Question about Heat Controller Thru-Wall/Window Air Conditioner
My wall unit is leaking in my outside walls .and it doesnt have a drain on the back of the unit.
  • 744 Answers
I hear about this problem a lot. The most likely cause is that the unit isn't tipped toward the outside of the building and/or the drain holes in the pan are plugged. Also, it's important to keep an A/C unit clean. It should be cleaned at least annually to ensure that the pan isn't dirty, the coils are clean, and that the fans and filters aren't caked up.
Posted on Jul 23, 2010
It is leaking
The drain line located in the back of the freezer section has clogged. Some drain lines are located on the outside of unit. If drain line is outside of unit, disconnect line, use a shop vac and place it over the connector and suck out debris. Then blow out the drain line, then connect drain line. If drain line is not visible on the outside of unit and there is no visible drain inside of freezer,, remover all food from freezer, remove the back wall in freezer section. You should see a drain in the middle, back of the freezer, Use sop vac and remove debris. If you don't have a shop vac, you can use a long straw, wrap tape around end to make a tight fit and blow out the debris.
May 16, 2016 | Freezers
Friedrich quiet master KS12L10 leaking water down outside wall and windowsill.
it may need coil cleaned. there is a drain hole under evaporator coil that might be stopped up.
Aug 12, 2014 | Friedrich QuietMaster RS10J10 Air...
Where is the drain pipe on my a/c? Ruud #UBHC-21J11SFC. Do I have to take something apart? The pan under unit fills up and overflows. It is leaking through the ceiling under the unit. I am a woman. ...
The drain or drain piping (usually PVC piping) is under or on the edge of the drain pan, under the unit. It has to exit outside some where. Either down thru the wall into the crawl space and out thru the foundation wall. Or thru the attic to a gutter outside on the edge of the soffett. Look for white PVC piping outside the house where I indicated. Then you can use a garden hose and high pressure to unclog it from at it's termination point, by back flushing it.
Hope this helps you. Please let me know. Thanks
Jun 19, 2011 | Ruud UBHC Air Conditioner
BTU is leaking water from the inside.
Take the cover off the inside unit and look for the drip pan under the evaporator coil. It should have either one drain in the middle of the pan or a series of smaller drains along the back of the pan. The drain(s) is probably clogged up and causing the pan to overflow into your home. Also check the drain line on the outside wall where the refrigerant lines come through the wall for a blockage.
Jun 14, 2011 | Sanyo 09KHS51 Ductless Mini Split Air...
Leaking inside house , condensation or something causing liquid to leak inside house and i have to use towels to catch fluid
Should have a drain hole on back to drain outside it maybe pluged or unit is not leveled to outside has to have a slight tilt for water to drain out not in.
Jul 11, 2010 | Sunbeam SAW10CR1FHU Thru-Wall/Window Air...
My onida split ac leaks water down the wall.how to fix it?
check to see if the drain to outside or your condensate pump is blocked with dirt, lift the unit off the wall and make sure the drain hose is correctly attached in the back of the drip tray. also ensure the unit is level using a spirit level.
cheers
Jul 03, 2010 | Heating & Cooling
Leaking water from underneath.
Hello my name is Heath it will be my pleasure to assist you. The drain should be in the back of the unit outside . If you lean the air conditoner slightly toward the outside it should drain outside.
Jun 28, 2010 | Frigidaire FAA084P7 Thru-Wall/Window Air...
Wall a/c is leaking water down log wall and puddling on floor.
When you sealed the holes outside, you trapped the water inside. The unit is designed to let the water run to the bottom of the pan and then go out the holes outside. Try unplugging one of them and see if that fixes the problem. Hope this helps.
Jun 24, 2009 | Emerson Heating & Cooling
A/C unit leaked out of front
pull out the unit and make sure the drainage is not clogged with slime and dirt. there is a drainage from the front to the rear. clean it before putting it back and tilt it a little bit towards the back too as you return i in place..
i hope i was able to fix your problem...
pls rate me..
tnx,
drcool
Jul 22, 2008 | Friedrich CP12C10 Wall/Window Air...
Heat Controller  Thru-Wall/Window Air Conditioner Logo
181 people viewed this question
Top Heat Controller Heating & Cooling Experts
JonSnell Electronic
JonSnell Electronic
Henry S
Tom Chichester
Are you a Heat Controller Heating and Cooling Expert? Answer questions, earn points and help others
