Question about Vacuums
Black and Decker dustbuster is not working . - Vacuums
    President:
  • 1,099 Answers
Take out the handle from the bag housing and use your volt meter/circuit tester to test the main switch, if that and your power cord are good, then you might have a bad fuse, which is located on the brush side of the main chip board.
Bad cord or plug - number one electrical problem due to the abuse that these endure. Vacuum cleaners are often dragged around and even up and down stairs by their tails. Not surprisingly, the wires inside eventually break. Test with a continuity checker or ohmmeter. Squeezing or bending the cord at the plug or vacuum end may permit a momentary spurt of operation (do this with it plugged in and turned on) to confirm this diagnosis.
2. Bad power switch - unplug the vacuum and test with a continuity checker or ohmmeter. If jiggling the switch results in erratic operation, a new one will be required as well.
3. Bad interlocks or sensors - some high tech vacuum cleaners have air flow and bag filled sensors which may go bad or get bent or damaged. Some of these can be tested easily with an ohmmeter but the newest computer controlled vacuum cleaners may be more appropriate to be repaired by a computer technician!
4. Bad motor - not as common as one might think. However, worn carbon brushes or dirt wedged in and preventing proper contact is possible. See the section: " Problems with universal motors".
5. Bad internal wiring - not likely but always a possibility.
Hope this helpout , Good luck...
Posted on Jul 22, 2010
How old are these dustbusters
The Black & Decker DustBuster (now stylized as DUSTBUSTER) is a cordless vacuum cleaner that was introduced in January 1979.
Mark Proett and Carroll Gantz are listed as the inventors on the utility and design patents, respectively, assigned to Black & Decker for a cordless vacuum cleaner.
If you want to get some other insformation, please be more specificabout your question
Nov 08, 2015 | Vacuums
Can I fix model cwv363004 black &decker
Hi-
This dustbuster does not have internal parts still available to replace. This model currently still has the filter, wet deflector and crevice tool available. If you would like to locate a service center for further information you can follow the link to find your nearest service center. blackanddecker com
Thanks
Black + Decker Customer Care
Feb 21, 2015 | Black & Decker 15.6 Volt DustBuster Vacuum
Our black and decker 14.4 Dustbuster is functioning but the charger does not shot its light that will indicate of charging. we dont know if the charger is not working or just the charge light is the one...
You can test the output of the charger with a multimeter. Set it at about the 20v scale and touch the contacts at point where it connects with the Dustbuster. If you get a reading it means that the charger is working. I would say that the charger is most likely not working because LED indicators very seldom fail while chargers are not all that reliable.
Jun 09, 2011 | Black & Decker Vacuums
How long do i have to charge a dustbuster? I purchased one at a garage sale and it does not seem to be working. The owner said that it was working..
if its not working at all it has a fault that could be anywere if it is working but with little suction then the batery is no good replace the battery
Jun 25, 2010 | Black & Decker AV1200 DustBuster Handheld...
What is the "wheel" on the side of the dustbuster for? what position should it be in?
The wheel is the pivot and cover for the filters. It opens up to show the filters behind for cleaning.
Mar 11, 2010 | Black & Decker AV1200 DustBuster Handheld...
User manual needed.
Black and Decker website offers product manuals. Also, various online vendors provided information I needed about DustBuster in product description, making it unecessary to purchase manual.
Sep 10, 2009 | Black & Decker V9660 DustBuster Handheld...
Charging Black & Decker Dustbuster
Leave it in the charger for at least 7 hours and then try and see if it works on a full performance time of roughly 3 minutes.
Feb 04, 2009 | Black & Decker V9650 DustBuster Handheld...
How do I open the dustbuster to clean out the end
There should be an area to press at the joint between the front section, and the motor section. The whole front cone comes off to empty the contents, and there is a filter - but no bag with these.
Hope this helps you.
Thanks for using Fixya
Dec 26, 2008 | Black & Decker V9650 DustBuster Handheld...
REPLACEMENT FILTERS
I suggest calling customer service.
http://www.blackanddecker.com/CustomerCenter/
Incidentally, the model number you gave is a 3.6 volt vacuum.
Dec 15, 2007 | Black & Decker CWV3630 DustBuster Wet/Dry...
Vacuums Logo
13 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
