Question about Paragon Amf 7008-00 Timer 7 Day 120 Volt Timing Motor
Where can I get 2 timer pins and 2 timer pin stops for an amf Paragon 120v 60hz smimming pool 7 day timer
  • 52 Answers
Looking for set of trippers for paragon 4014-20 pool timer
Copy following link to identify timer:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
Paragon 4000 series uses X2772 tripper
Paragon is no longer making timers except for defrost times.
There is a new line of timers coming from China that looks identical to Paragon 4000, and uses same tripper. As a result this timer design and trippers could be around for years to come.
Replacement timer is Intermatic T104R 240Volt indoor outdoor enclosure, with replacement parts widely available
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Add a comment
Apr 03, 2013 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Need trippers for older unknown model number amf paragon pool timer. timer is 15 - 20 years old
Paragon no longer makes timers or parts, except defrost timers.
Typically, defrost timers are not used for pools.
Open following link to possibly identify timer and tripper part number.
If you want a new timer for pools, Intermatic makes the T101 120Volt and T104 240Volt:
If you want T100 series timer with fireman's switch that turns off heater 10 minutes before turning off pump:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#pool
If you have energy-saving 2-speed pool pump, and thermostat and pool light, then buy P1353 digital timer with enclosure. Enclosure and timer sold together as P1353ME.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#P1353
http://waterheatertimer.org/pdf/PE100-series-with-P1353-timer.pdf
P1353 is not easy to wire or program for novice, so you can add a comment or repost question on fixya and I will catch it.
Jul 21, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
I need to order parts. I believe they are timer pins, but not sure. I cannot find a picture to verify that's what I need.
If I understand you correctly, these are the movable / adjustable parts that are placed and secured at the time of day an "on" and "off" operation is to be performed. Most brands of timers use two similar yet different types of trippers. One type performs an "on" function and another performs the "off" functions. They may be color coded or have some other distinguishing mark to differentiate between the two function types. The AMF Paragon 7008-00 uses black and silver to indicated off and on, respectively.
There are several terms used for these parts; "trippers" or "dogs" are the most common - but there are others. Some people even combine the two above to something like "trip dogs" too. Of course, timer pins also convey the part that you're speaking of just as well.
A larger picture with the black and silver trippers installed can be seen easily below:
I hope this helps - please rate this reply - thanks!
Dec 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
The 120 volt power for the timer motor has two terminals. One if labled M the other is labled T. Which one is the hot and which one is the neutral? Thanks
There are a lot of timers out there.
Add a comment with brand and model number to give us a shot at finding the information.
You posted under paragon 7008-00 timer
7008 is 120V timer with 120V clock motor
Power lines connect to Terminals A and B
Going through Paragon timers, I don't see terminals M and T
Looking at Tork timers, I dont see terminals M and T:
http://waterheatertimer.org/Tork-timers-and-manuals.html
Looking at GE timers, I don't see M and T
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
Woods timers, Sylavania timers don't have M and T
Intermatic makes more timers than I can go through in one night, but I don't recall M and T terminals.
Nov 19, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Where do I get a replacement motor for the 7008-00?
Intermatic clock motors are everywhere, but Paragon and Tork clock motors are a mystery.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
Shows manuals and resources
According to Paragon accessory chart:
http://www.paragontimecontrols.com/parts_accessories.htm
7000 series 240V clock motor M3193-71
7000 series 120V clock motor M3099-00
7008-00 is listed as 120V clock motor
http://waterheatertimer.org/pdf/Paragon-7000-series-manual.pdf
I cannot find M3099 120V clock motor on internet
Now Paragon has contact-us page for customer service:
http://www.paragontimecontrols.com/contact/default.aspx
I will also contact Paragon, and post results here if Paragon responds.
Nov 17, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
AMF Model No. 7008-00 How do I know if it is working or not. Where can I get more Pins to stop the bld everyday at 5pm.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Paragon 7008-00 timer parts:
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
We have an AMF Paragon 4001 timer for the light outside our building. The light goes on lately at the wrong time. We want it to be on at 7:00pm and off and 5:00am but it goes on at 12:00 at noon.
To set paragon timer: Pull large round dial straight out towards you, then rotate dial until correct time is lined up with stationary 'pointer' on front of dial
Sep 08, 2010 | Paragon 4001-0G Defrost Timer
I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Jan 14, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Paragon Amf  7008-00 Timer 7 Day 120 Volt Timing Motor Logo
217 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
jdthefixer
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
