Question about Lincoln Electric K1297 AC/DC 225/125 Stick Welder
How to rewire a lincoln 225 amp welder - Lincoln Electric K1297 AC/DC 225/125 Stick Welder
bubby001
  • 18 Answers
SOURCE: Need a wiring diagram for a Lincoln Welder
try this page http://content.lincolnelectric.com/pdfs/products/navigator/parts/P72.PDF
if ifs not what you looking for heres the service number for Lincoln
1-216-481-8100
Posted on Oct 26, 2009
  • 474 Answers
SOURCE: Need wiring diagram For Lincoln Welder
try the company web site
Posted on Nov 11, 2009
falspet
  • 438 Answers
SOURCE: i have a lincoln 225 welder and when you plug a
the first thing with this situation is be vary careful this can KILL,
insure that the ground contact to your welder is of good quality, you might have a voltage induced in the metal frame of your welder by the large transformer(inductor) used to modify the voltage/current to a value you can weld with, with a good ground this will not happen, if the ground contact is poor, and you repair the contact, plug it in and it trips the barker, your welder is faulty by way of the primary coil in the inductor contacting the metal body of the welder, this is not worth repairing, also look for any wires that may have worn off its insulation and are contacting the mettle frame of the welder, a good ground will save your life, insure that all your power tools that have a 3 wire cord have a ground contact. good luck and always be safe
Posted on Apr 28, 2010
  • 6 Answers
SOURCE: Where do I find a replacement cooling fan for a
I took my old one to Grainger and they ordered a new one that is 230V. Total cost of motor and fan $27.00
Posted on May 04, 2010
  • 6 Answers
SOURCE: how do you wire the old lincoln 225 ac welder
What are you wiring? Power Cord? Fan? Transformer? You should see a white wiring block in the lower right corner if you are looking from the back. On the two top post the black and white wires are attached. The green ground wire is attached to the case. On the two bottom poles the fan lines attach one on each side and the transformer wires that are coming up from the transformer are attached on the same poles as the fan wires.
Lincoln electric ac/dc arc welder will not arc
Check the dial indicator. Sometimes if someone changes the amps while welding, there will be a break in the coil. It will work at a different setting as long as you are away from the break.
Jul 17, 2014 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Arc Welder AC 225 Wiring Diagram
won't have reverse polarity. There are only 3 wires, 2 power and one ground. It does not matter what power lead goes to what side.
Apr 19, 2012 | Lincoln Electric K1170 AC-225 Stick Welder
Coming out of the breaker box going to the welder plug what size wire should i use to run a lincoln 225 welder
It depends on how far away you are going to be away from the breaker box, using a #2 wire should be fine for your welder.
Nov 04, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln electric ac/dc arc welder model ac/dc
my welder doesn't weld but my electric meeter goes wild.
Jul 25, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
I just got a Lincoln ac 225 welder , IT came with no stinger cable or no ground leads I NEED to know were to hook them on the inside?
the stinger is bolted to the amp dial inside the unit,there should be a ground terminal for the ground in same area.
Mar 07, 2010 | Lincoln AC-225 230V
ARC 225 - Can't hear fan.
sounds like you lost one leg of power to the unit,check power source and the the plug on the welder.
Jul 30, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Lincoln Electric K1297 AC/DC 225/125 Stick Welder Logo
195 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
