I have a 74v DC to 110v AC converter and I would like to know how many amps I can expect out of it? I am not sure how to calculate it.
  • 677 Answers
Locomotive systems run at 64 VDC. The 74Volts is there when the engine is running jst like on a car where the 12 volt battery is actually being charged a little higher, around 15 or 16 volts. Enough on that though.
Most of our battery systems consist of two 32 volt batteries connected in series and most of our starters are 32volts also connected in series except for a few locomotives acquired through mergers which have two 64 volt starters hooked in parallel.
As far as running things in the cab. Most of our cabs have what looks like a standard 110 volt outlet in them for running test equpment or whatever. There is 64 volts dc at these outlets and we have plugged regular 110 volt computer power slupplies into them for running laptops with no problems although I would not say that this would work on every one and I would be a little afraid to try it on one of my own computers for fear of burning something up.
Posted on Jul 22, 2010
  • ikechukwu joshua
    ikechukwu joshua Jul 22, 2010
    I guess what you are thinking is: Can I use a Locoverter to convert
    74VDC down to 12VDC and then add an inverter to step up the 12VDC to
    110VAC...?
    In theory, yes, (although not very efficient) but looking at these
    locoverter products, I don't believe their current is enough to then run
    an inverter.
    Consider, if you want 110VAC and 100 Watt, your 12 VDC supply must at
    least deliver 10 Amp!
    If you are desperate and skillful enough then you are probably better
    off building a 74VDC to 100VAC inverter yourself, something like
    http://www.interq.or.jp/japan/se-inoue/e...
    But of course, you need to make sure the DC side (component
    specifications) can run at 74VDC, and the output transformer should be a
    110 / 75 Volt type.
Massage chair national real pro 110 volts was put into 220 volt. Where can i see the fuse ?
Search Results
    replacing that AC/DC converter : voltage divider ? ' Electronics ...
    www.electro-tech-online.com/.../replacing-that-ac-dc-converter-voltage-...
    Jan 23, 2012 - 6 posts - ‎4 authors
    we purchased a massage chair from china , shipped to my home . my sister -guided ... being the home electronic "pro" ( lolz i don't know any real **** about ... it into 220vbroke it. i found the fuse to be burned. ... 110v AC inputMissing: national
Dec 14, 2015 | Health & Beauty
How do I use this adapter in the US with 220 voltage
is it an 220volt ac - dc adapter you could buy a 110V AC to DC adapter with the same DC Voltage and current rating
or you could buy a 110V to 220 Volt adapter
http://www.banggood.com/110V-to-220V-and-220V-to-110V-Voltage-Transformer-Converter-100W-p-938645.html?currency=AUD&refreshTmp=1&utm_source=google&utm_medium=shopping&utm_content=lola&utm_campaign=Beauty-AU&gclid=CIG68_Gl2cICFVcJvAod7GgArw
be careful with switch settings
http://www.ebay.com/bhp/transformer-110v-to-220v
please be aware if timing is required or electrical motors this could be a problem as usa is 60Hz and your appliciance may be designed to run at 50 Hz frequency
there are devices that can convert freq from 60hz to 50 hz
https://www.youtube.com/watch?v=RV3hEKLNm74
http://www.frequencyinverter.org/
Dec 22, 2014 | Photography
Sony cfd-s01 boombox radio
Hi Bart,
You will find there is a specification plate on the rear of the unit.
It should have a rating on it showing the wattage of the unit. This is usually the amount needed to operate all the functions of the boombox.
The wattage is your input voltage multiplied by the current draw in amps. So the amperage is the rated wattage of the unit divided by the input voltage.
Usually all power goes through the transformer, so I would use this input amperage as a guide, and assuming there is no power loss, use the same calculation for the output - you know it is 9 volts, so the wattage going to the unit is the same as the input wattage, so you can calculate the amperage from this.
Transformers usually work on AC input/output, so there will also be a rectifier to convert the AC to DC for your boombox.
I would add 10 - 20% above your calculation to make sure you have sufficient power. Also I suggest that you install a fuse between your transformer and the boombox for safety.
Feb 02, 2014 | Audio Players & Recorders
I bought my drill from the US and as we know its 110v AC there, i want to make the charger into a car charger 12v DC. is there any way of doin this and if so can someone please help me
You cannot convert an AC charger into a DC charger for a cordless tool, no matter what you do. The charger has a transformer that operates only on an AC current only. You did not state what battery your drill has, but a range of chargers are available for cordless tools, as long as the batteries are 12v or less. Speak to your hardware outlet.
May 03, 2011 | Vacuums
Power Requirement for Delphi Roady 2 XM Radio
Radio shack has a unit that plugs into a 110 socket and will accept the 12V plug that is standard with the radio. I use my unit in the house, car and on my motorcycle. The part number is 22-505 for the Radio Shack part.
Dec 02, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Crown XLS 802 D Amplifier Transformer!
You will need AC to AC converter that will accomodate US to UK mains. Look for power requirements of your amp on name plate and match with available converters online. Make sure power line frequencies match in/out requiremnts
Apr 17, 2008 | Crown XLS 802 D Amplifier
Qwestar MVP360A AC Adapter
Purchase a power supply, this will allow you to plug your car cord into the house. Available at most electronic stores, radioshack is your best bet. Good Luck
Sep 18, 2007 | Qwestar MVP360 Car DVD Player
153 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
