Question about Archos 605 WiFi Digital Media Player
Archos 705 is displaying recovery code 108 was wondering how to fix this
  • adrian smith May 31, 2008
    every time i connect to pc to archos comes up with please enter code i do not have acode number
  • zilhaomarque Nov 12, 2008
    the same problem with archos 705 160 gb
Inky
  • 691 Answers
SOURCE: Archos 605 Recovery code 108
1. Download the latest firmware from Archos
2. Format the drive on your player
3. Connect the A605 to your computer using the USB lead
4. Copy the new firmware the A605's root folder (Drive X: on your PC or whatever letter was assigned to your Archos
5. Click ok and you are finished
Posted on Jul 03, 2008
  • 7 Answers
SOURCE: Archos 605 WiFi Digital Media
This is generally due to failed firmware updates, etc....here is something to try that has worked for some others:
1. connect the archos to the PC
2. click on repair
3. click on done and wait for a few seconds and you will see the archos as a drive in your windows (be patiant it takes some time)
4. once you see the drive, open it and make sure the System folder is empty, if not delete the file that exists there.
5. download firmware from archos website and put the firmware update file directly on the root of the archos drive
6. click repair again on the archos and done.
I've been told this does not always work on the first attempt, so give it a couple of tries if the first attempt fails.
Posted on Oct 19, 2008
  • 3 Answers
In order to fix this issue, we are going to need to force the unit into a
recovery application. In order to do this please make sure that the unit is
completely shut off. When the unit is off, you are going to want to press and
hold the TV/LCD button and the power button at the same time until a recovery
code 101 pops onto the screen. As soon as you see this, let the buttons go.
Once you got this screen up, you are going to want to repair the operating
system by arrowing down and clicking repair. After this is done it is going
to ask you to connect your device to the computer and install an update file.
In order to do this, you are going to want to go to www.archos.com and go to
downloads. You are going to want to download the firmware for your unit.
After the firmware is saved to your desktop, plug the unit into the computer
and open up "My computer" and you should see the Archos in the list
of drives.
Your going to want to copy the firmware onto the root directory and not in
any file folders. Once the firmware is on the Root directory, go ahead and
unplug the unit from the computer. It should still say Please plug your
device into the computer and install an update file. Click OK. After this is
done, it is going to tell you to please connect DC or USB in to continue with
the update. Go ahead and let the unit install and reboot. After this is
done, you should be able to use the unit properly. If the unit still does not
work properly, we are going to have to create an RMA for the Archos. If you
need anything else, Please feel free to contact us via Email or at
877.300.8879.
Posted on Nov 11, 2008
IPOD tech
  • 61 Answers
SOURCE: archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Posted on Mar 24, 2009
INTERLOGIC
  • 326 Answers
SOURCE: How can I fix Recovery
Posted on Jun 07, 2009
My archos is showing "error code 108" on the
contract your manufacturer about replacement as there is no way to fix this on your own
Jun 04, 2011 | Archos 605 WiFi Digital Media Player
How do I fix my archos cause it shows recovery code 108
I think for this one, you can reload the firmware. Ihave had to remove the battery and reset. So if you do that, moe your files to another drive if possible as you woudl have to restore them after a reset. Try firm ware first.
Feb 15, 2011 | Archos 705 WiFi Digital Media Player
How can I fix Recovery Code 108?
Jun 07, 2009 | Audio Players & Recorders
Archos 605 wife (wife firmware)
try this solution
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
Just got Archos 5 goes into error 101...
Hi there, these instructions are for the archos 705 but they are the same for the 605.
A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
B) The Archos 705:
1- Connect the unit to its power source.
2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
3- The recovery mode will start (the screen that asks for repair or format etc…)
4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
5- Now that you are on "Repair" select it to validate your selection
6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
8- Wait until Pc should recognizes your Archos (around 5 seconds)
C) Computer
1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
D) On the Archos 705:
1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
3- DO NOT DISCONNECT the power cable until the process is finished
4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
5- Press on/off button to reboot
Your unit should restart with a fresh repaired, updated system like day one.
Jan 21, 2009 | Archos 605 WiFi Digital Media Player
Code 108 shows on archos 605
The archos 604 is a portable media player. It is not a PC. The Archos 605 WiFi runs embedded Linux on an ARM processor.
Here is a reprint of someone who solved this problem:
i just got my Archos 605 and when accessed the content portal it said i should update my firmware. when i said OK i got the message it faild connecting to the server and my archos froze.
after restarting it i'm getting the Recovery code (108) i tried to repair disk and format disk but both asking me to conncet to the PC and update the system. the problem i cannot conncet to the PC (i don't see the HD) and don't know what to do.
i managed to solve the problem, if you encounter same problem this is what i did:
2. click on repair
5. put the firmware update file directly on the root drive
now it should recognize the update file and perform the update
it worked for me
Oct 19, 2008 | Computers & Internet
Archos 604 (not WiFi) connection to TV without the DVR station
HI, bought the following off ebay and they worked just fine. I to thought that the socket on the right side was audio only. Can't get a picture via my DVR (may be a fault) however this item works great.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=370172642094
Jun 06, 2008 | Archos 604 WiFi Digital Media Player
Feb 18, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 wifi 30 gb
ave got same prob mate tried to download the firmware as red on the archos site in questions and answers fairly helpful but my computer does not put the archos on my desktop for me to transfer the files rang archos in holand apperently it means it is faulty and i am n the process of sending mine back advise you o rinng them on the 02 n0. that came with the item goodluck
Jan 31, 2008 | Archos 605 WiFi Digital Media Player
of drives.
877.300.8879.
Jan 10, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
172 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
