Question about Whirlwind FH-778 Air Conditioner
I use to do a/c work many years ago, forgot a few things. like what the pressure should be on the low side, 88% out side 77% inside do you have an approx. psi. using r22
  • 744 Answers
The back pressure on the suction side should be around 65-70 psi with R-22. Make sure the condenser coil is clean and that the condenser fan is working ok.
Also be sure the indoor filter is clean and that fan is running on high speed.
Posted on Jul 23, 2010
98 vw cabrio convertible top, troubleshoot, i got the car at auction the top wasn't working i fill up the fluid and it try to close but only halfway and notice the fluid was gone, try it again with...
Could be a burst high pressure hose. You need to remove as much trim as necessary to see the leak and identify the parts needed.
Power hood parts tend to be expensive due to the low volume production and the unrealistic profit margins so it is better to avoid dealer parts and use specialist hydraulic suppliers. A few years ago a dealer wanted £900 for a hose but I was able to have the hose repaired to a good standard for £96...
Nov 18, 2017 | Cars & Trucks
Compressor won't engage
filling an ac system by the can is begging for major costly problems
it is added by pressure in gauges attached to the compressor
the reality is that ac systems do not need added gas unless there is a leak and you have a big hole somewhere
Jun 23, 2017 | Cars & Trucks
I have a GE side by side refrigerator, with an icemaker in the door. The refig is slightly less than 6 years old. I have been out of town for a few days, but today opened the door to get something out...
Seriously? Mine just did the same thing today. The electric on the inside is fine. No cooling. there is a code blinking HRS on the inside. the ice and water were working intermittently the past couple of weeks. wtf?
I found a post describing the exact thing I have going on but it was from 3 years ago.
Feb 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
A/c clutch relay not getting signal from wire going to pcm.jump relay works fine. repl.a/c switch in dash a year ago
Check freon pressure while running on low side. Low pressure will cause compressor not to engage.
May 15, 2010 | 1992 Pontiac Bonneville
My fridge side out the blue is freezing. All
I had the same problem with mine a few years ago. After two thermostat replacements and still having the problem, the third technician out explained that if you blocked the vent on the inside of the refrigerator, (the shelf below meat drawer,left side) it could cause freeze up. Sure enough, haven't had a problem since.
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
I have a 20 year old furnace the transformer went took it off a year ago forgot the wiring , need a wiring diagram
The transformer is for the low voltage side of your furnace, you should be able to take the door off of the furnace and follow the wiring schematic on the inside of the door to wire it back correctly.
Sep 30, 2009 | Heating & Cooling
Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Jun 09, 2009 | Maytag MSD2756G Side by Side Refrigerator
Does not **** up detergent with the attached slim line hose
It only picks up under low pressure condition eather by adjusting wand or changing tip.
Mar 18, 2009 | Garden
Air conditioner is frosting up. Air temperature outside is not below 65......in fact it is more like 75, bnut inside because of the humidity it is around 80. it is less than a year old and only ran for 3...
Frost is caused by the refrigerant pressure being too low on the low pressure side of the system. That is, the compressor has more ability than the cold coil is using up. This can be caused by insufficient air flow over the cold coil or a shortage of refrigerant.
Insufficient air flow can be caused by a dirty coil, filter, or blower wheel, or collapsed ducts, to name a few. It is most likely that some of the refrigerant has escaped and the leak needs to be repaired and the refrigerant topped up to the right amount. You'll need to use the proper gauges, a good thermometer, and read the chart that is glued inside the access door on the condenser, or...check for any available repairs that are free because of your warranty.
I did know of a Sears 5,000 BTU window air that was simply designed wrong, but that was many many years ago.
Jul 22, 2008 | Heating & Cooling
Heating & Cooling Logo
114 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
