Question about RCA P60828 TV
Convergence problem on 60 inch rear projection RCA
My RCA rear projection TV has worked well just before vacation. I came back, turned it on and found that it blew the main fuse on the AC (5 amp). Replacement of the fuse allowed the tv to come on, but the convergence is off. Voltages from the convergence power supply board are incorrect.
Any ideas?
Here is what the picture looks like
http://img.photobucket.com/albums/v384/eganders/60inchConvergence100_1203.jpg
Background:
The TV has a chassis number of PTK195AC and is model P60812BL
I went into the service mode using the front panel as the service manual
describes. There were no error codes in P1 through P3.
I checked the voltages out of J19701 connector from the power supply to the convergence board. They are not to specification (at all).
pin 1 should be -45, is -1.8
pin 2 should be -15, is -1.9
pin 3 gnd
pin 4 should be +23, is +23.3
pin 5 should be +15, is 0
pin 6 should be -45, is 1.7
If the plug is pulled going to P19304, all the voltages go to 0 volts at J19701 on the power supply board. The service manual says to "disconnect power supply". I took that to mean pull J19701. I assume that the power board is bad. My question is..
Was the board blown by the load of something wrong on the convergence board, or just a bad component. I checked the input diode bridge and it seems to be OK. I would guess I should replace the power supply board. I wonder how much that is? I would hate to blow it after changing it out. What are the chances of that? I know that this TV has a coolant problem where the coolant gets on the boards. I see no evidence of this, but I know that some residue may be there and not seen. I blew off the dust and there is no greasy contamination that I see.
Can anyone tell me
1. What typically goes wrong when the main fuse blows and the picture
goes out of convergence
2. How do you get into the built-in geometric alignment grid pattern?
I would like to nurse this TV along for a while. It has given good
service and I have no reason to replace it other than the present
problem. I really don't want to get into it deeply. For example, I
would prefer NOT to get a chipper checker or have to hook an
oscilloscope to it.
  • 2 more comments
  • eganders Apr 22, 2008
    Do you think my problem is strictly on the power supply board, or is it possible that the problem extends to the convergence board also? As you can see in my above post, the power supply board has no voltages when it is unplugged from the convergence board and only 1 voltage (+23 volts) on pin 4. I expect that I will have to get a TV tech involved, but I want to be pretty sure of the answer before I do. The last time (2 1/2 yrs ago) the tech was not able to fix my problem (turned out to be contamination on the boards, probably from the coolant that I fixed myself). Do you have an estimate of what the cost would be to have a tech fix this? How do I judge a good, knowledgeable tech?
    Thanks for the information. Since purchasing parts and probably quite a bit of effort will be involved in working this problem, i have taken it to a TV repair shop. They can probably resolve the problem faster than I could as long as it is straight forward. The fellow I took it to seems competent, so I will let him take it on.
    Thanks again. I think some of the info that you gave me should help him.
  • eganders Apr 26, 2008
    I took the TV chassis to a local repair shop and they fixed it by replacing the STK regulator chip in the convergence power supply. So far, so good. Looks beautiful again.
I have a rca 52 inch projectin t.v and the power light turns on then off 3 times then it won't turn back on
Posted on Mar 18, 2009
  • 2,326 Answers
The likely cause of this failure is the convergence ICs got shorted and for sure It damage the pico/micro fuses and some of the fuse resistors nearby the STK ICs.
You do not need the chipper checker thingy for now until you can correct the voltage issue.
I would suggest to remove the convergence ICs first and check for the other possible blown parts.
I could indicate where the parts are but I do not have the service manual.
Let me know if you need further assistance.
Posted on Apr 22, 2008
  • Jaime Hernandez Apr 22, 2008
    The failure was cause by the convergence board ICs and for sure It damage the fuse resistors and fuses.
    The reason you get some voltage with the whole assembly connected is because there is power circulating through the circuit. Once you disconnect the J19701 connector, no power circulates.
    Check your power supply circuit and find all the fuses in there and check them for continuity. I'm sure you have blown fuses there.
    If you have the service manual, you can send it to me to guide you through the repair process.
I have a 60 inch RCA tv rear projection digital. the picture is like seeing 3 of everything. I have being able to fix this in the past by using the convergence option on the setup menu. but now the...
what it is the tvs like this are mento be serviced every 3 years or so the convergence settings are in the back only user ones are in the settings dont try this yourself though i broke mine lol it will cost 120 pounds tops to fix dont worry its worth it if this has helped please give me thumbs up because people are just taking answers and not voting
Jan 15, 2011 | RCA P60921 60" Rear Projection Television
Convergence issue-60 inch RCA projetion TV
it is under set up options in the menu
Oct 16, 2009 | Televison & Video
I have a phillips 60 inch hd rear projection television model number 60pw9363, i have recently replaced both convergence and the tv was working perfect for about 6 months, i went to turn on the set and a...
Whining noise sounds like the power supply in the TV ... not putting out the voltage it needs to project the image.... might have to consult with your TV repair
Sep 18, 2009 | Philips 60PW9363 60" Rear Projection...
I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets. Problem #1) Convergence Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pngSOLUTION http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 28, 2009 | Philips 60P8342 60" Rear Projection...
Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 10, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence board swap questions....
You can try to change it out and go to convergence adjustment mode on service mode to setup the template.
But I rather replace couple trans and leaky diode on your old convergence amp board to save my time
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
RCA P60828 TV Logo
709 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
