I recently purchased a reconditioned computer. none of the USB ports are working. is there a way to enable them?
    Genius:
  • 1,027 Answers
Sometimes USB can be enabled in BIOS set-up.
Most often it is the chipset that needs updating.
If USB support is enabled in BIOS, Then download eversesthome
run the program click on the <+> by motherboard, Click on chipset
click on NORTHBRIDGE, google chipset id for updates.
Posted on Apr 22, 2008
How to enable highspeed usb on neclcd1770nx monitor
On most monitors that have usb ports you have to run a usb cable from the computer to the monitor to get the usb ports to work.
If your computer is not equipped with high speed usb ports you can purchase a pci usb adapter card that can make it usb 2.0 which is considered high speed.
Try purchasing one from Tiger Direct at:
http://www.tigerdirect.com
Below is a link to one that I use which costs $9.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5265856&CatId=511
Jun 09, 2012 | Computers & Internet
Doesn't work.....no laser light appears on the bottom of the mouse. Nothing happens when I hit the "connect" button.
It sounds like these is either a problem with the USB port on the motherboard or with the mouse itself.
Assuming that if a wireless mouse: the batteries are new, the device is actually turned on and the transmitter has been removed from the mouse and plugged into the the USB port and it still does not work, it should be tried on all the other USB ports of the computer. If none work, try on another computer.
This will help determine if the mouse or the computer is the problem. If the mouse does not work on other ports or on the other computer, a defective mouse is likely. If it does work in a different USB port of the original computer, the first USB port is suspect.
If it only works on a different computer, the problem my lie in the setup or BIOS page of the computer. Look for a setting for USB ports. Enable the ports if disabled, and try again. If still no luck, there is some other issue at the motherboard level. Unless fairly new and under warranty, it will probably not be worth trying to fix the problem, when a $20 USB expansion card could be purchased and installed to provide USB connectivity needed.
You could also try connecting a different USB device (if available) to test the USB port. A USB webcam, hard drive, mechanical mouse, etc. are all good choices to test the port. You should indicate or cover any ports that are found to be defective.
I hope this helped and good luck!
Nov 01, 2010 | Computers & Internet
P4p800 se motherboard. usb doesn't work
you can purchase add-on p[ci usb cards for around $25 at a store such as best buy or online.
May 24, 2010 | ASUS P4P800 SE (890552603657) Motherboard
None of my usb ports work. Help!
  1. restart the computer
  2. to to bios setup
  3. enable the usb port  or use auto detect settings
  4. save changes
  5. restart the computer
Apr 09, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Acer Aspire 5532
webcam has own microphone which use USB like camera. Windows has own port for microphone.
go to software options which you are using with camera and change recording device to different one " it should be named like "USB mic" or something like that.
i would check to software included to camera too
Mar 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
We have recently purchased an Intel I7 processor and installed it into the ASUS P6T motherboard. We have also installed Windows 7 OEM builders operating system (not an upgrade version over windows XT). The...
Run "Windows Update", to see if it will find updated device-drivers for the specific USB hardware on the motherboard.
Access the ASUS web-site, and search for 'P6T', and search for USB device-drivers for Windows 7 -- if none are found, try the device-drivers for Windows Vista.
Jan 22, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
Usb ports not working, drivers ok,
Click on the link below and scroll down to the "Fixit" button. This is a patch to enable USB devices. This is a common problem especially after running Windows Update. Good luck.
Greg
http://support.microsoft.com/kb/817900
May 29, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Where can i download usb drivers for my ibm thinkcenter.
What version of Windows are you using? What happens when you plug in a USB device? Any error messages? Check your BIOS and see if the ports are enabled. If theyre not, then enable them. If youre running Windows 98 Second Edition or newer, the USB port drivers are typically built in. If all else fails, you can purchase and install a USB card. If its an older machine, get the 2 port card, otherwise, the 4 or more port card will suffice. (Some 4 or more port cards dont play nice in older machines.)
Mar 01, 2009 | IBM ThinkCentre A50p PC Desktop
Portable external hard drive
Greetings,
It's the USB port on that computer.
Try all USB ports and make sure you got it connected DIRECTLY.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 23, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
USB Ports Not Working
Check your CMOS settings to ensure that your USB ports are enabled.
Oct 15, 2007 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
David Payne
David Payne
