Question about Apple AirPort Extreme Router
Apple extreme router will not find the new ip addresses for the new motorola cable modem? when modem is connected directly to my mac everything wors fine?
    Brigadier General:
  • 10,406 Answers
Turn the cable-modem off.
Turn the router off.
Turn your computer off.
Turn the cable-modem on, and wait until its lights settle-down to the usual "pattern".
Turn the router on, and similarly wait.
Turn your computer on, and similarly wait.
You should now have Internet access.
Posted on Jul 22, 2010
Hi. I have a Motorola SB 6121 DOCSIS 3.0 cable modem. When I have a direct connectivity with this modem to the laptop with an ethernet, it works fine. But when I connect it to the Linksys wireless router,...
what is the ip address of the cable modem ?
when connected directly to the modem can you do ipconfig in dos command window and find out the gateway ip address listed.
This has to be the gateway ip address in the wi fi router.
turn of DCHP server in the WI FI router and make its ip address one more than the cable modem ip address.
make sure subnet mask is the same in both devices
Make sure DHCP server in Modem has leases above 20 to allow other devices to use 1 - 19 .
eg 10.0.0.1 or 192.168.0.1 for cable modem ip address internally.
make wi fi router 10.0.0.2 or 192.168.0.2 depends on the ip address of modem ?
Gateway address of 10.0.0.1 or 192.168.0.1 depends on the ip address of modem ?
dhcp server leases from 10.0.0.21 to 10.0.0.254 depends on ip address of modem ?
Feb 22, 2018 | Computers & Internet
I connected WRT54GL router to Motorola modem per linksys instructions. the router is not able to connect to the internet. please advise
This is most likely due to the Motorola modem still having the Media Access Control (MAC) address of the device that was previously connected the modem in NVRAM.
In order to clear this old MAC address, the easiest thing to do is to unplug the power cable from the modem for 15 to 20 minutes. This allows the NVRAM in the modem to clear and makes it able to accept the new MAC address of the router.
After the modem has been unplugged from the power for 15 to 20 minutes, plug the Ethernet cable of the router into the modem and plug the power cord back in to the modem. After the modem syncs back up to the network, it should add the MAC address of the WRT54GL router to its NVRAM and assign it an IP address. This should allow the router to connect your systems to the Internet.
Dec 27, 2010 | Linksys Wireless-G WRT54GL Router
DHCP problems for wired devices on my network
It sure sounds like the switch is not passing the DCHPDISCOVER packets through to the Apple Extreme.
Is the switch a NetGear Prosafe switch, or a GS608, or a different model?
If it's a managed switch (e.g. ProSafe) then you can connect to the switch's management UI and confirm that the default uplink port is set up for the port that connects to the Apple Extreme, and that it's set to forward DHCPDISCOVER packets to that port
If it's an unmanaged switch like the GS608, then it shouldn't matter which port you connect, but if your model has one port labeled "uplink" then you should be sure to use that port to connect to tha Apple Extreme.
One last thought -- have you replaced the cable that you're using between the switch and the Apple Extreme? You could test the network by first connecting your computer to the Extreme so it gets a valid lease, then unplug it and hook up the full network (computer -> switch -> Extreme) and see if you can still ping the router.
That's a bunch of thoughts, but may not be a solution yet. If these don't address the problem, post back with the model number of your Switch, and I'll go more in-depth.
Feb 12, 2010 | Apple Computers & Internet
I need to reconfigure the Netgear router
There isn't really much to configure on a cable modem. If the modem is fully recognized by the cable provider (all lights are lit on the modem once connected to the cable (coax) side), then just plugging in the Netgear router's INTERNET connection directly into the cable modem will work fine. If the modem isn't properly recognized, you'll have to call your cable company and provide them the MAC address of the cable modem. The MAC is a 12 digit hexadecimal (0-9,A-F) number that should be on a sticker on the modem itself - it will be listed as six pairs of hex digits. If the cable company doesn't have that particular MAC address attached to your cable account, then it won't work.
Nov 10, 2009 | NetGear RangeMax WPN824 Wireless Router...
My computer can see my router but can't get past my modem
1. delete all the saved networks from your computer
2. Make sure that firewall id disabled in computer
3. Tried to set your wireless as unsecured network and try to connect
4. Uninstall/Reinstall wireless adaptor and tried.
Aug 05, 2009 | Belkin (F5D7230-4) Router (587009)
I have a Motorola SURFboard SB5101 Cable Modem a Netgear mr814v2 wireless router, I obtain the ip address on router status but for some reason my internet communication losed. I verified the configuration...
Hi, follow the steps below to configure MR814 with your motorola surfboard:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.0.1
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 29, 2009 | Arris SURFboard SB5101 Cable Modem
Apple AirPort cannot get IP address from cable modem using DHCP
go to applications,utilities and go to airport set up and check the settings, it could need the DHCP setting up or the old settings deleted
May 24, 2009 | Apple AirPort Extreme Router
Router not recognizing internet connection from cable modem.
No, you do not need a Hub. You also should not need to add the mac address. On the router, you need to enable DHCP so that your PC can get its IP address from your router. Then try your reboot again. Modem------------->Router----------------->PC. Wait about 1 minute between each device for them to sync up. Make sure that your PC IP settings are set on obtain IP address automatically under Control Panel----->Network Settings
May 11, 2009 | Intellinet Active Networking (522212)...
Router/Modem IP
Try 192.168.1.1 or 172.16.1.1
Mar 14, 2009 | Apple AirPort Extreme Base Station
Change ip
Your IP address is assigned (leased) to you from your internet service provider. With that being said, you could possibly call them and ask to release your old IP address and have them assign a new one. If you happen to have a static IP address assigned from your ISP you can call them as well and ask to have your IP address changed too. It would be up to them to change it though.
Sep 14, 2008 | 2wire (1000-400108-001) Router
Apple AirPort Extreme Router Logo
226 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
