Question about Whirlpool Duet GHW9150P Front Load Washer
The machine stops and shows F11 on the screen and i cant open the door.. its a whirlpool duet front loading automatic washer
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F11 is a communication error between the central control unit (CCU) and the motor control unit (MCU). To start with check the wire harness connections between CCU and MCU, and then check the motor. If both of them appear to be working fine then it seems that the MCU of your washer has gone bad as the control unit seems to be working fine. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 22, 2010
  • 1 more comment
  • eleanorbenit Jul 22, 2010
    Whats a CCU and an MCU.. i dont understand. im not a technical person, so maybe i should just call for help then?
    oh.. sorry you did spell out what that means but where do i find it?
  • Rylee Smith
    Rylee Smith Jul 22, 2010
    If you have some expertise and want to do the repair yourself then please check this repair manual for your whirlpool Duet front load washer. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
I have an F11 code on my kenmore front load washing machine
After years of suffering from random F11 that became a permanent F11, I did the repair as in the video and all is good for 2 years. No more F11. About one load a day (we have kids!)
Aug 22, 2014 | Kenmore HE2 Plus Front Load Washer
Whirlpool front loader cant open the door the display just blinks
To open the door you need to remove the panel below the door (three screws at bottom of machine) then reach up by the door lock and there will be a plastic tab hanging down, that will be the manual release for the door, just pull it down. Wile you're in there see if the technicians packet is taped to the inside wall of the washer, it helps to explain the workings of your machine. If the display is blinking, is it blinking a code? like F11 or FdL? Knowing the code will help in troubleshooting the problem. Good luck.
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer displays error f did what the manual says but still same problem
it shows f11,also DL,
I did change the door lock,
same alarms.
it's fine for few wash but when it happens again it just stop and show
F11.
Mar 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error Code F11
TRY UNPLUGING IT FOR A MIN OR TWO. I THINK F11 IS A CONTROL MODULE. CALL A TECH
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
The motor does not engage in at all
The F 11 code is a water fill code. Check the water to make sure both lines are on. If their on then turn off take hoses off the water inlet valves in the back and check the screens. If your screens are clean then you probably have a water inlet valve problem. Are you able to open the door to get your clothes out? If not I can tell you how to get it open.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F11
rmove top and ck connectors to rear mounted main control module f11 is code for communication problem between upper main control and lower motor control..most likely upper control problem tech sheet behind lower panel
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet Whirlpool Washer
You will need service at this time!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
20 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
