Question about Dometic Rooftop RV Air Conditioner
Have a older dometic roof top ac 1992 problem is board 3101625
Have a older dometic roof top ac 1992 problem is board I can see a diode crode off , rest of board looks good. I think had a small leak and caused it crode. Anyone repaired these they want 195.00 for new board.Before i do this will buy new unit. So thing to Repair.
SOURCE: compressor
pls check compressor capacitor and compressor termonal connection start the unit check the voltage at the compressor terminal if is ok means copmressor need replcement
Posted on Apr 29, 2009
SOURCE: Older Penguin roof shroud, new style fit?
I just replaced my two 620315.321 shrouds with the newer style without any problems. I went to the Camping World site (and called them) with model no. and they knew what to send me. I also found that they had the best price at $79.00 (member price) with free shipping.
I didnt check your shroud part no.s, but think you will be ok if you do as I did.
If you have any question about installing, you can email me at remeola@comcast.net
Posted on May 05, 2009
  • 2692 Answers
SOURCE: How do I clean out the vents in my RV Dometic roof
Take it off,the plastic inside vents, with soap water and a hose wash it.  Outside condendor and inside evapator, making sure the drain is open and outside shroad removed, brush off fthe loose stuff. wet both units, put liquid dishwashing soap on both. Spray then through , with a hose untill they rince clean.  While up there. Oil the motor if possible.  Keep the drain clear and open,making sure none of the water is getting into the RV.
Posted on May 10, 2009
lbeng
SOURCE: FAN SHUTS OFF BUT COMPRESSOR KEEPS RUNNING - 6 MONTHS OLD
Depending upon the model of your air conditioner, this may be normal operation.
My newer Dometic air conditioner will run the compressor in a "reverse" mode without the fan occasionally in order to heat the coils. This is done to defrost the coils. After the frost is gone, the fan switches back on and everything goes back to normal.
Posted on Jun 30, 2009
ryanmalin
  • 40 Answers
SOURCE: the dometic roof ac humms when rv is on 110 ac
not likely but possible. if they already had one bad board what's to say their production methods have changed since they made your last bad board. I have just had 6 bad compressors from this chinese company danfoss in one month! for only 2 freezers i have installed 3 bad compressors in each! nobody takes pride in production anymore they want the stuff to break.
Posted on Oct 10, 2009
My carrier ac roof top ducted unit started spitting out small amounts of water now and then, I changed filter. Now with ac in off position I am hearing a humming noise coming from the unit, what can this...
Don't really understand what you mean by roof top duct unit .if it's a roof top unit and water is leaking down your vent then you have a clogged drain line .
Mar 02, 2018 | Dometic Rooftop RV Air Conditioner
1992 dolphin rv duotherm ac still leaking after cleaning the drain tray holes
Have you checked evaporator fins/coils at front to see if it is those that are frosting up and need cleaning? Also make sure return air and cool air aren't mixing. If some cool air is getting in to return air, from other side, it will cause condensation as well. Some older models did suffer from cracks in drip tray as well. That requires removing cover on top and looking and sealing cracks in plastic drip tray under evaporator and condensor etc. Sometimes it works . Clean well and use good sealant if that's the problem.
Sep 26, 2012 | Dometic Rooftop RV Air Conditioner
13.5 Dometic rooftop rv ac design has changed since I purchased 2006 Monaco Camelot rv. The collection cups leading to the drain line do not fit well on the roof seal and a good seal is hard to achieve. If...
I've not run into the problem your having yet, so I will apologize up front for asking you to furnish more information. These drain cups that I assume are little round pieces attached to the base of the unit where it meets the roof, were not common on dometic, but were common on Coleman AC units. Those are the outlets for condensation to the roof anyway, are they not?
Also, as far as gasket goes, no I wouldn't recommend using 2. We were always advised by manufacturer to compress gasket to half the original thickness when installing either Dometic, or Coleman (RV Products). Coleman at one time, had tabs under gasket that when gasket was compressed, and they touched the roof surface inside, that was far enough, which was approximately half the original thickness. Believe it or not, over-tightening is more likely to cause a leak. Stick with half original thickness, or close to it.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
Looking for schoolbus roof-top AC installer in Houston, Texas.
You can get lots of roofing companies in Houston TX. Just like CM Construction Remodeling, It is near to your location and helpful for you, get a fast response with reasonable price.
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
I need to find a cycling thermostat for a Dometic Roof top unit
I ran across the same problem and found the kit to expensive. I gutted the parts added a transformer, contactor and thermostat. Unit worked great and cost about half the price.
Jan 04, 2010 | Dometic Rooftop RV Air Conditioner
Rv ac unit leaks, even when fan only
Where the pipes enter the building, look carefully there for a bad seal. Use a good quality sealant and block the leak properly. If there is no rain, and the unit is leaking still with the fan on only, then you have an issue with the drain pipe angle or a kinked pipe or a blockage. Suggest you have it seen to by a aircon. technician as that repair is really not easy.(AC will possibly have to come out to rectify problem).
Oct 17, 2009 | Dometic Rooftop RV Air Conditioner
My dometic RV rooftop air conditioner is leaking on the inside of the camper even after I cleaned the water condensation drain on top of the roof. What could be causing this? The fan is blowing the water...
Remove all covers and look down with them removed and see if the coil drain pan has a stopped up exit where the water drains out and into the rear of the AC unit.
If the unit is off level it could cause a draining problem too.
Jul 10, 2009 | Dometic Rooftop RV Air Conditioner
Coleman Mach roof top ac
Under the drain pan on each side should be a small plastic drain plug they might be clogged up with debris.
Jun 07, 2008 | Dometic Rooftop RV Air Conditioner
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Mar 24, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
81 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
