Question about Kitchen Ranges
GE Profile Range Hood. The diode on the light switch has burned out and will no longer dim. I would like to replace the diode, but need specifications on what to buy, assuming the parts are available at a local store.
    President:
  • 1,099 Answers
Most HV diodes have press fit (Fast-On) or ring lugs so replacement is very straightforward. Discharge the high voltage capacitor. Make sure you get the polarity correct if your replacement can be installed either way. Putting the diode in backwards will result in positive instead of negative high voltage and, needless to say, no heat, but no other symptoms either.
Note: the lugs on your new HV diode may just be crimped onto the wire leads and not welded or soldered. If this is the case, take care not to stress them excessively which might result in bad connections now or in the future. It may be a good idea to solder the lugs to the wires as well (though this may be overkill).
Where the diode is part of the capacitor assembly, it may be possible to just replace the diode leaving the old one unconnected (at one end) as long as the original diode isn't tied to ground inside the case. This will probably be much much cheaper than replacing the entire assembly.
Hope this workout......
Posted on Jul 22, 2010
Ge hood insert zvc36l1ss fan comes on by itself. When not cooking?
The switch is bad. That makes it a possible fire or electrical hazard.
You should replace the switch immediately, or at least turn off the breaker that supplies power to the unit.
Don't let a broken $20 part be responsible for burning your home to the ground, fix it!
Parts for this hood are at http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Range-hood-Parts/Model-ZVC36L1SS/0432/0122400
This shows you how to open it up and replace the parts: http://www.searspartsdirect.com/partsdirect/user-manuals/9235/ZVC36L1SS-GE-Parts-RANGE+HOOD-manual?pathRender=fromManualTabPage
Jul 26, 2014 | Microwave Ovens
Ge oven model xl44. my oven will not lite, the broiler works fine.
Hi..
You need to do this
  • Replace the bulb
  • Test the switch
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
When an indicator light has stopped working, you may be able to replace just the bulb--but you usually have to replace the entire light assembly. Alternatively, there could be a problem with your burner sensor (stuck open or closed) or your indicator light circuit.
Good luck !!
Regards
PCmania
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Telescopic Downdraft JVB37HBB
mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut board...it seems a diode fried or something...im still looking for a replacement
Jun 08, 2008 | GE Profile JVB67HWW 36" Telescopic...
Oven light switch shorted out.
I scheduled a GE technician to make a home visit to replace the failed parts.
May 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Nov 26, 2007 | GE Profile JGSP48 Gas Kitchen Range
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
