Question about Mercury KVM266PM-U (KVM266PMUD1600) Motherboard
When i press cpu on button. monitor is not starting, nothing happen on screen
    Problem Solver:
  • 7 Answers
1.Check Any beep sound from comuter?
2.check hard disc signal light on working?
3.reset your cmos battery clear and clean memmory(ram)
4.change your smps
Posted on Sep 14, 2010
    President:
  • 739 Answers
Problems that you experience most often occurs on the computer,
To determine whether this problem occurs because one of the hardware in your computer casing,
first, you must make sure that your monitor is 100% functional.
If it's been identified, and proved your monitor no problem, this means that the problem comes from the hardware in your computer casing.
ways to identify where a hardware problem,
you should make troubleshooting prior to each of the hardware in your computer casing.
troubleshooting steps.
> Open the casing cover your computer and remove the ram in the ram slot on your computer by pressing the two pins at the end of slot (Make sure the electrical power source is turned off first)
> Sweep ram slot with a small brush or small paint brush is not used (new)
> After cleaning the ram slot, use the eraser to clean the copper surface on the ram you are.
> When you're done, plug the ram in the slot. (If you have a new ram to do the troubleshooting is better)
> Reattach the power source on your computer and then switch on your computer.
> Still not working?
> If you use the display card, remove the display card and do the same as you did on your ram and ram slots.
(If you're not using the display card, the better you get the display card to make the process of troubleshooting)
>Turn on your computer.
(If your computer is still experiencing the same problem though has to do the troubleshooting on the display card)
> Get at / ATX new power supply to do troubleshooting, (damage to the power supply will also cause the computer not display
If the computer still can not function normally means that you have the problem still appears,This requires you to perform more detailed troubleshooting process. First, you need to provide a motherboard and processor is still working (new) to do this process.If you already have all the equipment, you can start to make the process of troubleshooting your hardware one by one.I believe there is enough equipment for you to perform troubleshooting, problem you will be able to identify you and you will be able to solve by itself.
good luck
Posted on Jul 23, 2010
I just took all the cables off in order to move the monitor and CPU. WHen I hooked everything up again the monitor did not come on as it has in the past. I tried pressing the On button which I assume is...
Recheck your cables, particularly the VGA cable, it may not be seated well. Also, make sure the AC cord is fully seated at both ends since all modern monitors will put a warning on the screen even with no video (or sync) input to notify you that the monitor is ready but has no input. If nothing works, you may be the victim of a switching power supply in the monitor that will not start up any more.
Jun 21, 2011 | LG Televison & Video
When I boot up my PC my Acer monitor says "auto config please wait" then goes black. It works just fine through the boot up until it gets to the login screen. That's where it eventually goes...
Try power off then power on your PC press F8 choose highlight safemode press enter. if nothing happen no display on screen your CPU have problem contact service center for that CPU.
May 28, 2011 | Computers & Internet
When you press power button, computer does not boot up. only orange light blinking on and off.
Possible bad power supply. Unplug and let sit for 2 minutes. If you push the button again, and nothing happens; then replace the power supply.
Jan 06, 2011 | Dell OptiPlex GX620 PC Desktop
My computer will not *** on after the start screen
check this monitor with another cpu i feel there is some issue with the vga card of your system...
Feb 25, 2010 | Hanns.G Corporation HW173D Monitor
My Display has nothing showing and the Power Button has a flashing green LED...Can you help?
This usually happens when there is some video resolution conflicts occurs. Try to start windows in safe mode and then making a lowest resolution applied.
If you are unable to start windows. Try removing its data cable from cpu. and check whether there is any display on the screen.
Also check its pins..
Jan 16, 2010 | Samsung SyncMaster 244T 24" LCD Monitor
Can't start my computer
does the monitor is getting on....do you see anything in the monitor?
Mar 05, 2008 | Computers & Internet
Black Screen on ACER LCD 1916 Monitor
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem . bye
Sep 25, 2007 | Acer AL1916W 19" LCD Monitor
NO PICTURE
Blank screen on my monitor. Need help plz.ty.
see there is power in monitor and check also that your monitor is getting signal from cpu just remove the data vga data cable from cpu and see is it showing any massage on screen like check signal or any other massage. and check your keybord also by pressing num lock key see the light is on and aoff when you pressing the num lock button . if nothing is happen that mean your monitor is not getting signal from cpu and it is not monitor problem bye
Sep 13, 2007 | Acer AL1916W 19" LCD Monitor
I closed my computer maually after a bug then put it back on. My monitor is still black.
Mercury KVM266PM-U (KVM266PMUD1600) Motherboard Logo
128 people viewed this question
Top Mercury Computers & Internet Experts
Mark Gough
Abhinandan  Patil
Abhinandan Patil
Alun Cox
Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
