Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Our system is flashing 93 and we are not sure what that means or what we need to do.
93 is just an indication that the cycle has ended.It is standby mode.This is part of the normal cycle.You need to do nothing
Posted on Jul 24, 2010
How long should code 93 flash on the intex salt water system
It means that your pool has finished the chlorination process and everything is perfect! any other questions google will help you
Jul 15, 2014 | Intex Automatic Salt Water System for ...
How do I check engine codes on a '93 Nissan Quest?
Here is a general description on retrieving codes.
You will need to check online for the actual codes and their meanings. Systems built before 1996 will not show much compared to OBD2 systems built after 1996.
Turn ignition key on.
On Pathfinder, Pickup and Van models, proceed as follows:
    1. Turn diagnostic mode selector on ECU to ON position and wait until inspection lamps flash.
    2. Note number of flashes, then immediately turn diagnostic mode selector to Off position.
Feb 19, 2014 | 1993 Nissan Quest
What is rear abs code 16 for a 93 ford aerostar
Flash Code 16 from a 1993 Ford Aerostar Rear ABS unit means that the system is functioning correctly without any faults.
However, it should NOT be testing and flashing ANYTHING while you are driving unless the test connector/circuit is grounded or if there is an immediate system fault. The test connector is located behind the left side of the instrument panel and is taped (or at least, it USED to be) to the wiring harness. It is a BLACK connector with 2 mating halves. One has a BLACK/ORANGE wire and the other has a RED wire.
Inspect the connector to make sure it is plugged in and not corroded. Also check the wires to make sure they are not damaged or grounding inadvertently.
Make sure you are counting the number of flashes correctly. A fault code will be a series of short flashes followed by one long flash. For example, short, short, long, indicates a code 3. If more than one fault is present, it will output the lowest number code first. It will repeat itself until the ignition is turned off. For example: short, short, long, short, short, short, long, would indicate two seperate codes, code 3 and code 4, NOT a code 7, which would be indicated by six shorts and one long.
Apr 28, 2012 | 1993 Ford Aerostar Extended
On my intex salt generator I am getting a flashing code 93, can you tell me what that means? I lost my book.
Code 93 means "Stand-By Mode (Operating processed Finished).. Here's the link for Intex manual search and download... Find your model and click on the American/British flag to download.. Be patient, takes a little while to download...
Good luck and please take the time to write a comment or rate...
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?hid_windowname=null&lst_docsea=2011&source=intexstore&gid=2&lid=14313&hid_windowname=null
Aug 24, 2011 | Intex '10 Saltwater System Pool Chlorine...
What does the numner 93 mean when flashing
93 only means sleep mode
once 93 flashes long enough it will turn off completly even the 93
it will go back on 24 hours later ( when you originaly set the timer )
Jun 17, 2011 | Intex Automatic Salt Water System for ...
Where do I plug in my car to find out engine codes on my 93 dodge shadow
You don't need to, just cycle key, on (not start) off,on,off,on and leave in on position and count flashes of check engine light.
Will be a 2 digit number with pause in between. For example: 3 flashes, pause, 3 more, is code 33. 1 flash, pause, 2 flashes, is code 12. When you get 5 flashes, pause, 5 more, that's 55 which means end of message.
Sep 26, 2010 | 1993 Dodge Shadow
WHAT DOES IT MEAN IF THE GREEN LIGHT IS NOT ON? DOES THE SYSTEM REST AFTER THE TIME HAS RUN OUT, MY SYSTEM HAS 88 DISPLAYED
88 means you are filtering alone no chlorine
Once the generator is set it will run its time like 1-12 hours depending on what you set it at
After this time it will flash 93 meaning it is getting ready for sleep mode eventually it will shut that down and then turn back on at the same time you programed it the time before
There are 2 green lights
top one is that you are filtering
second one comes on about 2-10 minutes after you set the generator time this shows you are producing salt
Jun 14, 2010 | Intex Automatic Salt Water System for ...
What does 93 mean?
93 is sleep mode after the chlorine generator shuts off. to reset just unplug and re plug if you want it to go on at the same time and shut off again at the same time just leave it alone
Jun 05, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
Code 93 is blinking. lost manual. what does mean. does it need more or less salt?
93 meand "stand by mode - operating finished"......sure you got a zillion answers but I knew this one.
Jun 09, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
108 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
