Question about Samsung L100 Digital Camera
Camera is frozen, with the lense section stuck out, the screen is black and ive tried pressing the buttons, taking out the battery, charging it up.. it still wont work please help
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 22, 2010
Nikon s9300 - When I turn it on, the lense fully extends, but the screen stays black. I have to pop the battery out, then put back in for the lense to retract. Battery is fully charged and even tried
When the battery is fully charged, please put it in again. That means, if it is still in, remove it once again.
Switch it on, and even if you don't see a thing try to make a picture.
Then press the display button several times, to see if anything comes on the screen again.
If the camera does not respond after that, you should go back to the dealer, of contact Nikon.
Dec 21, 2013 | Nikon COOLPIX Cameras
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
I have fully charged the battery. Sometimes I can turn camera on and lense operates but no vision on screen and not able to take a photograph. but other times the lense will immediately retract. If lense...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success
Jan 14, 2011 | Pentax Optio SV Digital Camera
When I push the power button the lense moves in and out several times then the camera just turns off. I tried charging the battery and holding the power button down for 10 sec. but still does the same...
The power button has two purposes explanable;
1. A firm press and hold would shut down the entire device, where would be common feature for the camera to perform a system check to include the lense functionalilty.
2. A gentle press and release of the same power button should capture a snap shot only after the camera has been powered on, by the similar process as pressing firmly the power button
Remember
Pressing firmly the power button would shut down camera completely after a system check if only the camera was on.
Pressing firmly the power button when the camera is off would turn on the device by performing a system check also.
Important note
The camera when powered on would have an indicator light of ready to capture snap shots.
The camera would autoshut down when left on for an extensive duration without capturing snaps.
The instance of such would generate a camera check once more before powering off completely
The lense adds to the cameras feature capabilities of acquiring images. a function of the lense is capture an impressive image where the mechanism of drawing closer to the object is made possible by a moveable lense. The Olympus FE-340 Digital camera is powered by a battery requiring sufficient energy for a snap shot. keep in mind that, the camera can perform without the lense. However, the device is designed to automatically responded whenever the lense is required.
Important note;
1 a solution to the camera is with the source of energy in which instance batter power.
2.Dislogde the entire power area consisting of battery, check for improper installation; reinstall the battery in appropaitely noticing the installation indications of power supply. Cover the battery compartment properly, and charger afterwords.
Caution
1.Charge the battery for the entire duration known of a full charge.
2.Unplug thereafter when the full charge indicator is visible.
3.Try on the device for improvement in situation by taking photo snap shots
Dec 02, 2010 | Olympus FE-340 Digital Camera
Lense was stuck out did what toothy said now the lense is stuck i
Hi!
Please follow the troubleshooting given below to resolve the issue:
(a) Turn off the Camera and remove the Battery then press and hold the power button for 30 seconds.
(b) Then, reinsert the Battery and turn the Camera ON. Please make sure that the Battery is fully charged.
(c) Next, press and hold the Reset button for 30 seconds located above the DC-in jack on the Camera using a sharp pointed object.
If the Camera doesn't operate normally even after performing all the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
Help with frozen lense
the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 29, 2007 | Samsung Digimax S700 Digital Camera
Motorola V220 camera
fuck you !!!! motorola sucks!!!!!!!!! samsung rules!!!!!!!!!!!!
Dec 21, 2007 | Motorola Mobility V220
Frozen camera
your lense is jammed try to put your finger in it and close the lense all the way it might me like hardly closed, i had that problem and now my is open all the way so i cant close it yuo can email me at minimacaluso@yahoo.com or im makaluso06
Jan 26, 2007 | Samsung Digimax S500 Digital Camera
Samsung L100 Digital Camera Logo
1,600 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
