Question about Samsung DVD-R155
My dvd drive will not open. What is wrong
  • Samsung Master
  • 2,005 Answers
There is a tiny hole on the tray; push a straightened paperclip in the hole to open the tray.
Posted on Jul 22, 2010
I inserted a DVD wrong side into NEC TV NLT-!9HDDDV3. How do I remove it?
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Mar 29, 2013 | Computers & Internet
Laptop PC - DVD drawer wont open
just try this !!
there's an small hole beside eject button on your DVD drive tray.
take a small pin and push it into this hole move it around it will open.
this is for opening DVD drive manually if something goes wrong.
try this if doesn't help then goto service center. Generally they won't charge you for this.
Jan 23, 2013 | Computers & Internet
How to remove the DVD drive
Turn off and unplug the laptop, some where on the bottom of the laptop will be a single screw, about 5 inches from the DVD drive edge of the laptop, remove it, it may be a long. Once that is removed, open the drive's tray, using a paperclip (stick it into the "very small hole" in the front DVD drive draw, and press it in slowly...) the door/draw will open. Grab the door/draw and slowly pull out, IF it doesn't come out, you may have removed the wrong screw... try again.
Jul 17, 2012 | Toshiba Satellite A65-S1065 Notebook
I have a Compaq SR1650NX (Windows XP Media Center with MS Office 2003) computer. My DVD+RW will not open. I can open it manually but my computer does not recognize the DVD. If I change out the DVD+RW,...
There is nothing wrong if you want to replace it with generic or branded DVDrom drive. As long as compatible with your motherboard. If you are using IDE or UDMA cable you must buy IDE DVDrom drive but if it's SATA cable you have to buy SATA DVDrom drive.Good Luck
Nov 26, 2010 | Computers & Internet
My xbox keeps saying open tray, or even if im lucky enough for it to load it says disc is unreadable. what shall i do???
replace the dvd drive. there about $35. open the console and remove the dvd drive, buy the exact same one. you can avoid having to flash the drive by taking apart the old drive and removing the com board inside and putting it in a new one. there is a link on how to open the xbox and fix the dvd drive. Thanks and please vote
Oct 17, 2010 | Microsoft Xbox 360 Console
CD opens itself and closes
Either something is wrong with the physical open/close sensors, or there is a computer-virus on your computer that is intentionally causing the open/close actions.
May 31, 2010 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
My dvd drive doesnt open on my Compaq Presario SR2150NX, i finally got it open with the manual open, but im trying to install windows 7 on it, but when i try it says theres something wrong with something...
Check to see if the DVD drive is connected to the power supply and the IDE connectors.
Can your dvd drive be displayed in "My Computer"
If yes, then it is connected, so, you will have to reinstall the drivers. They could be corrupted?
Thank you for using Fixya,
Kenneth
Jan 17, 2010 | HP Compaq Presario SR2150NX PC Desktop
DVD drive
Hi usually when the light stays on this means the cable is the wrong way round the same problem occures when you get the floppy drive lead the wrong way round.
If the dvd drive came out of a working computer then the jumper settings were probably correct if the cable can go the other way round try that.
The only other problem you can have is are you building an ibm compatible computer if you are is the dvd ibm compatible if this is also not the problem then the chances are the dvd drive is damaged.
Do you have a normal cd drive in and working if you do try using it in the place of this if this still dont work then i would say the unit is dammaged.
check the leads not damaged but what you are explaining sounds like the lead is wrong way round let me know how you get on ok
Nov 27, 2007 | Televison & Video
Wrong region
open the control panel then double click system, click the hardware, open the device manager then click (+) of dvd rom drives right click to open the properties. you can see the region, you can now change the region according to what country you are. you have only 3 changes to make with the region
Nov 01, 2007 | RCA DRC620N Portable DVD Player
Samsung DVD-R155 Logo
264 people viewed this question
Jerry Greenberg
Jerry Greenberg
