and good.... if it does not and u see all the lights but not anything on the screen, try with an external monitor just to check if its an issue with the lcd screen.... if its working on a different monitor, u know what to do... take it to a service center....
again if nothing works... dont wait.. take it to a service center
Mar 18, 2011 | HP Compaq nc6000 Notebook
My "hp pavilion a220n" won't
Check all wires for loose connections--- if the memory was wrong or something, it would still attempt to boot but stop during the POST and start to beep
Dec 23, 2010 | HP Pavilion a220n (DK218A#ABA) PC Desktop
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
Resons why the hp DC5100 desktop will not start up when pressing the power button. I press the power button but none of the led's light up and the desktop doesn't start up. There is no fan noise either....
The first you need to do is remove the power cable to your Motherboard and back it again. If doesn't work , replace power supply, still not, replace motherboard
Jul 17, 2009 | HP Compaq dc5100 Small Form Factor PC...
DC5100 want start up
You need to replace the power supply, a fairly common problem.
Jul 17, 2009 | HP Compaq dc5100 PC Desktop
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Jul 14, 2009 | HP Compaq Presario F500 F700 and G6000...
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Compaq Presario SR1000 desktop boot up problem
nothing to do with the ram ... this motherboard sometimes locks, ( dont ask me why) but if you take out the power cord for 5-10 minutes and then press and hold the front power button on the machine (about 10 seconds) it will reset the board. Plug in the power cord and the basic items, sound, video etc ( some usb devices tend to stop it booting to) boot into windows. Then add the rest of your usb devices ..
Mar 23, 2008 | Computers & Internet
Presario 2200 Notebook won't power up
try disconnect power then remove battery,plug power back in and try to boot.if nothing happens put battery back in and see if it charges.if it does leave to charge for a while,try to boot if it dont boot you know its neither the power or battery and shouldnt cost too much to repair(probably a capacitor dead , possibly transistor blown diodes only allow electricity to travel in one dirrection so only break if shock(drop or bang hard) resisters have about a 100yr life.
Feb 22, 2008 | HP Compaq Presario 2200 Notebook
HP Compaq Business Desktop dx2200 - P4 524 3.06 GHz (S6104464) Logo
184 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
