Question about Homelite Garden
Versitool How to remove clutch assembly on Homelite Versitool
3 Suggested Answers
  • 420 Answers
SOURCE: How to remove clutch on model z830sb
The clutch interior must be turned the same direction as the engine to loosen (reverse threads), tapping with a screwdriver and hammer usually does the trick. When you install the new clutch make sure you apply an anti seizing compound to the threads.
Posted on May 26, 2009
  • 420 Answers
SOURCE: Housing removal outside the Homelite clutch
You must first remove the rear housing, then the shaft to access the clutch area.
Posted on May 27, 2009
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Homelite hlt25cs, pull starter cord, wont engage starter clutch, cant find how to access it
hello sir, ryobi trimmers and other models removal of the bell housing,removal of the metal bell housing,or clutch drum, on models 780R & 790R, here is what you do. after removing the trimmer & shaft assembly.remove the spark plug insert a screwdriver in the cylinder to keep piston from moveing. to remove the bell housing twist off the spring and using a T20 TORX screwdriver unscrew the retaining screw in the center of the bell housing (normal r/h thread) . push down firmely try not to strip screw head . you should be able to remove clutch housing.remove clutch using a pair of channel locks,works for me, (normal r/h thread) you should be able to remove front engine cover to repair what you need to.coil,pull stsrt, hope this works,. this solution applies to all trimmers with clutch removal~~~hope this helps,,any comments welcome,thank you. ``
Feb 02, 2012 | Homelite Garden
Removing clutch and replacing with new clutch. How do you remove the clutch?
first you need to remove the cover where the chain goes, then there is a clip to remove the clutch bell(thats the wheel looking thing that the chain is driven by)then there may be a nut that will allow you to remove the clutch pack...sometimes the clutch pack will unscrew of the crankshaft..depending on model..then replace and re-assemble in reverse order
May 20, 2011 | Homelite Garden
Chain dies under light load, engine running ok
It sounds as though you have abraded away the clutch face. I’d try a local saw seller/mechanic, they may be able to adhere a new face to your existing parts.
I went here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Chose “38cc 16" Chain Saw UT-10927” and on the “Clutch – Chain Brake – Drive Case Cover” detail found; item 20, clutch, pn984894001, $15.47; item 21, sprocket and drum assembly, pn984640001, $18.46
Yours is an inboard clutch but it must be removed, the outboard clutch video will help.
R² Drive Link Inboard Clutch
http://www.youtube.com/watch?v=YUbSIHMSSP8&feature=PlayList&p=4A4A1DF66590854E&index=0&playnext=1
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Oct 09, 2009 | Homelite Garden
Homelite st 155 pull cord wont pull out on my weed trimmer
this works by a spring, and there are 4 bearings in a clutch that help it to engage. Through wear and tear this can get to where it just doesn't work well anymore and needs cleaned. Remove the four screws that attach the motor to the clutch assembly. This will give access to the pull cord. Remove and be careful for the spring likes to shoot out when you remove the 4 tabs that hold the spool in. Clean, lubricate, reinstall, and you should be back to trimming.
Jul 06, 2009 | Garden
May 26, 2009 | Homelite Garden
Replace recoil starter for Homelite trimmer Model UT21546
My UT21546 has 2 springs, the regular recoil one and a what I'll call a anti kickback one. the top of the anti kickback spring kept coming unsecured and finally I just deleated it alltogther and screwed the 2 plates tightly togehter and the near new unit works better than new now.
Apr 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mightylite String Trimmer Piston removal
Homelite shows the short block assy ($84.02) but no breakdown of the top end. I've never taken one apart, not cost effective. Here's the link to their parts site. Have the UT number available
http://www.homelite.com/service_support/order_parts
Apr 10, 2009 | Garden
Garden Logo
70 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
