Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
Epson Stylus Photo R425 will not print. Screen says "Paper jam" but no paper is visible. All docs. have been cleared from the document queue. A whirring sound occurs when trying to print. Any advice please.
    Problem Solver:
  • 10 Answers
Please turn-off your printer and disconnect from PC then get a flashlight and try to look inside the printer starting at the paper loader mechanism. Try to look for paper or any materials that could have blocked a sensors path. Often this are not easy to spot and difficult to remove.
Contact me if this doesnt work.
Posted on Jul 22, 2010
  • fx3000 Aug 23, 2010
    I have a more or less similar issue with my RX425.
    The printer works well scanning wise, but the printing jobs have always been kind of dramatic.
    It prints for one or two pages and then I have to put my hand in the paperfeeder to push the black sensors. Resetting it by clicking the "Start/Color" button on the top.
    Now a days it gets even more serious; after doing the above action it gives me a rattling noise to be out of order showing me the "E" on the led display.
    Thank you all for your support and feed back.
    As this is an error message telling this is a general fatal error it needs to be restarted.
    Nonetheless it's over for quite some time before I can even print one other page.
  • 5 Answers
Its simple Just move printer head to the right whereever it is .. Forcefully move to the right most of ur printer ..it will not damage ur printer but will solve ur problem...
Posted on Aug 26, 2010
I have a "printer error"
sometimes the paper can get stuck way at the back of the machine out of sight and it might be all crinkled up and stuck , the noise that you are hearing at start up is probably the rollers going through a pre-spin check that identifies problems like a paper jam etc you will have to remove any covers and expose as much of the internals of the machine as possible and open and trays and compartments that will allow you to use a torch to inspect the paper route and follow it path
Oct 28, 2017 | Epson Stylus Photo RX680 Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My Epson Stylus Photo RX580 had a paper jam. I cleared it but now the screen keeps saying "Printer error has occurred. See your documentation". I've turned it off a few times and I don't know what needs...
1. turn it off & disconnect from computer
2. open printer & check for any obstructions
3. load a sheet of paper, press & hold the paper feed button while turning the printer on
4. it should print a test page, else the printer needs service as there might be some no-user serviceable parts inside that got damaged by the paper jam.
Apr 05, 2010 | Epson Stylus RX580 InkJet Photo Printer
"Clear paper jam" error, but there is no jam!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
May 25, 2017 | Epson Stylus Photo RX620 All-In-One InkJet...
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Photo paper jam on Stylus 4800
Here are some things to try. Place no more that 15-20 sheets in the printer, ensure they are fully to the right of the carriage and the paper is held securely on the left. You may wish to 'fan' the paper to ensure it will flow freely.
Sep 21, 2007 | Epson Stylus Pro 4800 InkJet Printer
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
1,107 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
