Question about LG DLE5932W Electric Dryer
I need to put a four wire 220 plug on a 3 wire LG DLE5932W dryer
  • 1,543 Answers
Remove wire from ground screw and move it to center terminal and attach white wire there. Red wire to one outside terminal, black to the other, green goes to the frame (ground) where the first wire came from.
Posted on Jul 22, 2010
How disasembly the heater on LG DLE5932w
http://www.repairclinic.com/Dryer-Repair-Help
Feb 26, 2011 | LG DLE5932W Electric Dryer
The check filter light is on. The clothes are not
The check filter light, is default message LG was put in place. No problem there. As for the clothes, I'd need some more infomation, what settings are you using on your dryer? I'll need to know if your using sensor dry, or manual dry.
Jan 30, 2010 | LG DLE5932W Electric Dryer
Installing a four prong plug
best bet would to be to buy a plug that matches your receptical.....this is somthing you do not want to monkey with as if not wired right could turn your dryer into a fire hazzard. white to white green to green black to black and the other wire goes to earth ground for like trailer houses and modular homes.
Nov 23, 2009 | Whirlpool Dryers
Wiring 4 wird dryer plug to 3 wire 10/3 for 220 welder
the four wire plug seperates the neutral and ground. the three wire just piggybacks the ground to the neutral. so just get a three wire cord that fits the 220 plug on the generator and install it on your dryer make sure to attach the ground correctly for your three wire setup
May 07, 2008 | Dryers
I have a 4 wire dryer plug and a 10/3 wire that I want to connect to a welder that is 3 wire. No idea how to splice the wire as the dryer has a bare ground. welder is 220 and 25 amp. help.....
get a 3 wire cord and install it on your dryer is the easiest way. the four wire setup removes the ground from the neutral.
just piggyback the ground to the neutral for your 3 wire setup
Dle5932w electric dryer
the back of the dryer have about 16 sheet metal screws.remove all the screws with a nut driver.the back should come off.
Jan 08, 2008 | LG DLE5932W Electric Dryer
No power
THese diagrams may help some
http://www.pcappliancerepair.com/model-display.php
Dryer NO Power
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
if you dont have a ohm meter you can hook the wires together
with a small piece of wire and by pass the themostates and hi limit fuse to see if thats the problem or not
Nov 03, 2007 | LG DLE5932W Electric Dryer
LG DLE5932W Electric Dryer Logo
108 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
