Question about Refrigerators
Ice maker has quit ,had this one put in after only six months ,and now this one has quit.
  • 121 Answers
  1. Water comes from water pipe, usually with a shut off valve (open??).
  2. Fridge has a small filter (for sand etc.) at inlet. (not clogged??)
  3. Water travels to solenoid valve, and waits for request. (do you hear it click when water requested??)
  4. Water usually goes to a fine filter..(these fail (plug) quite regularly).
  5. Water goes through storage in back of cool section (Inside fridge- is it full of water?).
  6. Water goes to ice maker on fill request.
  7. ?? Is the power switch "on" (to icemaker)??
  8. ?? Is the full / stop filling paddle/bar up?
  9. ...ask me more questions
More likly than not- it has just frosted up and needs manual defrosting, or the water filter is plugged (assuming the cold water dispensor is slow)
Posted on Apr 22, 2008
  • 531 Answers
SOURCE: ice maker and water dispenser to not work. Just quit!
water valve
Posted on Apr 05, 2009
  • 56 Answers
SOURCE: model # for refr. 106
Sound the the bi-metal is starting to fail or the freeezer is not getting cold enough. If you put a thermometer into the freezer and it gets below 8 degrees and does not harverst then your looking at the ice maker which is a Whirlpool part number 4317943. This a kit will replace most of those style ice makers. It is the quickest and easiest way to solve your problem. You should be able to get it for between $85 to $160 depending on where you live and who you buy it from.
Posted on Dec 05, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Model ED2CHOXK005 Whirlpool refrigerator with ice
The problem is most likely your water control valve for the ice maker. There are 2 one for ice maker and the other is for the dispenser. Fill your ice maker with tap water. Let it freeze and if it dumps and does not refill then the water control valve part number 2188542 let me know if you need more help, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Aug 19, 2009
SOURCE: ice maker does not make ice
I had the same problem. There is air in the line therefore you need to dispense about 3 gallons of water from the dispenser and that should slove the problem. Also, take a clean soft cloth or paper iowel and wipe the ice make sensor (if you have one) and the reciever. There is one on each side of slightly below the ice maker. Should be a flashing or steady red light ....follow the flashing red light to the other side.
Posted on Oct 27, 2009
  • 277 Answers
SOURCE: ice maker is not making ice...we had it in the off
change the thermostat
Posted on Nov 01, 2009
The water dispenser is not putting out water and ice maker is not making ice. The fridge frequently cycles like it is trying to send out water.
it's still under warranty for up to 1 year,call whoever you bought it from and it should be repaired free of charge and next time you write send model number.
Dec 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Kenmore Elite 59969 and no ice
six weeks old / prob still under factory warranty . but ck the tempts in freezer it must be 15 deg of colder to work . so reset the control for freezer to the highest setting then back one.. this should help .
Jul 03, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
GE TBX22ZA refrig. automatic ice maker stopped making ice. I replaced the first ice maker when it stopped working with one I found at a thrift store that was still in it's original box, never used. The...
sounds like the water inlet valve/solenoid may be bad. I've had some to work awhile then quit. It could be trash inside of the inlet valve. If it has a water filter on the frig try changing it also. But try the solenoid first by turning your freezer section thermostat to its highest reading to for 24hrs.to see if the solenoid is going to work.
Dec 15, 2009 | GE Refrigerators
Model # for refr. 106 50037000. module # for ice maker 106 626636. it quite.i felt the ice froze in the maker but it didnt flip it out. i took the maker out let the ice melt.put maker back in , it worked...
Dec 05, 2008 | Refrigerators
Ice maker not working.........
Reset button on the bottem front right of ice maker
Jul 22, 2008 | Samsung RB215LASH
Kenmore cold spot side by side
Compressor may have quit. Have you cleaned the condenser where the heat from the system is transfered to the air? If not clean it out under the front back of the toe plate. this should be cleaned as often as every six months.
May 13, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
