I some how managed to change my mouse to only point to the things I want to do but I have to click the bar to get into things...i want to be able to tap the mouse again. How can I change it back? Thanks Julie
  • 487 Answers
Hi, go to start key, control panel and select mouse, from here you can change your mouse settings.
hope this helps
Posted on Jul 22, 2010
Logitech mouse right click too sensitive
Your computer mouse has preferences to make it easier to use. You can change the style and of the pointer, and you can change the sensitivity, which controls how easy or difficult it is to scroll across the screen. Speeding up the mouse sensitivity can allow you to move your cursor across the computer screen faster, while slowing it down can give you better control but you may have to move the mouse a greater distance to get your cursor to where you want it.
Click the Windows "Start" menu and type "mouse" into the Search field. Click on the "Change Mouse Settings" link in the search results. Click on the "Pointer Options" tab. Move the Motion slider bar to the right for a faster speed and to the left for a slower speed. Click "Apply" to apply the settings. Move your mouse to see if those are the settings you would like. If not, adjust the slider bar again. When you find the right setting for you, click "OK" to save the settings and close the window.
Jan 23, 2013 | Logitech Wireless Keyboard & Wirelss Mouse...
The blinking line in the address bar runs across the address bar causing my page to scroll all the way down and when i try to scroll back up the page bounces
Is this adress bar the internet search ?
This might be a mouse related problem
Make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected.
You might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers.
Click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
Right click you will need to update the driver.
Click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall
Make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
In XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
For the double or single click options to open folders this will be in the folder options follow previous to get to control panel items
Click start control panel navigate folder options tick in the double click to open circle
hope this helps
Nov 11, 2012 | Computers & Internet
My computer wont recognize new wireless mouse
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top or bottom also you might try safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
hope this helps
Nov 20, 2011 | Computers & Internet
My mouse is stuck. Cant click on the icons what should i do? i changed the batteries and still the same.
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver,rollback driver or uninstall in xp
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver in
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
Windows 7
hope this helps
May 11, 2011 | Computers & Internet
No mouse, how do i do the things like highlight that i used to right click with
Does the laptop have a touchpad (usually centered on the keyboard below the space bar) with two buttons above it? Then drag your finger across the selection to highlight it. Then click the right button.
It may take some practice. I usually end up getting a finger to register as moving to a new point on the screen when I try to move up to the buttons.
If you are still more comfortable with a mouse, get a USB corded or wireless mouse. Connect the mouse to a free port and use as you normally do. (Wireless mice can be a little tricky when the batteries run down or the receiver and mouse lose their connection.) If you have limited ports, a USB hub will usually be fine for connecting a mouse.
I hope this helps.
(Note: some older laptops need the touchpad disabled to avoid confusion. With Windows, Start > Control Panel > Hardware > Device Manager)
Dec 27, 2010 | Computers & Internet
The scroll bar on my HP pavilion zv5000 does not work.
no. not scroll bar.
you are posted that your desired pointing device
is bad,dead, and the do not want the built in device working,
your unnamed MOUSE is bad. right.
ALPS tells us nothing. (is it a GP-410UB " wild guess.
is it USB mouse or PS2? what model mouse? the number.
what OS are you running, we can not guess this... and matters. big time.
there are 2 issues on notebooks, zv5000
1: SHUTTING OFF THE INTERNAL ,POINTING DEVICE(S)
do that in device manager, click unwanted device
and click (right) PICK DISABLE .
it now dead this internal, pointing device.
2nd: option to is click Mouse (CP) and then pick the internal
laptop , mouse, and find a tab there called.
what to do with 2 mice, (on mine it has , USB mouse shuts off internal mouse, not all can do this, my HP8540 you can't but the maker of the notebook pad had and upgrade from this pad, and now has this feature,)
ymmv, your mouse may vary.
2: The mouse external. what ALPS, is it USB or PS2
finding drivers for very old mice can be hard,
did you have internet connections when you plugged in this mouse? if yes, it will attempt to find a driver automatically (PnP magic)
next time say.
a wild example.
Im running Vista OS.
My glidepoint model, GP-410UB does not work right.
help.
the Control panel. 101
has a mouse icon
and a device manager icon
this is your only controls, besides REG hacks.
we can all those, all ways, but you need to tell the helpers, OS, and mouse model first. and if USB
May 25, 2017 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I downloaded the synaptic mouse touchpad driver - and can no longer scroll up or down the screen without holding down the left click button. please help
Right Click the Synaptics Pointing Device Icon on your Task bar tray, click POINTING DEVICE PROPERTIES,it will open the Mouse Settings, Click the Wheel Tab and make changes as you want it
Thanks
Oct 25, 2009 | HP Compaq nc6220 Notebook
Compac presario mouse stuck when on desktop but not on log in screen. little box on task bar with red through box
Get an external usb mouse, once you have it plugged in restart the computer. Then go into the device manager and uninstall your old mouse, unplug the usb mouse, then restart. That should fix your problem. Let me know if you need more details.
Feb 19, 2009 | Acer Aspire 3680 Laptop
Frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Dec 29, 2008 | Toshiba Satellite L305D-S5895 Notebook
My computer is not decting my mouse anymore help
re install the driver for this mouse
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this than do this
  1. select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
Apr 02, 2008 | Logitech 9313960403 Mouse
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
