Question about SE Electronics SE MINI Microphone
Does the SE Mini use a standard cable or is there a special cable needed for use in an amp or computer?
I bought a used SE MINI. The standard mic cable I use doesn't work with the SE Mini. I`m wondering if my mic is broken or if there is a special cable needed instead.
Also, can a SE Mini be repaired easily or is it best to buy a new mic?
Thanks all!
Peter
  • Cass Surek
    Cass Surek May 11, 2010
    Dear Peter,
    According to the specs it takes a 3 pin XLR cable, which should be the same as any other decent mic cable around. You will also need Phantom Power to feed into it to get anything going. Have you got Phantom power and have you tried different cables?
    Cass
    www.surek.co.uk
You'll need an xlr (male) to xlr (female) to use the microphone with 48v phantom power (from a preamp). phantom power dosnt work with an xlr to jack, only both xlr.
Posted on Jan 07, 2009
Where do you find a mini USB cable to hook up to computer?
If you want a mini or micro usb cable to connect to a PC then your local poundshop will do as it is a standard cable. If for charging then it must be a 5volt 1.5amp lead otherwise you will get connect to pc constantly. It differs between 500milli amp for a pc and 1.5 amp for a charger.
Mar 31, 2014 | Garmin GPSMAP 398 GPS Receiver
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
Very low volume from mic input even with Gain and Master turned full on
You haven't told us what type mic you are using. If you are trying to use a condensr mic with this, you will need a preamp that supplies Phantom power to the mic. You haven't told us what cable you are using. Do check that you aren't using a condenser mic as there will be virtually no volume.
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
How do u get hsm wii microphone to work on
well ..i cant see what type of conection you mic has and what you really want to achieve as far as quality of sound or ultimate use..,but...here are some ideas.. A mic needs a pre amp and that is often built into some cheap but usable mini mixers made by behringer..You could pick up one and a good cheap dynamic mic[dynamic mics are best close to the sound source] with a lead and then go from the main output of the little mixer to the audio input of the computer.. A second but easier way and one that could give very good results is purchase a USB input microphone and this will have mic pre amp built in so it just plugs into your computer usb port.. SE electronics ,Rode make brilliant ones that are used often for podcasting..[well worth the +-100 uk pounds] but i am confident that berhinger will make a usable model for much less money[these type usb condensers will be sensitive and give clear results]...
Mar 21, 2010 | Logitech Vantage USB Microphone for...
Hi i have videos recorded on tape with my samsung digi-cam SC-D353 NTSC. How can i transfer this to my pc? Do I need some kind of special cable? THanks for your help.
mini usb cable also depends on what inputs your camcorder has but most of them have mini usb inputs then use windows movie maker to put it on the computer if you dont know what cable to get then just take it to the store and they will tell you what cable you need
Jul 30, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Usb cable
Players use standard USB, Mini USB, or Micro USB. I believe the one in title uses Mini USB cable.
To get a replacement cable go to any computer shop or camera shop and buy a Mini USB cable, take the player with you and show it to the shop assistant to ensure you are buying the right cable.
Regards.
Jul 05, 2009 | Supersonic SC920FM MP3 Player
I have a Sony MDS JE520 mini disc deck. How do I
requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
Jun 24, 2009 | Sony MDS-JE520 Mini Disc Player
Do I need any special cables to view or record the footage?
No. The GRHD1U includes a component cable. Another breakout cable provides composite, S-video and audio left and right. For dubbing the footage to a DVHS VCR or computer, a standard 4 to 4 or 4 to 6 (camera has a 4 pin connector built in) pins firewire cable (not supplied) is required.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
SE Electronics SE MINI Microphone Logo
152 people viewed this question
Top SE Electronics Audio Players & Recorders Experts
Michial Gueffroy
Willem.
Willem.
Are you a SE Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
