Question about KitchenAid Ovens
Model KGRT607HWH6. Not only has oven stopped lighting but broiler doesn't and the two front burners don't so it isn't an igniter problem unless all of them went at once. Other possibilities?
  • 3 more comments
  • jachern Jul 22, 2010
    The original solution didn't take into account that it is the oven, the broiler, and two of the burners not coming on (and it's a gas oven all the way, no dual fuel or anything like that). I don't think everything would individually die on its own at the same time. Both broiler and oven igniters do glow but glow orange (I'm told they should glow white). The strangest thing is that the back burners do still work. And I know gas is getting in because you can smell it when you turn it on and it doesn't ignite.
    OK. Maybe the igniters on the burners need cleaning but what about the oven not working and the broiler (which has its own igniter) not working either. And all of this started at the same time prior to which it all worked. Wouldn't that indicate a problem with something more system-wide?
    See my comments in reply to the second solution if you can
    The idea of checking the terminal contacts is good but since this is a gas oven the rest of the last answer didn't seem germane. Since burners light and clock and other displays work, seems to have electricity to it. But the electronics do seem to be working oddly--oven light sometimes doesn't come on when it should and stays on when it shouldn't.
  • jachern Jul 23, 2010
    While it didn't completely solve the mystery, it gave me some good places to look and some things to try and I felt this responder looked at the problem rather than just giving a canned answer.
  • KitchenAid Master
  • 2,005 Answers
Gas is not totally clean; contaminants can and, do; get through the gas lines
causing a blockage; you have a blockage in the gas line before the two front burners and the oven gas valve... to repair:
remove power; turn off the range's main (wall) gas valve; remove the grates and, anything on the range top; lift the range top; once you do this note that the gas lines go from the burners back to a gas line divider that also feeds your oven gas valve,
remove the line that feeds gas before the oven valve to the two front burners.
use compressed air to blow the obstruction out of the clogged gas line and, reinstall the gas line; tighten all gas line nuts; open the wall gas valve; and, leak test using a spray bottle of 50 / 50 dishwashing liquid soap and, water: if you see a bubble you have a gas leak.
after you are sure you have no leaks repower the range.
Posted on Jul 22, 2010
    That's the most cogent answer so far but I did get the burners working again--all four of them--so I'm back to thinking electrical?
  • Jim Goldsmith
    Jim Goldsmith Jul 22, 2010
    very good! now, check the oven gas valve for power; turn off the wall gas when you do this; using a multimeter the oven gas valve looks like a a small bathtub with a gas line going to it and, two wires attached to it; read the voltage on the two wires it is located at the broiler flame tube (burner) by the way the ignitor need not burn white, yellow is fine to ignite gas.
    President:
  • 1,099 Answers
It's always a good idea to remove the back and check for burnt/loose wires or terminals when these sort of thing occur. Look especially at the element mountings and the wires from there to the control console. Also the main block where incoming cord is attached.
Done. Replaced the element and thermostat tonight and all is well. I did pull the controller panel off and re-seated the connectors running to the elements and sensors
Also notes that,
Broiler problems can also affect gas ovens but this troubleshooting guide is only designed for electric ovens. Gas ovens are very different and you should not attempt to follow the same guide.
Reseating the Element
The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element
The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls
Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Good luck and hope this helpout......
  • 2,272 Answers
Check the side areas of each burner for small pinholes. These holes bring the gas flow and flame from the pilot into the burner.
VERY often these holes clog with use from grease, etc. Open them up with a small strand of wire or a similar probe.
If in doubt, examine carefuly the burners that work versus the ones that don't. You will see the open pin holes on the sides of the working burners.
There should also be a pilot tube in the proper position from the
pilot flame to each burner. Makes sure that the tubes aren't clogged at the non-working burners.---------
check out.thanks.
    Unfortunately, this still doesn't address the nonworking oven and broiler. When you turn either of them on, there's a pause before it gives the "start?" message. Then when you hit start, it looks like it's going to work: the temp shows "lo" and the igniter does start to glow orange. Then--nothing happens. If you don't turn it off, you start to notice a gas smell, so there is gas coming in, the igniter is working, but...I still think there is some connection between these disparate symptoms. I can't believe it's coincidence that the burners, oven and broiler would all develop problems independently at the same time. Are there any internal fuses or circuits that could be causing this?
    Genius:
  • 1,478 Answers
Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Also, if
heating elements eventually burn out. Sometimes, when an element burns out, you can see that the coil burns in two, or blisters and bubbles. When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too, but since you said the it is not igniters problem, you will need to replace the two item above to get your oven working.
Take care.
  • Jimoh Adeleke Muyideen Jul 22, 2010
    Clean the ignition system, it might be clog with dirt, to get at the ignition system, lift the lid of your stove.
    Give it a rap with the heel of your hand if it's stuck. If your stove
    has sealed burners, identified by the igniter or little nub at the back
    of each burner, the lid won't lift. Clean the igniter . If your burner
    still doesn't ignite. Identify a standing pilot by a
    small gas tube running to a tip with a hole at the center of two
    burners. If the pilot (flame) is burning.
    Identify spark ignition (igniter) by the ceramic nub either under the
    top or beside the burner in a sealed burner range. It clicks
    when it's working. Clean the burner assembly the same way for both spark ignition stoves
    and standing pilots. You'll need a small diameter brush. Set the assembly in place and try your burners.see if it solve the problem.
    Take care.
The gas is connected on the rear side of the stove but the pilot light is not lit, nor will it light. trying to trouble shoot the problem before deciding to purchase a new oven/range. Also, I remember...
You may have a pilotless ignition.Check around door frames for model #plate.
Also , open broiler door ,turn on oven and look inside . If you see an orange glow appear after awhile, that is the electronic igniter and you have an electronic ignition(no pilot).In this case the top burners use a spark ignition system.If you don,t hear clicking when you turn on a burner your ignition module might be bad.
Easily fixed though.
Aug 18, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts: https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10282172.pdf
Jun 18, 2011 | Maytag Ovens
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
My GE upper oven (Model # J KP27G002BG) just stopped working. No power light when turned on. The door light works. The lower oven works. Any ideas?
The lower burner in the top oven does not work, although the broiler does work. The broiler and lower burner in the bottom over both work. Could it be the burner element or would it be the relay board ?
Sep 10, 2009 | GE Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Dec 08, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
91 people viewed this question
Top KitchenAid Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Jim Goldsmith
Jim Goldsmith
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
