Question about Dynex 4-Port 10 Mbps Ethernet Hub
I can't access my survallance system from homs since we have installed the Dynex hub
  • 560 Answers
Hi. Please make sure that you can connect to the internet through Dynex hub by connecting a laptop/PC to the hub.
If you can't connect to the Internet through Dynex hub, check the patch cable. Since that is a hub, you need to use crossover cable from Dynex LAN port 1 to the switch or router. Make sure that your surveillance system is connected to a good port on Dynex hub.
Let me know if you have more questions. Good luck.
Posted on Jul 22, 2010
Computer is not recognizing Dynex 5 in 1
What type of computer? The device is plug and play for Windows and Mac, Mac does require you to insert a card before it will mount, however. In windows you just need to access the drive letter the card reader creates when you install it.
Try another USB port, avoid using this in conjunction with a USB hub.
Apr 19, 2011 | Dynex USB 2.0 CompactFlash Card Reader
I HAVE 22 MBPS OF WIRED INTERNET CONNECTION. I HAVE TRIED TO HOOK UP MY BLURAY PLAYER TO THE INTERNET WITH NO LUCK. MY ROUTER ONLY HAS 1 ETHERNET SLOT, SO I BOUGHT A DYNEX 4 PORT HUB TO EXPAND TO THE...
You mentioned in your question that you had a router. If it is actually a modem, then yes, you need a router.
The reason that the Ethernet hub is not working is that your modem will only give out 1 IP address to one device on the hub. With a router, the router uses the 1 IP address and shares access to the internet via that 1 IP address.
Yes, you'll need a router instead of a hub.
Dec 29, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
Hom to replace air cabid filter for 2005 hnda accrd v6
The cabin air filter, which is part of the AC system, is normally accessed behind the glove compartmant door.
Open the glove compartment door and GENTLY press inward on the door supports to release them. You will see a white plastic cover. Remove it. The cabin air filter is there.
Jul 04, 2010 | 2005 Honda Accord
How do i access it from my laotop to make changes
The hub you've listed here cannot be managed. Hubs are non-intelligent devices. What changes did you want to make to a 4 port hub? Hubs are just used to physically connect network devices.
Mar 04, 2010 | Dynex 4-Port 10 Mbps Ethernet Hub
HPNA setup
all you need is the longitus eterneth cable needed to connect to / from the Dynex 4 port Hub ethernet cable plus a host pc on Dynex 4 port ethernet hub, the host pc you need to specify that you are sharing the connection of internet connection through the eterneth, and ready
luck
Jan 11, 2010 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
My dynex usb hub is not working
You need to unplug the power adapter from the wall, and disconnect the usb cord from the PC/laptop for at least 30 seconds. Then plug everything back in. Apparently this model suffers from static electricity from time to time. I have this hub also and it works every time.
Apr 06, 2009 | Dynex 4-Port USB 2.0 Hub
Dynex 4-Port 10 Mbps Ethernet Hub Logo
48 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Mike
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
