Question about Peg Perego John Deere Gator HPX Ride on Toy
How to replace CV Boot on JD
How to remove rear axle to replace CV Boot on JD Gator XUV 620i
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on Jun 14, 2012
3 Suggested Answers
  • 156 Answers
SOURCE: how do i change rear tires of gator? axle rotates
I would take a pair of pliers and hold on to the axle while a loosen the nut from it.
I had the same problem, but I contacted the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
and they gave me that trick.
Hope this helps
Posted on Mar 16, 2010
  • 156 Answers
SOURCE: how do i replace the front axle assembly on my
The Peg perego Gator model has a complete axle assembly.
My grandkids ran into the curb and broke it, so I contacted the guys at
Hope this helps
I have a gator xuv 4x4 620i and it won"t start but makes a clunking sound instead
check starter bolts pull plug and do a compression test clunk in engine never good possible spun rod bearing
Jul 27, 2016 | John Deere 2010 Gator XUV 4x4 620i
How do I fix john deere 620I gator steering assembly
then why do you not look for the bent rod and unbend it or replace it .
May 26, 2016 | John Deere 2010 Gator XUV 4x4 620i
Have gear oil leaks under transmission in two holes next where the axel meets on each side
Keith the seals will need replaced, take into a shop and have a tech give estimate for repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
half shaft seal replacement Google Search
How To Install Replace Front CV Axle Shaft 2002 09 GMC Envoy and XL XUV
Part 1 How To Replace Front Axle Shaft Seal RH Front Chevy GMC
CV axle replacement Subaru Outback 2000 Legacy Forester Install Remove...
May 04, 2016 | Cars & Trucks
How do i adjust the throttle position switches on a john deere gator 620i
YOU DONT! Factory specs are need to test and set it!
First off what is the problem you are having????
All the TPS does is switch from one timing curve to the other on the cdi, and is also connected to the fuel management computer to tell it when to increase fuel delivery.
If you are having running problems start with old fuel, fuel pump pressure, and last if you have modified the airbox or exhaust in any way it will run like crap! On fuel injection you have to get a tunable fuel management computer when increasing air-flow or exhaust flow. The fuel injection is set from the factory based on the OEM parameters.
How many hours/ miles on your unit?
Have the valves been adjusted if it has over 200 hours of use?
are there any codes being flashed on display when key is turned to on position but not running?
Aug 29, 2014 | John Deere 2008 Gator XUV 4x4 620i
Won't start
hi, I will need a bit more info
Jan 05, 2014 | John Deere 2007 Gator XUV 4x4 620i
How to remove the bolts on the starter John Deere Gator 620i
This is what I did to remove starter on 620i xuv gator. Remove starter solenoid and use extension 3/8 drive with universal joint to remove top bolt or remove front half of plastic shroud over drive belt assy , drill hole into cover in line with top starter bolt, insert extension with socket onto top starter bolt. Be sure to cover drilled hole with suitable material.
Jun 30, 2012 | John Toys
Cv joint but the plastic thang that go around it
One would have to remove the half shaft to service the cv joint properly.
Oct 08, 2010 | 2004 Oldsmobile Alero
Peg Perego John Deere Gator HPX Ride on Toy Logo
1,527 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
