Question about White Sewing 1415 Mechanical Sewing Machine
Can't remember how to load the bobbin
Obviously, none of us are seamstresses in our home. We wound the bobbin but can't remember how to load it. There's the bobbin casing which we loaded the bobbin in, but then there's a metal ring that fell out or dropped out when my daughter took the empty bobbin out, and you would think we could use common sense to fit everything back in. Alas. I've spent the last half hour manipulating the ring and casing to no avail. Any help would be appreciated!
k
p.s. I'm not positive that this machine is a White 1414, but it looks similar.
  • 980 Answers
If you have the seperate bobbin case that goes into the raceway, that is the bit which should have a black clip either side, make sure the needle is at the top , with the two black clips open the gate can be dropped down or taken off, the half moon shape shuttle should fit in quite easily, put the gate back up and put the clips acrosss to hold it in, take the bobbin case by the latch with thumb and forefinger and pop it in.
Posted on Jul 23, 2010
Embroidery machine bobbin not picking up thread
If you thread is coming out all tangled continue.
I Had this problem and found I had missed one leg of the threading.
I had an experienced seamstress look at our portable and could not get bobbin working. I took thread and redid it ,seems I had missed leg that went down.
she did to now all is well.
Sep 21, 2016 | Sewing Machines
Bobbin winder not working
none I have ever had CATCH the thread . you have to thread to the bobbin and hold the end till it gets a good start .
Feb 12, 2016 | Sewing Machines
Used machine recently but now no matter how carefully i load everything, bobbin pops out and thread tangles
Check that you have put the bobbin in the correct way. check that it is the correct bobbin for that machine and you could also check that the bobbin has been wound properly. If you load your bobbin up with different threads and not let if fill with only one thread you can have problems. Also clean out the bobbin area sometimes a bit of fluff can be caught in the bobbin area. cheers Dot
Sep 23, 2015 | Sewing Machines
I can't remember how to wind a new bobbin
there should be a spare thread holder on the machine and a bobbin mount near the drive wheel of the machine. The bobbin goes on the bobbin mount which is pushed onto the drive wheel in order that it is rotated. the thread should be wound onto the bobbin and the the motor should be actuated. This should wind the bobbin. This is usually done with the thread out of the needle.
May 25, 2015 | Sewing Machines
Thread a bobbin?
usually put the bobbin in the bobbin case insert in machine then turn by hand the right hand wheel the needle thread picks up the bobbin thread and pulls it to the top by the presser foot where the seamstress can get ahold of it
Apr 27, 2015 | Brother Sewing Machines
If everything else has been fixed/checked will a bad circuit board cause and elna 9000 need not to pick up bobbin thread
if you've tried a new needle
rethreaded the machine top and bobbin
make sure the bobbin is wound correctly
make sure the bobbin is inserted into the bobbin case correctly
if none of these suggestions help, then it would be a good idea to have the circuit board checked..
Mar 23, 2015 | Elna Sewing Machines
Why is thread is making multiple loops around bobbin
are you using pre-wound bobbins? or bobbins you've wound yourself? they might be too full or over wound (too much thread) this happens with pre-wound or some you've wound yourself. Also make sure you are loading the bobbin correctly. You also might try another bobbin, as sometimes they can get warped if they are the plastic kind.
Jun 27, 2014 | Singer 4423 Sewing Machine
White D'Lite Can't load wound bottom into machine. Manual is confusing. Need clear details.
I suggest checking youtube for a video
also make sure the bobbin is not warped or bent or damaged
make sure the bobbin is not over full
if none of this helps, then take the machine to a sewing machine repair shop to be checked, to see if there is something wrong with the hook and hook race.
Oct 03, 2013 | White Sewing Sewing Machines
Won't sew! Loads of top thread bundles up around bobbin casing.
First... make sure you are threading it correctly. It MUST be threaded with the foot up.
Do a test seam. Make sure you put the presser foot DOWN when you sew.
Make sure you grasp and hold the bobbin and top threads as you begin the seam. (this is good practice for any seamstress on any machine.
If you still get loops, tighten top tension.
Also check the bobbin case for burrs. drag a finger nail along edges to feel for it catching. If you find one take a small bit of extra fine sand paper and file it off.
Good luck
Nov 12, 2012 | Sewing Machines
My Janome sewing machine 4900 is showing error E1 how do I fix it.
try these suggestions
change the needle--normally flat side goes to the back of the machine
rethread the machine top & bobbin
make sure the bobbin is wound correctly & that the bobbin is inserted
correctly in to the bobbin case
also make sure that the bobbin spindle is in the position to the left when not in use
clean under the needle plate & in the bobbin area for lint or loose threads
if none of these suggestions work then the machine needs to be checked
Apr 10, 2012 | Sewing Machines
White Sewing 1415 Mechanical Sewing Machine Logo
159 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
