Question about Apple iMac M6709LL/B Desktop
What is an ip?
Ok, so what is an ip?
  • kseoulgirl Apr 22, 2008
    ok so how do I get this number?
    posted by kseoulgirl on Apr 21, 2008
    Report abuse
    I got this computer basically for free. I cannot figure out how to get hooked up online. I have DSL Broadband through Netzero on my other computer(which since has crashed) and I would like to now hook up the iMac to be able to use Netzero as my ISP. Can this be done?
    Comment by kseoulgirl, posted on Apr 22, 2008
    How do I know what phone number to type in?
    Best Solution
    airics
    Rank: Apprentice
    Rating: 75%, 3 votes
    Yes it can be done if you are in OS9 under your apple menu control panels you will see a Tcp/ip setting. In there change the setting to modem built in then put in the phone number you wish to dial and it should work. There also use to be a setting called free PPP that would work also.
    Comment by airics, posted on Apr 22, 2008
    Scholar:
    New Friend:
  • 84 Answers
An IP address is nothing but a string of numbers separated by periods that identifies each computer attached to the Internet.There are two types of IP for a single computer namely Private or local IP address ,you can find the private or internet IP address using the command prompt Start - CMD - IP config/all .And the second one is public or network IP address you can find this address by visiting the site IP-Details.com.
Posted on Jun 04, 2013
Hello kseoulgirl and welcome to FixYa
An IP stands short for Internet Protocol
An IP is like a home address like:
742 Evergreen Terrace, Springfield USA
but it is represented in numbers.
If you have a DSL modem it should say your IP address on the back
example:192.168.7.5
Hope It Helps
Posted on Oct 20, 2008
  • 22 Answers
IP= Internet protocol it would have numbers like 192.10.10.10 or what ever range the isp uses. If the first 3 numbers have a 169. whatever you are not connected.
Posted on Apr 22, 2008
I have a Xerox 8560 printer and I am trying to setup the TCP IP address, but the control panel will not let me go in to setup, it just says Exit. When I go into Trouble shooting I can print a printer
The procedure to set the IP address from the control panel is below:
1. On the control panel, press the System button.
2. Select Connection Setup, and then press the OK button.
3. Select Network Setup, and then press the OK button.
4. Select TCP/IP Setup, and then press the OK button.
5. Select DHCP/BOOTP, select Off, and then press the OK button.
6. Select TCP/IP Address, and then press the OK button.
7. Enter the product's IP address, and then press the OK button
Sep 27, 2014 | Xerox Phaser 8560MFP Laser Printer
How could i change the ip addres my hp 4015n ?
Configure the network product View or change network settings
1. Type the IP address into the address line of a Web browser to open the embedded Web server. 2. Click the Networking tab to obtain network information. You can change settings as needed.
Manually configure IPv4 TCP/IP parameters from the control panel In addition to using the embedded Web server, you can also use the control-panel menus to set an IPv4 address, subnet mask, and default gateway. 1. Press Menu . 2. Press the down arrow to highlight CONFIGURE DEVICE, and then press OK. 3. Press the down arrow to highlight I/O, and then press OK. 4. Press the down arrow to highlight EMBEDDED JETDIRECT MENU, and then press OK. 5. Press the down arrow to highlight TCP/IP, and then press OK. 6. Press the down arrow to highlight IPV4 SETTINGS, and then press OK. 7. Press the down arrow to highlight MANUAL SETTINGS, and then press OK. 8. Press the down arrow to highlight IP ADDRESS, and then press OK. -or- Press the down arrow to highlight SUBNET MASK, and then press OK. -or- Press the down arrow to highlight DEFAULT GATEWAY, and then press OK. 9. Use the numeric keypad, or press the up arrow or the down arrow to increase or decrease the number for the first byte of the IP address, subnet mask, or default gateway. 10. Press OK to move to the next set of numbers. To move to the previous set of numbers, press the back arrow . 11. Repeat steps 9 and 10 until the IP address, subnet mask, or default gateway is complete, and then press OK to save the setting. 12. Press Menu to return to the Ready state.
Jan 14, 2011 | HP LaserJet P4015N Printer
I have WG11v3, adapter and have all lights ready except. It tells me about the ip address is needed. How can I put that in. I provider is verizon and they tell me I will have to get that answer from...
Click on Start and then Control Panel. Select Network Connections. Right click on the local network adaptor you are setting the IP address for. Select properties. If you do not see Internet Protocol (TCP/IP) click the install select protocol and add then Internet Protocol TCP/IP and ok. Click on Internet Protocol (TCP/IP) and properties. If you do not know the IP Address select obtain IP address automatically and OK. Click OK to close and save Local Area Network Properties. See if this works otherwise you will need to find the IP Address for your modem.
Jul 27, 2010 | Computers & Internet
What is the default ip of the paradyne modem6381
The default ip is :192.168.1.1
The default User-name and Password is : Admin
Some model came with default ip 192.168.0.1
Subnet to use is 255.255.255.0
Ok make sure you are using an ip address with the same range.
That is you can set your ip 192.168.1.x where is 2 to 252
ok try this
Jan 22, 2010 | Paradyne 6381 ADSL2+/ReachDSL Router...
ImageRunner 1023N.. assign IP
Press the additional funktion buton,press the arrow keys until 9 system settings is displayed press ok press the arrow again until 5 neywork settings is displayed press ok.TCP/IP settings will be displayed press ok and change the ip to your network adminatrators specifications.
Aug 17, 2009 | Canon imageRUNNER 1023 Black and White...
I have Windows XP Pro, SP2, Office 2007, and an HP Photosmart C7280 off a wireless router. Printer scans OK but 9 times out of ten it can't see the PC. DHCP is "on" but printer IP address is sometimes Auto...
The problem is you want to have the printer on a fixed IP address. This can be done by reserving the IP for the mac address of the printer in the router OR simpler just set the IP address in the printer.
Change IP settings
The default setting for the IP settings is Automatic, which sets the IP settings
automatically. However, if you are an advanced user, you might want to manually change
the IP address, subnet mask, or the default gateway. To see the IP address and subnet
mask of the HP All-in-One, print a network configuration page from the HP All-in-One.
NOTE: When manually entering an IP Setting, you must already be connected to an
active Network, otherwise the setting will not stay when you exit from the menu.
CAUTION: Be careful when manually assigning an IP address. If you enter an invalid
IP address during the installation, your network components will not be able to connect
with the HP All-in-One.
To change IP settings
1. Press Setup.
2. Press until Network is highlighted, then press OK.
The Network menu appears.
3. Press until Advanced Setup is highlighted, and then press OK.
4. Press until IP Settings is highlighted, and then press OK.
If the HP All-in-One is already connected to a wired network, you are prompted to
confirm that you want to change the IP settings. Press OK.
5. Press until Manual is highlighted, and then press OK.
6. Press to highlight one of the following IP settings, and then press OK.
• IP Address
• Subnet Mask
• Default Gateway
7. Enter your changes, and then press OK to confirm the setting.
Jul 04, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Wireless printer
  1. Print a Network Configuration Page from the product.
  2. On the front panel of the product, press Setup .
  3. Press the arrow buttons to select Network and then press OK .
  4. Press the arrow buttons to select Network Settings and then press OK .
  5. Press the arrow buttons to select Network Configuration page and then press OK . NOTE: If the page does not print, unplug the power cable from the back of the product, wait a few seconds and then plug it back in. Repeat the previous steps, a-d, to print the configuration page.
  6. Change the IP settings to Manual from the printer:
  7. On the front panel of the product, press Setup .
  8. Press the arrow buttons to select Network and then press OK .
  9. Press the arrow buttons to select Advanced Settings and then press OK .
  10. Press the arrow buttons to select IP Settings and then press OK .
  11. Press the arrow buttons to select Manual and then press OK .
    1. Set the IP settings from the Manual IP Settings Menu using the following instructions:
      For this item...
    Do the following: IP Address Type in a static IP address on the same subnet. Select an IP address outside of the Dynamic Host Configuration Protocol (DHCP) range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway
  • tahnks
    TTYAGI
    Apr 30, 2009 | HP DeskJet 6988 Printer
    Tcpip is disable on a xerox 8550 printer. How to enable it manually
    Here are the steps to set up a static IP on your printer.
    1. With the printer displaying 'Ready to Print', press the [Up] or [Down] arrow button on the Control Panel and select [Printer Setup] on the Display Screen, and then press the [OK] button.
    2. Press the [Up] or [Down] arrow button to select [Connection Setup], and then press the [OK] button.
    3. Press the [Up] or [Down] arrow button to select [Network Setup], and then press the [OK] button.
    4. Press the [Up] or [Down] arrow button to select [TCP/IP Setup], and then press the [OK] button.
    5. If necessary, press the [Up] or [Down] arrow button to select [TCP/IP], and then press the [OK] button to select [On].
    6. If necessary, press the [Up] or [Down] arrow button to select [DHCP/BOOTP], and then press the [OK] button to select [Off].
    7. Press the [Up] or [Down] arrow button to select [TCP/IP Address], and then press the [OK] button.
    8. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the address.
    9. Press the [OK] button to accept and move to the next three digits. Repeat until the required IP Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
    10. Press the [Up] or [Down] arrow to select [TCP/IP Network], and then press the [OK] button.
    11. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the network mask.
    12. Press the [OK] button to accept and move to the next three digits. Repeat until the required Network Mask is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
    13. Press the [Up] or [Down] arrow to select [TCP/IP Gateway], and then press the [OK] button.
    14. Press the [Up] or [Down] arrow to scroll to the correct number for the first 3 digits of the Gateway Address.
    15. Press the [OK] button to accept and move to the next three digits. Repeat until the required Gateway Address is displayed, and then press the [OK] button to return to the TCP/IP Setup Menu.
    16. Press the [Up] or [Down] arrow to select [Exit], and then press the [OK] button.
    May 20, 2008 | Xerox Office Equipment & Supplies
    Configuring IPSec between a Microsoft Windows 2000 or XP PC and a Linksys VPN Router
    Windows XP or Windows 2000 IP Address: 140.111.1.2 ? User ISP provide IP Address, this is only a sample Subnet Mask: 255.255.255.0 BEFVP41 WAN IP Address: 140.111.1.1 ? User ISP provide IP Address, this is only a sample Subnet Mask: 255.255.255.0 LAN IP Address: 192.168.1.1 Subnet Mask: 255.255.255.0 Step-by-Step [Windows 2000/XP] Create IPSec Policy 1. Click the Start button, select Run, and type secpol.msc. in the open field. 2. Right-click IP Security Policies on Local Computer and click Create IP Security Policy. 3. Click the Next button, and then type a name for your policy (for example, ?to_befvp41?). Then, click Next. 4. Deselect the Activate the default response rule check box and then click the Next button. 5. Click the Finish button, making sure the Edit check box is checked. Build 2 Filter Lists: ?WinXP? BEFVP41? and ?BEFVP41? WinXP?. Note: The references in this section to ?WinXP? can easily be exchanged for ?Win2000?, if running Windows 2000. Filter List 1: WinXP? BEFVP41 1. In the new policy properties, deselect the Use Add Wizard check box and then click the Add button to create a new rule. 2. From the IP Filter List tab, click the Add button. 3. Type an appropriate name ?WinXP? BEFVP41? for the filter list, deselect the Use Add Wizard check box, and click the Add button. 4. In the Source address field, select My IP Address. 5. In the Destination address field, select A specific IP Subnet, and fill in the IP Address 192.168.1.0 and Subnet mask 255.255.255.0. 6. If you want to type a description for your filter, click the Description tab. 7. Click the OK button. Then click the OK (for WinXP) or Close (for WIN2000) button on the IP Filter List window. Filter List 2: BEFVP41? WinXP 8. On the IP Filter List tab, click the Add button. 9. Type an appropriate name ?BEFVP41? WinXP? for the filter list, deselect the Use Add Wizard check box, and click the Add button. 10. In the Source address field, select A specific IP Subnet, and fill in the IP Address 192.168.1.0 and Subnet mask 255.255.255.0. 11. In the Destination address field, select My IP Address. 12. If you want to type a description for your filter, click the Description tab. 13. Click the OK button and click the OK (for WinXP) or Close (for Win2000) button on IP Filter List window. Configure Individual Rule of 2 Tunnels Tunnel 1: WinXP? BEFVP41 1. From the IP Filter List tab, click the filter list WinXP? BEFVP41. 2. From the Filter Action tab, click the filter action ?Require Security?, and click the Edit button. 3. verify that the Negotiate security option is enabled, and deselect the Accept unsecured communication, but always respond using IPSec check box. 4. Select the Session key perfect forward secrecy (PFS) and remember to check the PFS option on the BEFVP41, and click the OK button. 5. From the Authentication Methods tab, click the Edit button. 6. Change the authentication method to Use this string (preshared key), enter the string ?XYZ12345?, and click the OK button. This new Preshared key will be displayed. Click the OK button to continue. 7. From the Tunnel Setting tab, click The tunnel endpoint is specified by this IP Address radio button and type the WAN IP Address 140.111.1.1 of the BEFVP41. 8. From the Connection Type tab, Select All network connections and click the OK button to finish this rule. Tunnel 2: BEFVP41? WinXP 9. In the new policy properties, deselect the Use Add Wizard check box and click the Add button to create the second IP Filter. 10. From the IP Filter List tab, click the filter list BEFVP41? WinXP. 11. From the Filter Action tab, select the filter action Require Security. 12. From the Authentication Methods tab, click the Edit button. 13. Change the authentication method to Use this string (preshared key), enter the string ?XYZ12345?, and then click the OK button. This new Preshared key will be displayed. Click the OK button to continue. 14. From the Tunnel Setting tab, click the radio button for The tunnel endpoint is specified by this IP Address and type the Windows 2000/XP IP Address 140.111.1.2. 15. From the Connection Type tab, select All network connections. Then, click the OK (for WInXP) or Close (for Win2000) button to finish . 16. From the Rules tab, click the OK button to go back to the secpol screen. Assign New IPSec Policy 1. In the IP Security Policies on Local Computer MMC snap-in, right-click the policy named to_befvp41, and click Assign. A green arrow appears in the folder icon. [BEFVP41] Setup Screen 1. Open your web browser and enter 192.168.1.1 in the Address field and press the Enter key. 2. When the User name and Password field appears, skip the user name and enter the default password admin and press the
    Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
    Apple iMac M6709LL/B Desktop Logo
    115 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
