Question about Xerox Office Equipment & Supplies
Xerox workcentre 4150 will not turn on. 3 yrs old. no warranty. plugged into a surge protector with other equipment that's on. switched outlets and reset surge protector. xerox copier will not turn on.
  • 2,272 Answers
If there is no power at all.Then this problem relates to three problems. 1)Either the power outlet in which the power cord of the xerox work center in inserted that is faulty.Try in another power outlet then check. 2) The power wire of the xerox work center itself is faulty. 3) The major problem the power supply board of the xerox work center has been got short and the power supply board needs to be checked by meter and faulty components on the power supply board has to be replaced. Now out of this three possibilities the first possibility has been tried by you.That is ,you checked the other devices on the same outlet and that are working.But still you try to connect the xerox work center in other different power outlet if its possible ,because many a times the xerox work center requires certain amount of voltage/current to power on and on that power out its not getting the required current to turn ON.so try it on another power outlet and confirm the first possibility.But if same NO power problem in another power outlet too,then check the power cord.IF possible replace the power wire and check.IN some cases the Power wire is internally fitted on the power supply board of the xerox work center so in that case the internal power wire has to be disassembled from the power supply board and external power wire has to be connected.But that is bit technical job and technicians help is required because the exact voltage of external power has to be checked.If its confirmed that power cord of the xerox work center is OK,then the power supply board is faulty.But this power supply board as a whole never goes faulty.On power supply board there are many tiny electronic components.If any of the components gets weak or shorted then this makes the power problem as the current gets cut on the board.Many a time its a tiny fuse problem.On the power supply board there is a tiny fuse located for safety purpose.This fuse blows out actually to save whole power supply board from blowing out and get faulty.In that case only replacing the fuse solves the problem.But for that also the xerox work center has to be disassembled to reach the power supply board. Any of this possibility can cause this problem of NO power on the xerox work center.Get it checked and replace the faulty as per the problem. Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 22, 2010
  • deblieux Jul 22, 2010
    I've disassembled the printer and I'm at the power supply board. How do you change out the fuse. I don't see it.
Xerox workcentre 4150 not printing test page on windows 7
Hi Cnorini ,
Check this video and solve your problem.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Xerox Printer Support
Mar 04, 2014 | Xerox WorkCentre 4150 Black and White...
I need to change my Xerox workcentre 4150 toner cartridge. The old cartridge is stuck and I cannot get it out. Any ideas? Thank you. Russ thornock
You have to twist them clockwise and then counter clockwise. There is a locating pin they stick on in back, All I can say is twist and pull.
You can try opening the right side door and sliding a thin bladed screwdriver in there to assist in lostening it .
That is not uncommon and is frustraiting.
Jul 03, 2010 | Xerox WorkCentre 4150 Black and White...
Olevia 37" no picture
check the TV power cord first., try to plug any other appliances on the same surge protector or outlet, like electric fan, electric iron., see if's work., if it does, probably the power supply of your TV is in trouble.
May 09, 2010 | Olevia LT37HV 37 in. HD-Ready LCD...
My workcentre 4150 is on my network and sometimes
Check and see if your using the PS driver for that machine, If so switch to the PCL driver. The PS one has been known to run slow.
Mar 22, 2010 | Xerox WorkCentre 4150/C All-In-One Laser...
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Xerox 4150 Workcentre, when xeroxing and pringt copies are dark and gray. I have clean the the window but still grayish.
Sorry I didnt see your post a while back.
You shold call and have the firmware updated on that machine.
There are several firmware updates to the 4150 that resolve a lot of problems with the machine/.
Dec 04, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
Xerox 4150 Multifunction Printer
From my expreiences with that product, you should reload the machine software.
If the machine is less than one year old call for service it is under warranty.
If not you can go to www.xerox.com and download the firmware,10.100.32.000.
It will resolve many software issues on that product.
You can download it to your computter then upload it to your machine.
Some of the versions of software on that product have some issues. Most are resolved with that version.
You will also need to download the 4150 printer setting utilities if you are going to do this yourself.
You may lose your LDAP settings, so be sure you print out a settings or configuration page before you do the upgrade.
Feb 25, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
536 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
