Question about Goodmans W280NS Television
Goodmans ld 26022
With the tv on standby and then press the channel button to turn on the tv goes to power up but after a few seconds it flashers the screen and then goes back to standby !!
    Master:
  • 788 Answers
I found two solutions to tripping:
#1: http://www.e-repair.co.uk/faults/GS017425.HTM
Replace line output transistor TR16. Resolder capacitor C68 as will blow transistor again if not resoldered
#2: http://www.eserviceinfo.com/repair_tips.php?search_rt=W280NS
Dry joints C68 & C71 & LOPTr slightly leaky
Looks like it would be worth looking at the board for bad solder joints and burnt components.
Posted on Apr 22, 2008
  • 3,037 Answers
It is tripping, meaning that it is trying to come on but not because of a safety reason. There is no exact cause for this, The only way to know for sure what part needs to be replaced is to have an experienced technician check it out. I'm sorry that we can't give you a certain part to replace but that is how some things are.
Good luck on getting this fixed and please let me know if you need any further help.
Thank you for using Fixya and Have A Good Day.
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
  • Benjamin Patri
    For Tripping you can Replace line output transistor TR16. Resolder capacitor C68 and also possibly C71 as will blow transistor again if not resoldered
  • Benjamin Patri
    Benjamin Patri Apr 29, 2008
    Thank you
    Sergeant:
  • 264 Answers
Yo may need to get it tested however yoy may just try one step.
Unplug the power cord. Unplug all the cords and anything with is connected.
Turn the TV on. Leave it for 20 seconds (without power and it wont show anything). Then plug everything back and try to power on again.
There should be no magnetic field near the TV , if yo have a magnetic device keep it away from the TV.
  • Goodmans Master
  • 19,396 Answers
You probably have a short, as the security switch is turning off tv by itself for safety reasons.
  • Ginko
    Ginko Apr 22, 2008
    When this happens you need to have your tv tested. Tvs have an internal security switch which turn tv off if there is an overvoltage issue or a short inside tv.
    Often you get this because of a faulty power unit.
Wont power on
some tv's always have standby light on, even iff you turn off by tv button. solution 1: with light on, press a number on remote. solution 2: with light on press stand-by button on remote. solution 3: with light on push the 'on' button on the tv set. solution 4: unplug tv set, wait a few seconds then plug back in, if no light then turn on tv using button on the set, and then channel number.
Jun 25, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Have purchased a Technika TK81R universal remote control to use with my Goodmans LD 2667D but canot get it to work any idea what to do?
Setup codes for Technika TV with universal remote contol are:
0031 0004 0005 0009 0051 0053 0105 0109 0170 0000 0174 0001 0008 0012 0042 0058
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Code Search Method
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 27, 2012 | Televison & Video
Hi i have a nordmende tv and was working until it was plugged out of the mains now it stuck on standby and i dont have remote its an nw32lqt any ideas for easy fix i ve tried letting capicators drain no...
while the TV is on standby, press the channel + or channel - button on the TV and the TV should power on.
If TV doesn't power on after pressing the channel button, then it means your TV is having a power problem. But I don't what to believe it is a power problem.
Let me know if press the channel button does not power on the TV so that I can explain further on the cause and way to fix the problem.
Yours sincerely.
Elect_Comp.
May 16, 2011 | Televison & Video
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
When i switch on and then press for channel the standby light goes dull and tv does not come on. tried power down and trying again but no luck
There is probably a leaking diode or something that is overloading the power supply in the TV. I had recently fixed an HDTV in which the standby light was flashing on and off dimly but would not come on. I measured the standby voltage and it was only a little over 2V which should have been 5 volts. Then I checked to see if the standby circuit was switching ( they switch on and off at 100,000 times per second if operating). It would switch on then off the on then vice versa every fraction of a second and that indicates overloading. Sure enough i found a diode that was shorted almost completely. All semiconductor only let current to pass one way . These are diodes, transistors and chips. They are like electical one way valves and when they get messed up the leak untill current goes both ways and this causes a short which in turn overloads the system and cause shut down. You can try to learn how to test these device using a the diode feature in a digital multimeter.
Jun 26, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
My EPG on my Goodmans GTVL26W28HDF no longer works
You may be right but if you leave it in standby overnight it should recover.
Jun 14, 2017 | Televison & Video
Televison & Video Logo
475 people viewed this question
Top Goodmans Televison & Video Experts
Kolbrun...
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
