Question about Canon EOS Rebel K2 35mm SLR Camera
Auto Focus Camera will not take picture will only focus in and focus out while it is on auto focus when you switch to manual it will take picture but it will not focus all the way in. Tried a different lens but it still did same thing.
  • 1 more comment
  • volsfan May 14, 2008
    Yes you can rotate the focus ring and you can get a clear picture through the lens but as soon as you push button to take picture it gets fuzzy again - it is really odd
  • Edward Stewart
    Edward Stewart May 11, 2010
    Do you know what AF setting you are on. Some cameras allow you to change from spot focus etc.
    What happens when you try to shoot the sky outdoors?
    What type of lense are you using?
  • Edward Stewart
    On manual focus you need to adjust the focus ring manually, the camera will nto control the focus at all. Are you able to rotate the focus ring at all when it is in manual mode?
  • 60 Answers
Try removing the camera lens and VERY CAREFULLY raise the mirror in the camera. There is another small mirror behind the main mirror that reflects the light for the autofocus to work. If the spring on that small mirror is broken (common problem) it can cause the symptom you are experiencing.
You can also check it by aiming the camera at an object above your head with the camera pointed up since that will hold the little mirror in place by gravity. If it works pointed up the spring is the problem.
You can get the spring from Canon. The part number is CS2-6367-000. Canon's parts dept phone number is 1-732-521-7230.
CameraRepairs
Posted on Aug 11, 2008
Rewind sound when switched from auto focus to manual focus
Probably a problem with the af/m switch so that even though switching to manual moves the connector out of the way (pulls it into the mount) the af motor continues to run. Remover the bottom and then the front cover and check the switch.
Jan 23, 2014 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
I can't get my camera out of auto focus
Did you push down the lever on the side of mirror box to switch it to manual focus? If so and it is still not going into manual focus, then the switch may be damaged (bent switch contacts etc.). You can check the switch by removing the bottom and front covers. Beware of loose parts!
Oct 27, 2013 | Minolta Maxxum 400si 35mm SLR Camera
My camera turns on but it won't focus on automatic and when I press the button to take a picture it won't take one on manuel or automatic.
There may be a few things preventing the camera from taking a picture. I don't know the lens you are using but by chance does it have an auto/manual switch that has been switched to manual? Also make sure the lens is locked in position. The camera won't take a picture unless it has focus in the auto focus mode, this is normal. What are you trying to focus on? The camera auto focus system will search and fail to auto focus on surfaces that have little or nor contrast. For example glass, chrome, a blank wall, water, blue sky. Other conditions that auto focus fails is being to close to your subject, heavy fog, a dim lit subject, available light and night photography. Once the little green confirmation light comes on the camera has focus and will operate as it should.
Nov 27, 2010 | Canon EOS Rebel XS 35mm SLR Camera
You push the button and it will not take a picture. I put new batteries in it and it still will not take a picture.
My HTsi Plus never seems to be able to Auto Focus on a subject, so when you push the shutter button half-way, it just flashes the focus indicator (telling you it is unable to focus). Try switching over to the "Manual Focus" mode. On the front of the camera there is a button labeled "AF/M". Push that button to switch to manual focus. If the camera is in manual focus, the external LCD screen will say "M.Focus". Now try to snap a shot. If that still does not work, there may be something wrong with the camera or the lens. So, try using a different lens in manual focus mode. If it still does not work, then I would say the problem is with the camera itself.
Nov 15, 2010 | Minolta Maxxum HTsi Plus 35mm SLR Camera
My Nikon N55 will not auto focus.
Depending on the type of interchangeable lens you have mounted on the camera, there may be a switch on the lens barrel for choosing between auto-focus or manual focus. The N55 also will not auto-focus with the newer Nikon AFS lenses such as those used with the Nikon D40 digital slr. Finally, there was a service bulletin on the N55 back in 2005. Nikon discovered a problem with the auto-focus and fixed it for free, but there may have been a time limit. Here is a link to more info about that:
http://www.nikonusa.com/Service-And-Support/Service-Advisories/N55-Service-Advisory.page
Hope this helps : -)
Nov 30, 2009 | Nikon N55 35mm SLR Camera
Trouble with Pentax MZ 60 camera.
does the camera work without lens mounted?
turn auto focus switch to manual focus when using non- auto focus lenses.
Dec 24, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Canon 3000N Auto focus fault
No extra batteries.
Usually this is a lens fault as the focusing gear is all in the lens. Clicking sounds as if a rear pinion has cracked. It's not uncomon in the 'prosumer' level lenses where plastic gears are used a lot.
It's just possible the fault is which the auto-manual switch. This usually has a mechanical clutch coupled to it which physically disconnects the gearbox from the focusing ring, as well as operating a switch to tell the camera to turn off the AF system.
Dec 21, 2008 | Nikon F65 35mm SLR Camera
Nikon N55 Won't take picture in Auto Focus Mode?
There was a recall on the N55 due to auto focus problems. You can do a google search or nikon.com email the support team and they will send you the paper. This is what I did, I wasn't charged since I had the correct papers. I, however, used one roll of film and my focus went out again! Mine doesn't even work on manual... If you want to try that maybe you will hae better luck than me. GOOD LUCK!
Apr 28, 2008 | Nikon N55 35mm SLR Camera
Minolta Maxxum 7000i
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Sep 28, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Canon EOS Rebel K2 35mm SLR Camera Logo
155 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
