Question about Canon BJC 80 InkJet Printer
I am running Windows 7 Ultimate with a Canon BJC80, is there anyway to get the scanner facility to work, Canon drivers seem to end at Windows XP
  • 881 Answers
Usually, XP drivers works perfectly with Windows 7. You should just give it a try.
Posted on Jul 22, 2010
  • 265 Answers
If you can not find any driver that work with Windows 7, try to troubleshoot compatibility of the Canon scanner program, just right click on the program icon and you will find the option there.
Looking for driver MF5630 canon Win_64
I have spent hours to find a solution... there is no driver. But there are definitely 2 solutions:
1. MF5630 - using ONLY printer in Win 7 x64:
You have to use the drivers for MF5700 Series - http://driverscollection.com/?file_cid=4213082682609f383f81540957d
- http://www.techulator.com/resources/4156-How-add-Printer-manually-your-Windows.aspx
1. First, Click on the Start button in your screen, further click on Control Panel button and then double click on Devices and Printers button.
2. Then click on Add a Printer button in the menu.
3. Further select the Add a local printer button from the available menu.
4. Then choose an existing LPT port and click Next button .
5. Further select the correct driver from the driver list menu for your printer. Suppose if the requisite driver is not available then click on the Windows Update button. After the Windows 7 Update installation finishes in your computer, once again search for the appropriate driver for your printer.
2. FINAL SOLUTION - for printer and scanner - if you have proper PC configuration:)
Win7 has a possibility: http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7
you can install the WIN XP environment where you can easily install driver for Canon MF 5630 (or any other by Win7 x64 not supported printer/scanner) and additional software.
BUT YOU NEED to run: Windows 7 Professional, Enterprise, or Ultimate editions. Windows XP Mode is not supported on Windows 8.
Your BIOS must support Virtual Machine.
Jan 31, 2012 | Office Equipment & Supplies
Error code 0x24050010 Canon scan N640P in windows 7. please please help me...
What you need to do is run the driver setup in windows XP compatibility mode.
Right click on the setup icon, select properties, compatibilities tab then select Windows XP SP3 (or some older version of Windows.
Then left click on the "Change settings for all users" button and from the new window select again XP service pack 3 compatibility and check the "Run this program as an administrator". Click OK and then run the setup application.
It worked for me on Windows 7 ultimate.
Sep 16, 2010 | Canon CanoScan N640P Flatbed Scanner
No driver for Canoscan FB 630U Vista 64 bit
Unfortunately, it doesn't look like Canon supports this scanner under Vista. Check if the Windows generic TWAIN scanner driver will work. The Canon software won't work. If the generic driver can be installed, then you should be able to acquire scans in Paint (File > Import from Scanner or Camera), Windows Fax and Scan (New Scan) (some versions of Vista) or Windows Photo Gallery (IIRC it works like Paint).
I hope this helps.
(Canon wants you to upgrade. I have a different scanner that isn't officially supported past XP and the generic driver works fine. Unfortunately, you can't just use the XP driver in the compatibility mode due to the lack of signed drivers that are required in the 64-bit OS)
Jun 03, 2010 | Canon CanoScan FB630U Flatbed Scanner
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
Windows 7 driver
If you can't find it with google, it doesn't exist.
Jan 23, 2010 | HP Scanjet 4400c Flatbed Scanner
Install canoscan n650U with windows 7
sorry, none of the solutions listed above worked for Windows 7 on the N650U. will have to keep scanner on a stand alone computer with old Windows
Jan 19, 2010 | Canon CanoScan N650U Flatbed Scanner
I have recently purchased a new tower which includes Windows7. I have a Canon N650U scanner. I am having trouble installing it. Please help!
Unfortunately the manufacturer has chosen not to support this scanner under either Vista or Windows 7. If you have Windows 7 Professional or Ultimate, you can install the XP mode (a virtual XP computer). You will probably be able to install the scanner in the XP machine. The drivers are listed as being for Windows 98 and Windows 2000; I have never found any Win2K device that didn't install under XP.
You may need to save the images to an external media to transfer them from one "machine" to the other.
I hope this helps.
Jan 04, 2010 | Canon CanoScan N650U Flatbed Scanner
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
CanoScan N1220U Scanner Windows 7 64-bit Driver
You may use Hamrick VueScan Pro, it installs a driver that makes 1220 to work. Or, if the version of Windows 7 you use support XP Mode, install it.
It's still a good scanner, and mine is working in 7 x64 using XP Mode!
Sep 17, 2009 | Canon CanoScan N1220U Flatbed Scanner
Canon BJC 80 InkJet Printer Logo
333 people viewed this question
Clive
Clive
old marine
old marine
