Question about Sony Cyber-shot DSCW210 Digital Camera
Zoom error only zooms to 1.0 then tells me to turn camera off
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 22, 2010
Fujifilm finepix a820 zoom error ... i turn the camera on and it wont focus... message on lcd screen is zoom error. it will not take picture and when i turn it off agan the zoom bit wont go back inside
    This problem is related to the malfunctioning of zoom motor, Two possibilities are there,
1- If company provides technical help on component leve in your regionl then zoom motor may replace.
2- If component level support is not available then LENS ASSEMBLY must be replaced.
   Contact your nearest fuji service centre or contact any expert nearby for the specific part replacement.
    Thanks for using fixya.
Oct 28, 2009 | Fuji FinePix A820 Digital Camera
My Sony Cyber-Shot DSC-W120 Super Steady Shot zoom won't work!
Follow this procedure to troubleshoot if the zoom function does not operate.
NOTES:
  • The zoom function will not operate with some AE modes.
  • The zoom function is not available while shooting a movie on all cameras. Refer to the owner's manual for information regarding the functions available on the camera. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Change the Auto Exposure (AE) mode on the camera.
  2. Ensure the camera is not set for movie mode.
  3. If the camera has a conversion lens setting in the menu, set it of OFF.
  4. Reset the camera back to factory settings. To reset the Camera, please select Initialize under Settings and Main Settings 1.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Sep 20, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
My FINEPIX s1000fd fujifilm camera displays zoom error! in red and won't take pictures please help. We put new batteries in and think I have all the settings right thanks ellen
Try these:
1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error"
2) Recharge or fit new batteries. Use 2700 power if you can get them.
3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy!
4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism.
I have used my S1000fd lots now, and the initial "zoom error" problems have stopped.
It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Dec 26, 2008 | Fuji FinePix S1000FD Digital Camera
Zoom Error
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Aug 03, 2008 | Pix FUJIFILM Fine S1500fd Digital Camera
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Zoom error
You have to make sure you take the lens cap off first before turning on the camera.Cheers Sandra
Mar 02, 2008 | Fuji FinePix S5500 Digital Camera
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Sony Cyber-shot DSCW210 Digital Camera Logo
32 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
