Question about Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt
Line 6 spider ii. As soon as I turn on the power I get a huming sound. can not adjust anything. The only sound is the hum. Could it be a transformer problem! much appreciated
  • Line 6 Master
  • 5,603 Answers
Not a transformer problem... this is likely filter capacitors, rectifiers, and PROBABLY a bad amp chip. Service this before it wrecks the speaker.
Posted on Aug 10, 2010
My Line 6 Spider II 210 won't make any sound from the guitar. When the amp powers on, the speakers pop a little so I know they are connected right. All of the lights are on and the channels can switch...
Bad soldering, especially around the jacks and plugs. Crack in the circuit board. Bad switch contacts on the headphone jack... all these are first things to check.
Here is your service manual for the unit:
http://elektrotanya.com/line6_spider_15w_ii3012_1508_sm.pdf/download.html
Jan 14, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
My son has a Line 6 Spider III amp. The sound disappeared. I was told the problem is the power transformer had no power any longer. I need a 1X-5730-04H0 to replace the bad one. Where do I order from?...
Transformer failures are VERY UNCOMMON. I would verify the problem before trying to find one.
Most failures are with circuit board cracks and electrolytic capacitors.
Find a very competent electronic technician to check this out.
The RARE failures that occur in transformers are often poor soldering right near the terminals or lead wires. These can often be repaired without replacing.
Sep 29, 2010 | Line 6 Spider Iii 30
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Hi My line 6 spider 111 30 has a problem The amp will switch on but there are no light showing and no sound, there is power to the amp as it will hum slightly when switched on
The hum MIGHT be directely from teh power transformer vibrating the chassis RATHER than via the speaker. This is an important detail to investigate.
Jan 14, 2010 | Line 6 Spider Iii 30
Amp goes dead
A few things come to mind. The power transformer could be failing or a capacitor is failed or has a broken solder connection..or a series of bad connections. Spider II's and especially III's are known to do this sort of thing. There is nothing you can do to fix it without taking it to an authorized repair center with your receipt. Repair centers simply get a whole new circuit board to replace the existing one since most of the components are surface mount and programmed chips. If its the transformer then if may be more expensive to fix than it's worth (unless it's still under warranty). With dozens and dozens of components inside these amps, there is no way to pinpoint the problem without hands-on servicing. Check Line 6's website for your nearest repair center. Best of luck!
http://www.line6.com/support/serviceCenters/
Aug 25, 2009 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Line 6 spider III 15 watt sound problems
Hi there. Sounds like the power amp IC is shorted. Must replace.
Paul
Jul 04, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Amp turns on but no sound even with diff guitars and cords
Hi Dan
I wish I could just say what to fix, but you can not do this at home. Line 6 is a great amp and worth the time taking it down to the music shop , to be looked at an give you a repair estimate. good luck keep on rocking in the free world. DFD
Apr 12, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Open Questions:
See all Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Questions
Line 6 Spider Iii 15 Modeling Guitar Amplifier 15 Watt Logo
493 people viewed this question
Top Line 6 Music Experts
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
freddybrass
Level 1 Expert
Don Hart
Are you a Line 6 Music Expert? Answer questions, earn points and help others
