Question about Pioneer Audio Players & Recorders
Pioneer VSX 47TX receiver problem. Hi all, Recently, the pre/pro is acting up. Every time I switch it on, it goes somewhere else other than where it was the last time. For instance, I have it on 'DVD, Movie 7:1'. The next time it goes to 'VCR, 2 Channel' without touching it. (??) When I toggle select, descriptions are completely gone, ''Tape 1'' is spelled ''Rape 1'' and so forth. Also, the receiver is NOT imputing digital audio from any source. So, what gives? Is it something I can repair? Thanks
  • Pioneer Master
  • 5,615 Answers
At first I thought you might have some bad soldering. But on second thought it might be a control circuit problem. You would only have a good chance of fixing this yourself only if you had a very comprehensive service manual, I would have thought. So start searching for the Service Manual.
Posted on May 06, 2017
5 Suggested Answers
  • 14 Answers
SOURCE: Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Posted on Apr 02, 2008
dunnbiker
  • 8546 Answers
SOURCE: How to connect 901 equalizer to a Pioneer VSX 47TX
I have a VSX-36TX so this is how it's going to work...
You will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. However, the VSX 47TX doesn't provide power for a Subwoofer, should you decide to get one, so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
A separate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two avaailable channels on a 4-channel amp. The iterations are many. Have fun.
Posted on Apr 13, 2009
  • 4 Answers
SOURCE: HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Posted on Jul 13, 2009
SOURCE: Sound Just Stopped Working
I have the same problem with my 49txi, and I called pioneer and a repair shop as well. Both told me that the 49txi has a known problem with over heating and that its boards unsolder themselves. I would have thought Pioneer would stand behind something this expensive, but that was the old Pioneer in the 80s, and the new Pioneer says we are on our own.
Posted on Feb 02, 2010
How can I connect an analog turntable to my Pioneer VSX-D710S? Also, do I need a turntable with a built in pre-amp?
According to the specs there aren't any phono inputs which would have their own preamp. Everything else is line level so I'm pretty sure you'll need a preamp either between the turntable and one of the line level inputs or built into the turntable.
Mar 21, 2014 | Pioneer VSX-D710S Receiver
Hooking up phonograph to Pioneer VSX-D498
You'll need a phono pre amp and then you can connect to aux inputs.
http://www.google.com/search?q=phono+pre+amp&rlz=1C1CHMO_enUS514US515&aq=f&oq=phono+pre+amp&sourceid=chrome&ie=UTF-8#q=phono+pre+amp&hl=en&tbo=u&rlz=1C1CHMO_enUS514US515&source=univ&tbm=shop&sa=X&ei=Kv_2UMatJoOc9QSDr4CoAg&ved=0CGQQsxg&bav=on.2,or.r_gc.r_pw.r_qf.&bvm=bv.41018144,d.eWU&fp=a656d84bcd78ba72&biw=1360&bih=643
Jan 16, 2013 | Pioneer VSX-D498 Receiver
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
I have a Pioneer VSX-D411 and there is dsp ng flashing, what is it
http://www.retrevo.com/support/Pioneer-VSX-D411-Receivers-manual/id/385ci976/t/2/
I believe it's trying to tell you something is wrong with its digital sound processing.
This was the best source I could find on it:
http://www.avforums.com/forums/av-amplifiers-receivers/381823-problem-pio-vsx811s-no-sound-display-says-dsp-ng.html
If you switch it to satereo / direct and the light goes out I'd say that would clinch it.
Jan 15, 2011 | Pioneer VSX-D411 Receiver
How to install bose 901 eq to my pioneer vsx-1019ah-k
This works for all models of AV receivers when you want 901's as Front L&R speakers..
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
Nov 04, 2009 | Pioneer VSX-1019AHK A/V receiver
Jan 24, 2009 | Bose 901 VI Main / Stereo Speaker
I have pioneer receiver Vsx-454 i want to know if this receiver is 5.1 surrounds
Yes. It is 5.1 surround. There are 2 front channels, 1 center channel, and 2 rear channels which comprise the "5" in 5.1 surround. The pre-amp output channel for a sub is the ".5".
Jan 11, 2009 | Pioneer VSX-454 Receiver
142 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Morne Olivier
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
