Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop vac model 86L450 won't turn on
This was used only once. Made sure the outlets were working, but still no power.
5 Suggested Answers
SOURCE: craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Posted on Jun 09, 2009
oldmanewtoys
  • 414 Answers
SOURCE: shop-vac model 90L550A motor wont run
Yes replacing the link would work, but that would not fix the cause. You have either pulled the wiring to the point of pulling apart the connection or there is a short. Which would be in the way of a grounding effect causing the link to heat and melt. A safty issue to be sure. Check all contact with housing and motor to make sure there is not an underlying problem to start with. Unpluged of course
Posted on Feb 25, 2010
SOURCE: vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Posted on Aug 29, 2010
javeedcare
  • 316 Answers
SOURCE: I have an old shop
http://www.hammerwall.com/Download_Manual/16114/
GO TO THE ABOVE ADDRESS TO GET YOUR MANUAL.
REGARDS.
PLZ RATE THIS
Posted on Jul 04, 2011
Miele S251i. While using,operator pulled on cord from another room. Vaccuum stopped.Touch of smoke at outlet.Prong slightly bent.Prong straigthened & plugged in, but still no power.No breaker tripped.
Power cords of portable appliances are vulnerable to internal damage, especially vacuums.
If the power outlet is still good and a different outlet has been tried it would be reasonable to suspect the power lead has an internal break.
The correct method of checking is to partially dismantle the appliance and use an ohmmeter to check for continuity. In practice, because a break is more likely to be near the end of the wire, cutting a couple of feet off and refitting the plug often works.
Apr 27, 2018 | Miele Vacuums
Shop vac qps30 on off switch stays on Do I have to replace
It would be a good idea since the points inside the switch are welded together and produce heat.
Nov 09, 2017 | Shop Vac Vacuums
Shop vac doesn't work. Does my shop vac have a thermo fuse?
Contact the manufacturer of device. They may help you. If not, make sure that current is reaching the on/off switch and that the power is reaching the motor - if power gets to motor and still nada then the issue is probably with the brushes not making proper contact with the commutator.
Dec 23, 2016 | Shop Vac Vacuums
How do I fix the beater bar attachment on my Oreck Canister Vacuum?
Well Anonymous, unless you have a continuity tester I'd say you will most likely need to take your machine to a vac repair shop. You need to determine if there is voltage going to the power nozzle portion through the hose and the wand. This is where the continuity tester comes in. If you have one and know how to use it, check the hose to make sure there's a clear path there for the juice to flow, if so, then check the outlet on the vacuum itself. If all is kosher at these two points then check the power nozzle itself. Somewhere along the line you will find an open circuit, that will be the problem that needs to be repaired or replaced. If you take it to a vac shop for repairs, they will do all this for you and then tell you what needs to be repaired and how much it will cost.
Oct 17, 2015 | Oreck Vacuums
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Honeywell air purifier won't turn on
Hello, this is Ava with Think Crucial.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 23, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
I have a brand new KitchenAid mixer that is 5 years old and never used. I unpacked it this morning and it won't turn on, no noise, no movement, nothing. Help.
Please check manually the motor and see if it moves freely. Now make sure that the power plug and the connections to the switch are not tampered , check the continuity of the plug to the switch and to the motors.
If you notice any dirt or insects make sure that this has not clogged on the motor. If so clean using a degreasing spray- WD40- would be recommended.
If the motor is tight , lightly oil or degrease using the spray while manually rotating.
Once this is done connect the power while taking all precaution. Use the meter to check the flow of the circuit to the switch and to the motor. If there is a trip switch see that it is reset.
If there is power to the motor and still it does not work the brushes might be dirty and might need a cleaning/ reset.
Jul 07, 2011 | Vacuums
It stopped working while I was using it . I tried to plugged in different electric outlets but it still dead. What should I do or look into in order to get it back to normal?? thanks
I would start by taking the wand apart. Be sure vac is unplugged from the wall outlet! You should be left with two pipe pieces, and the beater bar. I would also pull the hose from the canister unit itself. Once all the pieces are pulled apart, check the two or three prong wire connectors on each piece, both the female and male ends. If you have any dielectric grease, use a dab on each electrical connection. Once you reassemble, and still not powering up, wiggle the wand back and forth at the connection near the canister, and after the hose near where the switch is. If the vac cuts on after wiggling it, then you have a loose connection, and will need to tighten the female ends on the electrical connections, by squeezing them together slightly with a pair of pliers. Please rate if this works or does not work. Thanks!
Jan 03, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
310 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
