Question about Kenmore 16622 Mechanical Sewing Machine
Where can I find a manual for Model 16622? ITs a differential feed serger and I've misplaced my manual
  • Kenmore Master
  • 7,365 Answers
Try these sites
sew usa
sewing manuals.com
ebay
Posted on Jul 30, 2010
White Speedylock SL34D, manual
White Speedylock Differential Serger Manual
www.manualsonline.com/.../white/.../white-speedylock-differential-serge...
Find the user manual and the help you need for the products you own at ManualsOnline. ... White Speedylock Differential Serger Model Number : SL34D.
White Speedylock SL34D, manual - Fixya
www.fixya.com/support/t14860576-white_speedylock_sl34d_manual
Nov 2, 2012 - White Speedylock SL34D, manual - Sewing Machines ... i was able to find one at www.ifixmachines.com ... I have a 1500 with a manual. I could ...
Sewing Machine Instructions White Speedylock Differential ...
? 21:00
https://www.youtube.com/watch?v=-cvfkBvrw3o
Oct 17, 2013 - Uploaded by Michael Del Polito
Sewing Machine Instructions White Speedylock Differential 1800 ... That is video to help me to fix my wife's ...
White Sl34d Serger Manual
Nov 02, 2012 | Sewing Machines
I need a Kenmore Manual for a serger 3/4 differential feed model 385 1574290
try these sites
sewingpartsonline.com
sewusa.com
sew4less.com
sewingmanuals.com
sewingmanuals.net
Jun 02, 2012 | Sewing Machines
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
I need a manual for a Pfaff Hobbylock Serger 4762, where can I find one
I can't find a manual for this model, however there is a general hobbylock book http://sewingonline.co.uk/library/know-your-pfaff-hobbylock.html which would certainly be a good start.
You may find best source is to contact Pfaff locally and source it from them direct.
You could also try www.diplodocs.com, I can't see this manual but if you go through similar model numbers manuals you may see one very similar. Overlockers/Sergers are very similar in many ways so once you've mastered one, the next one is pretty straight forward. Four tension knobs, 2 needles and 2 loopers is the norm - to get a three thread stitch you just don't thread one of the needles. Tension adjustments alter the stitch formation, and you should have a stitch length knob on the right side of the machine along with a flywheel and if it has it, differential feed (which controls the feed dogs so you can stretch, or compress the fabric as it goes under the foot).
There are some good general how to use a serger books in the marketplace too which should help. Threading up, many machines have a diagram inside the front flap, colour coded dots on the knobs, eyelets and loopers. And oiling points are often marked on this diagram too. But basically oil the two loopers where they slide/move on another metal part. Some good info here too http://sewing.about.com/od/sergersoverlock/Sergers_Overlock_Sewing_Machines.htm
Hope this assists you a little.
Apr 18, 2011 | Sewing Machines
How do I operate the differential feed? I bought
The differential feed is usually on the right side, you will see a some numbers. Their should be one that sticks out (might be red, The letter "N", "0", or a line) This is the normal setting. A larger number is going to gather the fabric and a smaller (.99 and below) is going to stretch.
Hope that helps :)
Chris
Jun 06, 2010 | Sewing Machines
How do you thread the Singer QuantumLock 5 Differential Feed?
www.singerco.com/pdf/14SH654_threading.pdf
Its a different model, but most sergers thread the same way.
Mar 30, 2009 | Singer Sewing Machines
Need Serger Manual for Model BL402
i HAVE THE MANUAL FOR bl402.
trial2962@gmail.com
Mar 04, 2009 | Baby Lock Eclipse Serger
Need manual for singer serger model # 14sh654
Hi Wendy. Go to this web address and you can order what you need. http://www.sewingmachineparts.net/index.html
Please remember to rate my answer. thanks.
Feb 05, 2009 | Sewing Machines
What does the differential feed do?
Get a basic book on serging from your library. The higher the #, the feed dogs infront feed fabric in faster, keeping knits, etc from stretching. It can also gather if you go to the highest #. A slightly lower # the N can be used for slippery fabrics because it slows the front feed dogs, but be careful because it can stretch and ruin the fabric. I have only once needed the lower # for a really slippery chiffon. Start on scraps and experiemnt. It's not used very often unless you sew daily or professionally.
Mar 18, 2008 | Baby Lock Eclipse Serger
Sewing Machines Logo
127 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
