Question about Uniden Cordless Phone
I AM GETTING FEED BACK AND PEOPLE CANNOT HEAR ME
    Problem Solver:
  • 14 Answers
Contact me :yoggim@yahoo.com with details.
Posted on Jul 22, 2010
Singer futura xl-400 should the feed dogs be disengaged when embroidering
ABSOLUTELY! The XL models of embroidery machines are supposed to automatically lower when you put the embroidery unit on, but I have had an XL-400 and currently have an XL-550 and Quintet, and I have noticed on the latter two that the feed dogs have not always automatically lowered. Incidentally, to lower or raise the feed dogs, the lever (it's in the back) goes DOWN and OVER. If you are having problems getting it move, use a straight blade screwdriver and pop the little tip off--it's not necessary to operating the feed dogs.
Also incidentally, when you raise the feed dogs, you have to turn the hand wheel towards (ALWAYS towards you for anything) several times to get the feed dogs to actually pop up. You'll hear when it does that. They lower right away, though.
Jun 11, 2014 | Singer Sewing Machines
I hear starter spinning right before it engages engine
It sounds like the starter is going bad. you may want to replace it before it destroys your flywheel. A lifetime replacement starter at autozone is about $125.00 plus instalation if this was helpfull please leave good feed back
Feb 06, 2014 | 2000 Ford Taurus
Kfc complaints department
Have you tried KFC's website? I'll bet the regional manager would like to hear from you.
Jan 16, 2014 | Computers & Internet
Its not getting anyfuel to the fuel pump
The fuel has to be drawn to the pump with vacuum made by the fuel pump. Disconnect the feed line to the pump and install a vacuum gauge, crank the engine over and see if it has 8-10 in of vacuum. If not the pump is not working properly. If it does, check the fuel lings that go to the tank. If there is a crack, it will not pull the gas to the pump(like a straw with a hole in it). If that all looks fine, you may have an obstruction in the tank. Back flush the fuel line with air and listen to see if you can hear air of bubbles in the tank NOTE if there is a lot of fuel in the tank,some gas may splash out. If you hear air, Blow air from the tank forward to the disconnected pump feed line. If there is fuel in the tank it should flow out. If not you may need to R&R the tank to find a problem
Nov 03, 2013 | 1983 Chevrolet K1500
Singer 507 sewing machine - material wont feed through
if the fabric won't feed thru then there is something wrong with the feed dogs
May 25, 2012 | Singer Sewing Machines
My mic rophone seems not to be working .? when i make a call I can hear them just fine. but thay can't hear me ? unless I put my c550 right up to my mouth and speak is there somthing i can do so thay can...
Honestly I had the same unit as you do now and I had the same problem you are having. Your better off getting a good blue tooth headset like Jawbone or one of the others that are on the market today. Also while your on your phone you loose the feature of the voice to tell you when to turn and to me I didnt like that either.
I hope this helps you out, if it does please leave me some feed back.
Apr 04, 2011 | Garmin StreetPilot c550 GPS Receiver
I have a cobra29 wx nw st. its been peaked and tuned, an echo board installed, and soundtracker override when i key up if my mic gain is over 1/4 the way up it makes an awful racket what do i do?
is there talk back installed? if so its probably too loud. You are getting feed back. The talk back should be low, just enough to hear it to check echo. 470 ohm resistor is perfect.
Jan 04, 2010 | Cobra 29 WX NW ST 40-Channels Base CB...
Out of paper message, won't feed paper
The feed roller was turning but the paper wasn't moving and so I kept getting an "out of paper message." The paper was actually getting caught on a small black piece in the back of the printer. I removed the black piece and the paper start to feed fine.
Remove the back access door (it just pops out... no screwdriver required). The black guide piece (2nd from left) is about the size of my little toe after I took it out. Use a flat head screw driver to pop it out... that should leave 3 black guide pieces left. Put the access door back on the printer and the problem should be solved.
May 20, 2009 | HP PSC 1610 All-In-One Printer, Scanner...
Voltage regulator location
NOT sure of what back feed you are talking about. But for reference the voltage regulator is BUILT IN the alternator.
Jan 08, 2009 | 1995 Eagle Summit
Uniden Cordless Phone Logo
59 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
