Combining two partially full hard drives
I have a desktop pc running Windows XP pro. It has one hard drive, 20gb which is running out of space. The HDD is a pata IDE, set as master.
Can I install (set as a slave) a second, 60gb HDD (same type), from an older computer, which still has 45gb of free space on it? I would like to use this space and also would like to access the files on it. It too ran on wxp pro. Can I do this without resetting partions and Bios settings? As I boot from the master anyway, I would remove the redundant OS from the larger disk after install. Any info would be appreciated. Thanks much.
  • 3,153 Answers
Yes you can is the short answer.
However If I were you I would be tempted to invest in somthing a little larger
Then CLONE your first drive to your second one (second one being clean) and then just set the new one as master or if you are using the CS (cable select) jumpers on your hard drive swap the connections over.
The advantage would be increased speed that should prove notcicable.
Even if you do it with your 60 GB I would do somthing similar by transfering what you need from it to the old one then wipe it and then clone the old one to the new one.
For clone software there are quite a few FREE packages around but I tend to use clonezilla or those available on the "hirens" boot cd or the UBC available here
http://www.ultimatebootcd.com/download.html
Bob
Posted on Jul 22, 2010
Testimonial: "Thanks Bob, I will pick up a new HDD and consolidate all I need to keep. I will then make the 60gb clean and available."
    Brigadier General:
  • 10,406 Answers
Yes, your plan is feasible.
However, any 20GB disk-drive has a warranty that expired *YEARS* ago. So, that disk could "crash" at any time.
So, consider buying a brand-new PATA disk-drive, which comes with a 3-year warranty, temporarily disconnecting the "old" drive, connecting the "new" drive, installing Windows onto it, and then making your "current" disk-drive into a "slave" disk-drive. Reconnect the "old" drive, and copy all your "data" from the "old" disk to the "new" disk.
Note that if you buy a SEAGATE/MAXTOR disk-drive, their MAXBLAST software can automatically copy "everything" from the "old" disk to the "new" disk, and will expand the partition from 20GB to the maximum size of the new disk. Very slick!
Then, disconnect the "old" drive, and boot from the "new" drive.
Testimonial: "Thanks much, Sounds like a good plan. I keep forgetting I can buy a 250gb or 500gb HDD for a small amount of money these days. "
    President:
  • 2,678 Answers
Can't see any reason why not.
Hard Drive is full
if the Hard Drive is full you need to remove some software or any large file from the computer to free up some space on the Hard Drive , may want to buy another hard drive or get an External hard Drive to help with the space problem .
Jan 27, 2011 | Dell Inspiron 530 (883685981020) PC...
When i connect my drive to my pc using windows xp in show Found new hardware searches for drivers and completes the search. but when i go to my computer it does not show up
Windows XP can only see up to 120GB. If you can partition the drive in 4 X120GB and 20GB XP will see five drives. If you need to use the full 500GB, you will need to upgrade to XP with SP3 or Windows 7
Jan 26, 2011 | LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB...
Looking for possible hard drive how hard is it to self install --with windows xp
A few simple steps:
0. find your original Dell "System Restore" set of CD/DVD disks, or order a replacement set from Dell, or run software on your computer to burn a set of "System Restore" disks.
1. do an "inventory" of installed programs (Adobe? MS Office?) and extract any "license-keys" you need (anti-virus software, purchased software).
2. backup your E-mail and contacts and music and other files, either to an external disk-drive, or burn some CD/DVD disks, or copy across your local network to another computer.
3. turn the computer off
4. disconnect the AC power
5. remove the battery
6. remove the old disk-drive
7. determine if it was an EIDE ("parallel-ATA") drive, or a SATA drive, and buy a new drive of the same type
8. mount the new disk-drive
9. reinsert the battery
10. reconnect the AC adapter
11. take your "System Restore" disks, and "boot" from the first disk, and reinstall Windows and the Dell applications
12. run Windows Update repeatedly (Service Pack 3, post SP3 fixes, Internet Explorer 8) to get all the fixes, and the fixes-to-the-fixes
13. install anti-virus software
14. install other purchased software, using license-keys you preserved
15. download the latest versions of "free" software (iTunes, Adobe Reader, WinAmp, et cetera)
16. import your "data" files
OR.................
if both the "old" and "new" disk-drives are SATA, and you have a desktop computer with two "unused" SATA ports, you can use software, such as the commercially-sold "Partition Magic", to "clone" the old disk-drive, and to "expand" the volume to span all the "unused/unallocated" space on the new drive, e.g., copy 20GB from "old" to "new", and then "expand" the 20GB partition to the full size of the "new" disk-drive. Install the new drive into your notebook computer, and enjoy the additional "free" space.
Sep 07, 2010 | Dell Latitude D600 Notebook
Tried to install a used 20gb working hard drive
I think that you have to reinstall the XP os on the hard drive again.
Nov 30, 2009 | Dell Optiplex GX60 PC Desktop
I had reinstall windows,now i only have 1%of disc space
You allocation of partion is too low while the time of os boot , so the only way is you have to change partion space , use this number during partition 60555 MB this 60GB so you cant get full easily , you have to run the DOS mode booting then only you can get the partition location , you may be runned the os from normal opening cd setup mode from already booted os , for further clarifications reply me , i will help you , thank you , dont forget to vote for me .
Nov 02, 2009 | Computers & Internet
OLD FILE IS LIVING
because you didn't delete the old partition on the drive before istallation, when you goto install it inspects hdd and find other windows OS's before you setup a fresh install you hvae to get the blue screen to show all space as unpartitioned space then install as you did before
Apr 29, 2009 | Intel Motherboard
Ms office won't open gives there is not enough memory disk space full message but memory no where near full
Depending on how much disk space you have left onyour hard drive, Microsoft Home and Student requires at least 1.5GB offree space. I've posted the minimum system requirements below, you willneed these to run Office Home and Student 2007.
Minimum Requirements: (View on Microsoft Website)
  • 500mhz Processor
  • 256 Memory (RAM)
  • 1.5GB of Free Space (Hard Drive)
  • CD/DVD Drive
  • Display: 1024x768 or higher resolution monitor
  • Operating System: Microsoft Windows XP with Service Pack (SP) 2, Windows Server 2003 with SP1, or later operating system
Mar 15, 2009 | Microsoft Office Professional 2007 Full...
Does Belkin transfer programme files?. Also I want to know if this product transfers from XP to XP, desktop to desktop. Basically, I am moving from a 20gb to 80gb hard drive and want everything to be in...
A transfer cable kit will only transfer files and settings to another computer. What you want to do is have your 20GB hard drive imaged to a clean 80GB hard drive. That would transfer everything and give you extra space.
Some people call this "Ghosting" using a product from symantec called "Ghost" and another product that can be used for free (home use) would be "Drive Image XML" .
I would suggest going to your local Computer Shop and requesting this type of service.
Mar 13, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
